Question about Whirlpool Dishwashers
My dishwasher is coming up with a error 4. my dishwasher is a whirlpool ADP6000WH/ADP6000IX please help
I just had the same thing, same model. After cleaning the filter out, the problem remained. I then read on another forum that it helps if you tilt the machine backwards for a few minutes (which involved pulling it out of the cavity in the kitchen). Did this and it now seems to be working. Hope this helps you.
Posted on Aug 13, 2010
  • megan_armstr Oct 10, 2010
    I've just had the same problem, and I tip it at a 75 degree angle for 2 minutes and the error dissappeared. THANKS
What's error 2 in whirlpool adp6000ix dishwasher
ERROR 2 = Longer Drain Time
Possible cause = The installation position of the drain pipe too high or the drain pump faulty
Jul 26, 2018 | Dishwashers
Model ADP6000WH/ADP6000IX. What is error 2?
if this is a model that flashes the clean light in blinking code for faults , then your not properly reading the flashing light , if it repeats the two - two flash rate this is an indication that its lost its communication between its internal circuit boards (most times this is a logic board problem ) but it can be the other ones as well or ive even seen a wet cable do this as well , if the flash rate is 1 flash - two flash this is an indication that there is stuck key on the keyboard (or a cable problem too )
but the Number one problem I see with dishwashers is there's water(or had been) where it should not be !! water in the wrong spot causes all sort of gremlins to show up and it doesn't take much just one drop and its chaos
Apr 13, 2016 | Whirlpool Dishwashers
Our whirlpool dishwasher make ADP6000WH/ADP6000IX runs for the first few minutes of each cycle the just kind of pauses and will not finish the cycle
Check your FLOAT... When it stops, Open the Door and see the Water LEVEL.
If the Water LEVEL is normal, then you have a problem with your Circuit Board
Apr 09, 2013 | Dishwashers
Whirlpool dishwasher ADP6000IX error3
see page 6 on this user manual for description of error 3.
Sep 21, 2012 | Whirlpool Dishwashers
ADP6000WH/ADP6000IX--Whirlpool Dishwasher.(new) My problem--Water not getting hot--i have it connected to the cold water--should it heat the water ?
9d561c5b-7c7e-4515-8a01-fbfa8f762c34.jpgerror 3 not heating..on wix6000 /or / ADP6000WH
same boards .
rip out the the main mother board with all the black boxes ,and the transformer on it,,there is 1 black box its the biggest of them all ,next to the fuse with the blue cover on it ,with care take the black cover off with a screw driver carefully, not to damage the lower half of the internals,the lower section must not be damaged all ,once the cover is off you will see a copper coil on one side and on the other a set of breaker points ,at the end of the points ,get a screw driver and push in the outter point inward just a fraction,and bingo it will work again,of coarse its a temp solution,you will need to get a new breaker box from tandy or dick smith or simlar place to keep it going long term ..
hope this helps guys and gals ,please take extream caution when working on such dangerous power sourses ,and always make sure the power cord is removed before and repairs or tweeks..
cheers
Sep 30, 2010 | Whirlpool Dishwashers
Whirlpool ADP6000WH Fault Code err 2
Hi, i have had my new dishwasher for less than 3 hours and is doing the same thing. Not happy Jan!!!! I have dishes everywhere, stuff out of the sink cupboard and a open house in 2 days. Watch out retravision in the morning!!!!!!! Did you get a solution to yours??
Jan 01, 2010 | Whirlpool 24 in. DU920PW Built-In...
What does it mean whirlpool adp6000wh err 4 message code
Error 4 means" too much inlet water", turn inlet water tap down.
Aug 25, 2009 | Whirlpool Dishwashers
Whirlpool dishwasher ADP6000WH Error 3
Hi there i have found out that error 4 mean's two many soap suds and ths washer thinks there's two much water. Try less soap and clean the filters.
Jan 15, 2009 | Dishwashers
WHIRLPOOL DISHWASHER ADP6000IX
your not alone. i to have this error 4 and so do hundreds of others.it means low water level even like mine your water level probably isnt low.what happened to mine was the sensor got a layer of fat and oil scum buildup on it and couldnt detect the water level so i cleaned it and worked good for another month. then same problem.solution- dishwasher had an "accidental short due to water leak" wich insurance covered and bought me a new dishwasher (fisher and pikel) now no more problem
Jul 30, 2008 | Dishwashers
Dishwashers Logo
610 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
