Every time my HP Photosmart C3180 is switched on it prints out a print cartridge alignment sheet and unfortunately I have to switch the printer on and off all the time I am using my word processor as the typing alternates with printing the finished sheets. (My processor is Papyrus, german software, but much preferred to Word. If I leave the printer on it grabs control of the mouse so that I can't use it with the word processor). I have at the moment a pile of five unwanted test alignment sheets beside me from my recent hour's work which, with the waste of ink and paper, as well as the time it takes to print these test sheets, is very annoying. I am contacting you because there must be some way to switch this test alignment print-out function off so that it only prints a new alignment sheet when a new cartridge is fitted and not every single time it is switched on. I am using genuine black HP print cartridges, number 338. Hope you can help. Norma Wrangham e-mail address: normawrangham@msn.com
  • norma1 Apr 26, 2008
    Many thanks. I tried cleaning the ink heads with the printer tool box software and, guess what! It then stopped doing the annoying test sheets before each printing! Maybe the problem was no more than the last cartridge wasn't fully settled in the cradle, though working, and the printer thought it was new each time. If so, the cleaning must have settled it fully in. I have noted your advice in case of trouble in the future, but for now, thanks again - problem solved! Norma.
    Glad to rate you, can't find where to do it! Clicking on 'how do we rank' page coloured damonds has no effect. No effect either from clicking on the empty balloons on the query and profile page. Where is it done on the website?
    Genius:
  • 3,587 Answers
Hmmm..this is unusual...perhaps it's a settings issue
Posted on Apr 26, 2008
  • 3 more comments
  • Patrick Michaels
    Patrick Michaels Apr 26, 2008
  • Patrick Michaels
    this looks like the answer to your issue.
    Step three: Align the new print cartridge
    When a new print cartridge is installed, the prints a print
    cartridge alignment sheet. This may take a few minutes.
    If the print cartridge alignment does not start automatically, complete the following steps:
    1. Make sure the printer is turned on.
    2. Verify that there is a plain paper loaded in the input tray.
    3. After the alignment page is printed, lift the lid of the product.
    4. Place the alignment page face down on the glass. Align the upper right corner of the page in the
      right front corner of the glass.
      Figure 6: Place the alignment page face down
    5. Close the lid.
    6. Press the
      Start Scan
      button. The
      Power
      button light blinks during the alignment process.
      After the
      Power
      button light stops blinking, the alignment is complete.
  • Patrick Michaels
    good for you..would you please rate this then?
  • Patrick Michaels
    you'll note that the first comment addresses this ssue precisely..thankya for using fixya
  • Patrick Michaels
Bought used Photosmart C3180 printer. Need to know how to insertcartridges. Thanks
for this particular printer, there are two slots, one with a green triangle and another with 2 different shapes. The left one is for colour and the right for black ink.
First you want to pull the desired cartridge out by putting a finger on both top and bottom and it should literally slide out (if it doesn't first time lift it up slightly first). Save the cartridge for future refill and the cartridge you want to put in you hold the same way and again from the bottom just literally slide it in. You should be able to click it in once it is all the way - this indicates it is in correctly, the printer should now run a test print
May 24, 2011 | HP Photosmart C3180 All-In-One InkJet...
Every time i turn my printer on it goes through what i think is a diagnostic print out. This totally wastes ink and paper. also it no longer shows the enlargre or shrink mode. Oh wait let me guess you...
Here is a NO CHARGE manual on troubleshooting:
http://h10032.www1.hp.com/ctg/Manual/c00694908.pdf
This is a copy direct from the manual above:
If you installed a new print cartridge, the HP All-in-One prints a print cartridge
alignment sheet.Note
If you have colored paper loaded in the input tray when you align
the print cartridges, the alignment will fail. Load unused plain white paper
into the input tray, and then try the alignment again.
If the alignment fails again, you might have a defective sensor or print
cartridge. Contact HP Support. Go to
www.hp.com/support. If prompted,
choose your country/region, and then click
Contact HP for information on
calling for technical support.
FIXYA never charges unless you select premium service.
Good luck
Thanks
Please rate FIXYA if this helps
Apr 14, 2011 | HP Photosmart C3180 All-In-One InkJet...
The HP Photosmart c3180 prints a color test sheet every time I turn it on even if only to scan a document. How do I prevent it from doing this?
1. Turn on the HP all-in-one.
2. Disconnect the USB cable from the all-in-one.
3. Press the sequence of front panel buttons below to initiate the print cartridge alignment process. The button-press sequence must be completed within ten seconds. It might take several tries to complete the sequence within ten seconds.
a. Press and hold Cancel.
b. While holding Cancel, press On.
c. When the Check Paper and Check Print Cartridge lights begin to blink simultaneously, release both buttons.
d. Press Cancel again.
e. Press Copies.
f. Press Paper Type.
g. Press Color Start Copy.
h. The alignment page will begin printing. If the alignment page does not print, repeat the button-press sequence in this step.
4. Once the alignment page is printed, place the page face down on the scanner glass and press Scan. The alignment is complete when the On light stops blinking. 5. Reconnect the USB cable.
Mar 15, 2010 | HP Photosmart C3180 All-In-One InkJet...
How can I stop my printer automatically printing out a test page when I switch it on?
every time u switch on the printer it will print the alignment sheet until you scan it.once the alignment sheet is printed ,keep it in the scanner glass and press the scan button.this will scan the alignment sheet.
Sep 24, 2009 | HP Photosmart C5180 All-In-One InkJet...
Alignment page prints each time
You must replace both cartridges with new ones to get a sucessful alignment.
Jan 09, 2009 | HP Photosmart C3180 All-In-One InkJet...
Cartridge alignment function repeats
you must replace both ink cartridges to get a sucessful alignment.
Jan 02, 2009 | HP Photosmart C3180 All-In-One InkJet...
HP Photosmart D7360
try to align the print cartridge. go to settings -> tools then choose align printer. you may also try to clean the print head.
Nov 01, 2008 | HP Photosmart C3180 All-In-One InkJet...
129 people viewed this question
jasbo
jasbo
