Question about Zodiac Baracuda G3 Automatic In Ground Pool Cleaner
Intermittent suction of my baracuda pool cleaner
  • 640 Answers
If your pool cleaner is losing suction, there are several things that you need to check. Check the diaphragm for damage. Make sure that you don't have air leaking into the cleaner. Check all of the returns, hose, and connections for cracks or improper connections. Make sure that the filter is backwashed and that there are no obstructions in the filter basket.
Posted on Apr 13, 2011
3 Suggested Answers
jharwell668
  • 640 Answers
SOURCE: no suction on my baracuda
There are several things that you will want to try if you are not getting adequate suction on these pool cleaners. First and foremost, make sure that you are getting proper water flow to the cleaner. If you are not, the cleaner will not move until the water flow is increased. Clean your baskets and your filter and make sure that they are clear of debris and blockages. Also, make sure that you do not have any leaks in your hoses and connections. Any leakage of air will cause the cleaner not to move correctly.
Posted on Mar 30, 2011
  • 10 Answers
SOURCE: Zodiac Baracuda Zippy Pool Cleaner hose tear
I haven't seen any bulletins on the Zippy hoses. You might adjust the flow to the cleaner. You can find the Manual for the zippy cleaner on this page beneith the diagram. It shows how the star control works. You can also contact the Mfg Technical Support at Phone: 800-822-7933 They might be able to warranty a hose or two for you.
Posted on Nov 05, 2009
Barracuda G3 manual
http://www.zodiacpoolsystems.com/Products/Cleaners/Suction/Zodiac-G3.aspx
Bottom of the page labeled downloads
Apr 08, 2013 | Zodiac Baracuda Zippy Pool Cleaner
Baracuda G3
Check your pool cleaners hose to make sure that it is not becoming tangled. Storing the hose in a coiled position will cause this. If it is not moving and it is not the hose, you could have a leak in a connection somewhere. If the cleaner is getting adequate suction, it should be moving. Try adjust the hose weights to make sure the cleaner is at a 45 degree angle to the pools floor.
Jul 06, 2010 | Zodiac Baracuda G3 Automatic In Ground...
My baracuda G3 stop working is not pulsating and therefore not moving. I checked the suction and the hoses even the diaphram everything looks ok.
If you have suction at the bottom of the cleaner, there has to be a problem with the diaphragm. I would remove it and recheck.
Feb 01, 2010 | Zodiac Baracuda G3 Automatic In Ground...
Get stuck in the pool corner
try adding a hose length or taking one piece off. Also you can try increasing or decreasing the suction.
Jan 15, 2010 | Zodiac Baracuda G4 Automatic Pool Cleaner...
Changed the fin on the baracuda, but it still does not move around the pool, can fill the suction if I lift it up, but it does not move.
If you have good suction at the head you may have a bad diaprham or something stuck in it. If you have suction but it is weak check for cracks in hoses or you may have a clog in your pump impeller.
Oct 30, 2009 | Zodiac Baracuda G4 Automatic Pool Cleaner...
The zodiac G4 pool cleaner has slowed down considerably and now gets stuck on the drain so i have to continually drag it off so it will circle the rest of the pool
Your Zodiac should ballence all suction with the skimmer and no suction should go through the main drain. A main drain is better called a deep suction to collect heavy dird and your cleaner is a roveing suction and replaces the drain. If both are on the two suctions pulling against each other will always stop the cleaner.
Oct 03, 2009 | Zodiac Baracuda G4 Automatic Pool Cleaner...
Zodiac Baracuda G3 Automatic In Ground Pool Cleaner Logo
789 people viewed this question
Top Zodiac Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Jay Finke
Jay Finke
Are you a Zodiac Pool and Spa Expert? Answer questions, earn points and help others
