I have a magnovox model# mwc13d6x7ma tv/dvd unit plsys cd's o.k. , dvd's display a on-screen message:disc error, please eject the disc,playback feature may not be available on this disc. please advice,George
    President:
  • 1,961 Answers
The first step you need to do is to manually clean the lens of the player to do this you need to open the cover of your player.You will see the mechanism of the player and the lens is place at the center of it.Use a cotton buds dip into a little amount of quick drying alcohol and wipe the lens gently..repeat it 2 or 3 times.next step,you can also try to adjust the lens focus there are two adjustable pot under the lens just at the base of the lens using a plastic jewelry screw carefully adjust the lens clockwise or counter clockwise gradually in a very little amount of adjust untill you get the lens read the dvd disk.test the DVD after every little adjust of the pot.
Note! there are 2 adjustable pot there 1 is for the CD disk the 2nd is for the DVD.The last we can do is to replace the lens with a new one you can order a replacement in an electronics shop/supply just bring with you the sample or the part no.it is printed on the lens..thanks and good luck!shoul you have any questions pls post a comment.
Posted on Aug 05, 2010
Marantz Model DV6600 DVD rewind is indicated on screen but will not play. Simply throws up message for all DVDs and CDs - "Disc Error. Please eject the disc. Playback feature may not be...
Usually means the lens needs cleaning. Occasionally, it's a case of the drive binding. Try running a lens cleaner through it first. You'll want the type that's got optical quality brushes built in to the bottom of the disk.
If that doesn't fix it, it's likely a drive issue, which means it's time for replacing the unit - costs more to fix than replace.
Jul 05, 2011 | Marantz DV6600 DVD Player
DVD player won't read disc anymore
i had the same problem.
is the player done? or is there a fix?
Mar 02, 2010 | Denon DVD-1740 DVD Player
Won't play dvd's
Try buying a Laser Lens Cleaner Disc from Wal-Mart, FYE music store, or any other place that might sell DVD players. Your Laser Lens that reads the DVD'S is full of dust. Try using the laser lens cleaner disc i mentioned to clean the laser lens.
Aug 12, 2009 | Philips Magnavox DVD/VCR Dual Player
Dvd player wont play
I found this on the PROSCAN website under customer support manuals.The website is www.oncorpus.com.I hope this information helps you with your problem. IMPORTANT THE LABEL SIDE OF THE DVD MUST FACE THE BACK SIDE OF THE TELEVISION 1. Press the ‘INPUT’ button to select ‘DVD’ mode, if no disc is inserted yet, the display shows ‘No Disc’.
2.Insert a DVD with the printed side facing towards the rear of the TV/DVD Player (see below)
3.The TV will first display ‘Loading’, then change to ‘DVD-video’. Most DVDs will show some preliminary
information then stop at a main menu screen.
4. Press PLAY/PAUSE to play it directly. Or press the DVD-MENU button to access the disc menu during
playback.
5.Use the direction button on the remote control to select the desired option. Press ENTER to select the
option or press the ► button. Playback will now commence.
6.After playback, press the EJECT button on remote control or EJECT button on TV/DVD to remove the
disc.
Note: No function‘’ will sometimes appear on the screen after a button is pressed. This indicates that the
function is not supported at the current time.
Feb 14, 2009 | Proscan 32LA30Q Television
ERROR MESSAGE:
If these disks have not been finialized then they will not play on the dvd player. Turn your computer on and see if they will play. If they will then you will need to the dvd palyer finialize them. I hope this helps you. If not get back to me and then we can try a different way.
Aug 15, 2008 | Hitachi 168589 DVD Player/VCR
SRD4900 Sylvania DVD/VCR Combo
Well first of all, why the hell would you press play when there was nothing in it???
Feb 01, 2008 | Durabrand DUR7 Portable DVD Player
DVD playback problems
Did you buy these DVD's out of the country? Are they burned? did you pick English and the United States of America when you set up the dvd player? Try unplugging the player for an hour, plugging in and resetting everything up
Jun 03, 2007 | Zenith DVT216 System
Televison & Video Logo
88 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
