Question about Robinair Cool Tech 34700Z Recovery, Recycling, Recharging
34788 cool tech will not accept new filter codes tried two different filters and is locked out of recovery
    President:
  • 180 Answers
It will not unlock till you enter origenal robinair Spin-on filter code! Try with this code FD32C46B01. This is a free gift for you. Good luck & don't forget to vote it.
Posted on Aug 05, 2010
  • rbackstr1 Jul 13, 2011
    Any one got service code for a 34988
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
Here's fifteen different codes I have either used or come across. I have two Cooltech 34788 machines. I usually buy 5 generic filters and 5 real ones at a time. I use each code twice, once in each machine. I use the generic filters when I use the code the second time.
5652301803
165A581801
34AD16050A
6FAAC95001
A0DDFE7F01
D23FAA6701
FD32C46B01
FE56584C03
FE6A5B5703
FF3F7C4602
FF47C48201
8739734D01
FF62B7AA01
9DA2670A03
B6E1BE1B02
Posted on May 29, 2014
Is there a new 10 digit code for replacing filter on robinair 34788?i try the old two codes that Mr Hasan Khan Amran posted but fail please post another code ...God bless you
Please be informed that, one code can be use only one time! However now i will give one more new code: 6FAAC95001. Apply it now and solve the problem!
Don't forget to vote for it, if you wish to get help in future. Good luck....
Apr 14, 2012 | Robinair Cool Tech 34700Z Recovery,...
Will not accept filter code
TRY WITH THIS CODE: FD3F601C03. THIS WILL WORK FOR SURE
Nov 04, 2010 | Robinair Cool Tech 34700Z Recovery,...
How do you perform a manual reset on a 34788 cool tech filter replacement with filter lock out and no filter code accepted?
There is no way to reset without filter code. This machine ( Model-34788) will not accept even new filter code,if filter from old verson (manufacture before the machine). However try with this code-FD32C46B01. I'm sure this will work! Good luck & vote for my solution.
Aug 05, 2010 | Robinair Cool Tech 34700Z Recovery,...
34788 COOL TECH,FILTER LOCK OUT,REPLACED FILTER TWICE STILL LOCKED OUT,READS FILTER ERROR
Check the filter monitor air flow differential switch is not blocked or broken. have you a manual reset after filter change?
Aug 03, 2010 | Robinair Cool Tech 34700Z Recovery,...
Model 34288 robinair . Were is the weight . How do you do A filter change.
There is no Weight in the machine. Machine show Filter weight that you have been recover refrigerant from the vehicles since last filter change! After every 68KG/150LBS of refrigerant recovery you must change the Spin-no filter. The machine ( Model-34788 ) will lock-up when filter capacity reach to 68kg & you will not abel to access the machin till replace new the filter.
When the machine show the filter weight 68kg on screen just press YES key,then add the 10 Digit code of new filter ( Code is stick with evey filter). If the code is accepted then open the old filter & replace new one.Follow the on screen direction to compleat the process.
Note: Do not switch off the machine till compleat the filter change function.
Jul 05, 2010 | Robinair Cool Tech 34700Z Recovery,...
Cool Tech 34788 "air purge not working"
Please check ISV tank air purge (pressure) transducer & 12V DC discrete Solenoid ( both lacated on top of ISV ), it sounds like defective!
NOTE: Never use Automatic Mode till you are not very familiar with this machine
Jul 06, 2010 | Robinair Cool Tech 34700Z Recovery,...
I have a a modle 34788 robinair cooltech my day shift messed it up is there a way to fix my problim? it wont recover at all. all other functions work (with the lines off i can get it to vacumme)when i hook...
Please check 1# The compressor suction line with a vacuum gauge & make sure it has 13" HG of suction while you active recover. if not then you need to replace the compressor. 2# Check spin-on filter O rings are fixed properly it may missing or lose, also check filter capacity (amount of refrigerant you have been recover sinc last filter change.every 68KG or 150LBS of recovery you must change spin-on filter)
Jun 25, 2010 | Robinair Cool Tech 34700Z Recovery,...
I have a 34788 and it keeps leaking through a little hole above the filter and the machine seems to be freezing up.I have recently replaced the filter.What could be the poblem
With power off, open the filter & check two 'O' ring of filter is in the right position then replace filter again. Hope this will solve your problem.
Jun 16, 2010 | Robinair Cool Tech 34700Z Recovery,...
Robinair  Cool Tech 34700Z Recovery, Recycling, Recharging Logo
1,561 people viewed this question
Top Robinair Measuring Tools & Sensors Experts
Mike
Jay Finke
Jay Finke
Are you a Robinair Measuring Tool and Sensor Expert? Answer questions, earn points and help others
