Question about Intex Easy Set Pool 15x36
Como encuentro donde pierde aire la parte inflable de mi piscina intex easy set pool
  • 323 Answers
SOURCE: Lopsided 18x4 intex round easy set pool
I started out with easy set pools a few years ago and finally gave up and went to their steel supported ones.
I have put up over 20 above ground Intex pools and have learned a few things in the process:
A: The larger the pool with the air ring at the top the more difficult it is to fill to its maximum potential.
B: Eventually the pool is going to collapse with people in it, especially if someone leans over the edge with their arms on it which is a perfectly natural thing to do.
C: It is virtually impossible to get an area beneath the pool level without scraping the ground and measuring it with, in your case, at least a 16' long 2"x4" on its edge with a level on it.
D: Trying to build up the ground on one side with sand will eventually result in collapse of the pool.
E: There is a type of stiff styrofoam ring that you can buy in sections to go around the bottom of the pools, but that will also result in collapse unless it is used for what it was developed, and that is a rigid wall pool.
F: Out of the three types of pools that Intex sell, the easy up with the air ring (the worst), the steel supported all the way around (next worse). and the rigid side, only the rigid side is forgiving to a tiny degree where unlevel ground is concerned.
For your size of pool everything must be exact and completely level or at one point it will collapse. There is little more discouraging than seeing all those gallons of water run out onto the grass. Once the water goes over the edge, no amount of people can prevent the collapse.
Finally I have learned that, with above ground pools, you get exactly what you pay for. My 5th above ground Intex pool was the best, but even with the ring around the edge at the bottom and the rigid side, I was still wasting my money unless the ground was aboslutely level. You just have to cut away the dirt until the level shows no angle.
I wish you all the luck. If you feel a desire, I have 5 Intex pools in my barn I will give to you if you pay the freight. Each was a dissapointment and a waste of time, energy, and above all, money.
I finally spent about $750 on one, had a professional crew level the ground, and it stays up through the winters even.
Posted on May 25, 2009
  • 93 Answers
SOURCE: INTEX EASY SET SWIMMING POOL
INTEXCORP.COM /EASY SET IF IT IS SOFT TYPE BLOW UP TOP RING FILL WITH WATER
Posted on Jun 19, 2009
lonewolf1996
  • 142 Answers
SOURCE: Intex Easy Set 530 Gallon swimming pool filter
You will need to go to the manufacturing web site and get a new seal for the pump.They cost some where around $1.00 to $2.00.
Posted on Jul 03, 2009
  • 297 Answers
SOURCE: I JUST SET UP MY INTEX SALT WATER SYSTEM A
It is possible that you do not have enough
even after disolving the salt by siring it up you need to run the filter for at least 24 hours to really disolve and mix your salt
even though you cant see it it is still not equally distributed through the water
once you have run the system for 24 hours check your salt content
It should be as close to 3000ppm as possible
a test kit will cost about 11 dollars for ten tests
Posted on Jul 22, 2009
SOURCE: need instruction manual to set up my pump for intex easy set up
The correct website is intexstore.com
on the right side, about half way down the page there is a blue box that says instructional set up video and manuals. You then click on pumps and on your model, and you can open it there.
Posted on Aug 24, 2009
Mi numero de seguro Social es de 1963 donde lo encuentro
Si es del gobierno de los estados unidos, la oficina de Social Security puede encontrar lo para ti, y ver si puede tener un pension. Toll free telefeno:
toll-free number, 1-800-772-1213, entre 7 a.m. y 7 p.m., Monday-Friday.
Se es de otro pais, como Espana, yo no se donde estan las officinas.
Jun 28, 2018 | Computers & Internet
Mi projector es un zenith 881 pro y mi problema es ... , se me tiro el liquido de uno las pantallas y no se como en contraro ni onde buscarlo y tambien una de las pantallas que es la del medio el que manda...
bueno creo me puedan ayudar es un projector muy viejito pero muy bueno donde puedo encontrar la tarjeta de convergencia, el tubo verde de enmedio crt, y el power supplay de un zennith 881 espero me entiendan lo que busco soy de Mazatlan Sinalo es te es mi correo danitza1420@hotmail.com gracias........
Aug 13, 2011 | Zenith Pro 881 Multimedia Projector
Por Favor me gustaria que me respondierais a la mayor brevedad posible y en español. Mi lg pdp42,estaba funcionando perfectamente y de pronto se escuchó un ruido,como cuando se va la luz,como si...
Podrias proporcionar el modelo completo de tu plasma?
Cuando proporciones el modelo te indicare donde esta la falla y tambien donde comprar la parte(s) para reparar tu TV.
Sep 12, 2010 | Televison & Video
Como puedo saber si el sensor de oxigeno de mi gmc sierra98 no sirve o como puedo detectar el problema ( por ejemplo: se apaga o pierde fuerza el motor o la transmision o como puedo detectar el problema...
hola me llamo alvaro me gustaria que me si me pueden alludar a encontrar el sensor de oxigeno #2 de una gmc sierra 2000 porfavor espero su respuesta con su alluda muchas gracias
Aug 26, 2010 | 1997 GMC Sierra
Mitsubishi ws-48311
DEPENDE DEL TAMANO O SI LA QIERES NUEVA ODE SEGUNDA MANDO EN REALIDAD SE VA AVER IGUAL TIENE 3 HOJAS LA PRIMERA SE LLAMA PROTECTOR SCREEN ,LA SEGUNDA SE LLAMA LENTICULAR; Y LA TERCERA ES EL LENTE BUSCALA EN VANCE BALDWIN.COM O MATS ELECTRONICS DEPENDE DONDE VIVAS USADAS LAS TRES VALEN COMO 150 O 200 NUEVAS COMO 500 LAS TRES
Oct 20, 2008 | Mitsubishi WS-48311 48" Rear Projection...
Donde encontrar mapas ruteables de colombia gratis
amigos.. yo los tengo y se los regalo... los de colombia totalmente ruteables... jhor113@hotmail.com
Oct 08, 2008 | Garmin nuvi 200W GPS Receiver
Ayuda para desbloquear
buenas tardes tengo un tv modelo HTV-2115 y tiene un candado rojo en la esquina inferior izquierda el canal no lo deja de mostrar y donde deberia tener la hora aparecen las rayitas no me deja usar el control sino para apagarlo y de los botones laterales solo lo puedo apagar como puedo desbloquearlo sino me da acceso al menu ni con el control ni con el menu lateral. darme respuesta al messnger viittoria1997@hotmail.com Gracias es de Venezuela
May 24, 2008 | Televison & Video
Intex Easy Set Pool 15x36 Logo
99 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
