Bea and mae is working together.In one hour they could finish 20 basket how many basket can mae and bea finish alone in one hour?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 99 Answers
50hrs
Posted on Aug 05, 2010
GE WCVH6260Fww knocks during spin
Had the same GE model number and similar problem. The basket (stainless steel) doesn't look centered in the unit anymore, you can tell when looking around the perimeter of the basket and compare to the rubber gasket. On front load washers the basket (the stainless piece that spins), if the door is open and if you push up on the basket there should be very very little to NO play or give . Meaning the basket should not be able to move up, down, side to side (not talking about spinning, just north, south, east, west). If there is play or movement there is a very good chance (thinking 95% sure) that it is the bearing. Not good news for any front washer but GE in all it's wisdom set it's crack engineers out to design this unit so that the bearing is not an individual part, this design has the basket (THE ACTUAL STAINLESS BASKET), THE SUPPORT ROD AND BEARINGS AS A SINGLE PIECE. The "Basket Assembly" alone is between $550 and $650, before tax, before labor if you don't do it yourself. If you decided to tackle this yourself you have to totally disassemble the entire unit to replace it. No exaggeration, you literally have to take the entire outer tub assembly apart to replace. If you are able to accomplish this without damaging any other part then you have to Humpty Dumpty back together again, without damaging anything else. Hope this helps.
Nov 23, 2011 | GE WCVH6260F Front Load Washer
Working alone,Maria can complete a task in 100 minutes.Ann can complete the same job in 2 hours.They work together for 30 minutes when Liu,the new employee,joins and begin helping.They finish the job 20...
Check my work, before you hand it in -- there could be some DELIBERATE errors in my fractions. :-)
Marie takes 100 minutes for 1 job.
Marie took 50 minutes for 1/2 job.
Ann takes 120 minutes for 1 job.
Ann took 30 minutes and did 1/4 job.
Ann took 20 more minutes and did 1/6 job.
Together Marie & Ann did 1/2 plus 1/4 plus 1/6 job in 50 minutes.
Together Marie & Ann did 6/12 plus 3/12 plus 2/12 job in 50 minutes.
Together Marie & Ann did 11/12 job in 50 minutes.
Liu did the rest (1-(1/2+1/4+1/6)) job in 20 minutes.
Liu did the rest (1-(4+3+2)/12) job in 20 minutes.
Liu did the rest (1-9/12) in 20 minutes.
Liu did the rest (1/4) in 20 minutes.
Liu worked for 5 minutes.
Sep 17, 2010 | Computers & Internet
Error code 8 appeared and now cannot get basket
The machine did not complete its cycle, either while finishing a brewing cycle or a cleaning cycle. This is caused because the motor is not strong enough and overheated. I think it is a design problem, but there is a "work-around" solution.
First, to put basket back, look inside opening. You will see a flap at the back of the opening. This flap is down and is what is preventing insertion of basket. Take only the grounds basket. Tilt the grounds basket and insert it so the back end of basket goes under the flap. Then level out the basket. Note the flap is now inside the back end of the grounds basket. Holding the basket up and level, re-insert the drip tray and the basket holder underneath the basket. These should now slip into place.
The "work-around" solution is to let the motor cool down. Unplug the machine for at least 30 minutes, then turn unit back on, and the cycle should complete because the motor is now cool.
I notice this error 8 happens mainly when the voltage from the Hydro Utility is low. This happens during peak electricity usage hours. So, to clean your machine, do it on the week-end during the daytime either mid-morning or mid-afternoon.
Good luck
Sep 27, 2009 | Jura Capresso Coffee Makers & Espresso...
Peeling paint coming off of oil rubbed bronze basket strainer
Bronze is more expensive than standard mass production is worth, i supposed if you want them made out of any mat. you can call kohler and pay for it, i've been to their plant and they do some pretty awsome custom work.
Rubbed oil is just a color and somtimes "you get what you pay for" if you buy a cheap basket strainer they usually do exactly what you're saying.
You can buy more expensive strainers that have a better finish, I know Kohler and Moen have lifetime warranty finish on many of their higher end products.
Mar 03, 2009 | Mountain Plumbing Mountain Basket Strainer...
How to make coffee with 101-cup percolator urn (Regalware)?
Simply fill with COLD water to the number of cups desired.
Place the stem and basket in the pot and put one 8 oz cup of coffee for every 20 cups of water into the basket...when doing 100 cups I add an extra 12 oz of coffee for a good coffee flavor.
Place the perforated lid on the coffee basket that is in the pot (if there is a lid--some do not have a lid). Put the cover for the coffee pot in place.
Plug in.
Turn on if there is a switch.
Give these large pots about 1 minute per cup, brewing time...that is a little over an hour usually to brew 100 cups. The coffee maker will percolate with the water coming up through the stem and over the coffee as the water heats. Usually there is an indicator light that comes on when it is finished.
If holding the coffee for awhile, it tastes best if you remove the stem and basket and it will maintain the heat without doing more "perking" and becoming stronger or bitter.
Be sure to wash it out and dry it well, leaving the lid loose or upside down for storage so that the pot doesn't become pitted. Blessings, Louise
Nov 14, 2008 | Regal Ware 426473 Black Satin Coffee Urn...
Work problem
Here is the answer:
Daisy did 2/5ths or %40 of the barn in those two days as she can do the whole lot in 5 days she did 2/5ths or %40 in 2 days so thats %40 of the barn done.
Didith did 2/8ths or %25 of the barn in those two days,
so the amount of barn painted in the first two days is: 1/4 + 2/5 which equals %65 of the barn complete in the first two days. so there is %35 of the barn left to paint and only Daisy (who can paint %20 of the barn in one day)
so to figure out how many days it takes Daisy to paint %35 of the barn this is what to do:
%20 = 1day %35 - %20 = %15 5x5x5x5 = 20 5x5x5 = 15 therefore it takes Daisy 1/4 of a day to paint %5 of the barn therefore it takes Daisy 3/4 of a day to paint %15 of the barn (i hope you are following me here!) 1 + 3/4 = one and three quarters of a day
Therefore it took Daisy one and three quarter days to paint the remaining %35 of the barn.
So it took Days one and three quarter days to finish the job after Didith left.
Hope this is helpful
Emmanuel
Sep 17, 2008 | Computers & Internet
No Stereo & center sound together in CD mode or TV mode
Something isn't wired correctly, check you wiring and get back to me.
Jul 15, 2008 | Bose Lifestyle 28 System
Fryer basket
Put the one bar into the C shape and squeeze it closed with plyers, mine works great now.
Sep 03, 2007 | Rival RCF25 Deep Fryer
Computers & Internet Logo
74 people viewed this question
David Payne
David Payne
