Question about Candy CPCA240FFK Bottom Freezer Refrigerator
My candy ka lasse frige freezes - Candy CPCA240FFK Bottom Freezer Refrigerator
Freezing on candy crush rewards level277
Click on this link and watch the video: https://care.king.com/en/candy-crush-saga/how-do-i-pass-level-277-on-candy-crush-saga
How do pass level 277 on Candy Crush Saga Questions King Care
Jul 02, 2015 | Tablets & eReaders
FRS26R4CB0-Freezer not freezing and Fridge not getting Cool
Hi Candi,
I don't know this model but most friges are the same,
Check on the bottom back, there should be a radiator with a small fan
installed.
If the fan is not working this maybe your problem,
It is not colling the gas.
You also may have a gas leak or the gas compressor is not working
or starting to work because of a faulty capcacitor.
Jan 11, 2014 | Frigidaire FRS26R4C Side by Side...
Whirlpool frige e 220 elite
AJAY SAHIB.ye spares counter me milega ok.good luck.ali
Jul 09, 2012 | Refrigerators
Candy fridge ka lasse , fridge is freezing food inside
lower the temp in the fridge. a dial with numbers or range
don't touch the interior walls with the food
Apr 21, 2012 | Refrigerators
Frige freezing solid
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Jul 03, 2009 | Samsung RB2155 Bottom Freezer Refrigerator
I have a frige that won't freeze. fridge side won't get cold
This seems to be a common problem with these refrigerators. I had the same problem a while back. Sounds like your defrost board is dead. part number is 12002104. You can find it at searspartsdirect.com
Jun 27, 2009 | Maytag MZD2766GES Side by Side...
Fridge freezes contents
Check the door seal is not split,it may be letting air into the compartment
Nov 12, 2008 | Candy CPCA240FFK Bottom Freezer...
Water pressure
If you have a water filter, the filter might be too old and plugged. If you've replaced the filter or don't have one, I would check the water supply to the frige. You might have a kinked line. Also if you used a self piercing saddle valve on your plumbing supply it may be blocked. You would need to turn the water off to the house and replace it with a saddle valve that would require you to drill a hole in the water supply line. Also most friges have a tank in the frige to keep the water cold. If the frige is too cold it could freeze the tank. The average frige temp should be 35-36 deg.
Jul 18, 2008 | Kenmore 53642 / 53644 Side by Side...
I have a drill like noise coming from my Candy frige or freezer
The only things I can think of that would make a noise like this would be an icemaker cycling or a damper motor opening or closing.
Nov 11, 2007 | Freezers
Candy CPCA240FFK Bottom Freezer Refrigerator Logo
783 people viewed this question
Top Candy Refrigerators Experts
Charles T Nevin
Charles T Nevin
Cesar Quant
Cesar Quant
Are you a Candy Refrigerator Expert? Answer questions, earn points and help others
