Question about Kenmore 63942 Dryer
Kenmore dryer won't start
Where is the thermal fuse and how do i get to it
    Genius:
  • 1,073 Answers
There are 2 thermal fuses one is on the blower housing, it is white in color with 2 blue wires connected to it the other one is on the heater housing at the top it has red wires connected to it
if you need further help let me know
Posted on Apr 26, 2008
If thermal fuse is bad, most dryers will not run. If it is bad, dryer has overheated for some reason. Check venting to be sure it is clear and be sure heating element has not grounded out.
Aug 29, 2017 | Kenmore Dryers
Kenmore HE5 dryer won't start
Several different problems could prevent your dryer from running. Make sure that the door is firmly closed and hold down the start button for a couple of seconds to start the dryer. If you hear a click from the control board then the door switch and the control board are likely okay. You could have a blown thermal fuse or a broken belt in the dryer. To check these components,unplug the dryer and remove the bottom front service panel as shown in the first image below. With this panel removed, you can tell whether the drive belt is broken. If the drive belt is okay, I recommend checking the thermal fuse. This fuse is located on the blower housing as shown in the second image below. It will have light blue wires attached. To test the fuse, remove one wire and measure the resistance across the leads of the fuse with a volt/ohm meter. You should measure near zero ohms of resistance (continuity). If you measure infinite resistance, then the fuse is blown and will need to be replaced. You can verify that this is your failure by taping the contacts of the light blue wires together with electrical tape to "bypass" the thermal fuse. Reassemble the dryer and see if the motor runs with this fuse bypassed. If it does, then this verifies that the blown thermal fuse prevented the dryer from running and that this was the only failure. NOTE: Do not continue to run the dryer beyond this brief test with the thermal fuse bypassed. This component must be replaced. It is an important safety feature of the dryer.
You can order a new thermal fuse from the Sears PartsDirect website. The part number is 3392519.
May 01, 2012 | Kenmore HE5 Electric Dryer
Our 8 year old kenmore dryer won't do anything when you press the start button. We don't hear even a hum. It worked one day and then just wouldn't start the next day. We checked the fuse box...
Here is a good link for basic troubleshooting... But 10 to one the culprit is a thermal fuse or thermal cut off.... they are usually pretty cheap and easy to replace....
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
One final note on these: if you find your thermal fuse\cut off (or element) open, before replacing it, be sure to check the airflow out your dryer's vent system. Even though these devices do 'wear out' with age, poor airflow's the #1 cause of failure of these devices, and if your vent's partially clogged, a new thermal won't last very long, but will do its job again, and leave you 'cold' (a new element won't last long if the vent's clogged, either).
More info and pics:
http://www.davesrepair.com/DIYhelp/DIYthermalfuses.htm
Jun 16, 2011 | Kenmore Dryers
Amana dryer model YNED7200TW will not start. there is power, but start button does nothing. Resetting breaker did not work. Any ideas?
Thermal Fuse
Item #2986 (OEM Part)
$10.70
Thermal fuse. If the dryer overheats, this device stops the flow of electricity to the heat source and/or the entire dryer. It is located on the blower housing and cannot be reset. The most common cause for overheating is a vent tube clogged with lint, a birds nest or other debris.
Manufacturer Number 3392519
More
  • Admiral Dryer Thermal Fuse
  • Amana Dryer Thermal Fuse
  • Crosley Dryer Thermal Fuse
  • Estate Dryer Thermal Fuse
  • Kenmore Dryer Thermal Fuse
  • Kenmore Refrigerator Thermal Fuse
  • Kenmore Washer/Dryer Combo Thermal Fuse
  • KitchenAid Dryer Thermal Fuse
  • KitchenAid Washer/Dryer Combo Thermal Fuse
  • Magic Chef Dryer Thermal Fuse
  • Maytag Dryer Thermal Fuse
  • Roper Dryer Thermal Fuse
  • Roper Washer/Dryer Combo Thermal Fuse
  • Whirlpool Dryer Thermal Fuse
  • Whirlpool Washer/Dryer Combo Thermal Fuse
In Stock
Quantity: http://www.repairclinic.com/PartDetail/Thermal-Fuse/3392519/2986#repairHelpVideoTabs
Jun 08, 2011 | Amana Dryers
Have a Kenmore Model 80 Electric home clothes dryer and it won't start and light won't turn on. It is about 8yrs old. Checked breaker and still no power. Is it likely thermal fuse? If yes, where/what is...
Yes that would definitely be a thermal fuse problem. Take the rear panel off your dryer and look down at the lower left where the blower housing assembly is there will be a white rectangle looking thermostat with 2 blue wires going to it that is your thermal fuse. Unplug the 2 blue wires and then you will have to remove the screw which will be a phillips head or 1/4 bolt then the thermal fuse will slide out you need the model number off the dryer which is located on the top left of the dryer behind the door take that to your local appliance parts store which they carry that in stock and just replace using the same steps above.
Jan 04, 2011 | Kenmore Dryers
Kenmore elite oasis dryer model #110.6708
about $10.00 for the thermal fuse and 1 Hr Labor (my rate is $30.00 per hour) and a service call,rate depending on where you live
Mar 19, 2010 | Kenmore Elite Oasis 6809 Electric Dryer
Fuses
We have Kenmore Elec Dryer - Model # 8860293, 70 Series. Where is the thermal fuse located? Dryer starts and shuts off in less than 5 seconds.
lantzer@hotmail.com
Mar 08, 2008 | Kenmore 63942 Dryer
Kenmore 63942 Dryer Logo
59 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
