Question about Ricoh Computers & Internet
Hi i have a computer using in NORITSU QSS lab..now when we started it its boots and after 30 or 40 sec the monitor only goes down ..like it shows there is no analog and digital signal... i have changed the signal cable,monitor..etc.still same. the problem is there is no seprate motherboard cd with the computer,only the recovery cd with the compete software pack...of the noritsu... please help
  • reachsreeju Aug 05, 2010
    thanks azraelsri
    ...4 the quik reply...i already checkd wth reinstalling...but after few days same is hapeninig....i have any dougt ..there will be any problem with ..motherboard..?.pls help
  • Ricoh Master
  • 11,800 Answers
Massive corruption in the OS. Reinstall using the recovery cd.
Posted on Aug 05, 2010
  • Azrael SRL Aug 05, 2010
    No. Either you get reinfected very quickly or your hard disk is dying.
    To check for infections use a better antivirus - one like Avast.
    To check the hard disk use  http://www.hdtune.com/files/hdtune_255.e...
    Both are free for home use.
My Kipor KDE16STA3 shows p03 error after 15 min runing and shuts down after 3 sec.The voltage drops to 30,40 whta's happening?
[PDF]DIESEL GENERATING SET
www.kipor.com/upload/spec2011053011590766.pdf
3/KDE16STA3/ ..... P-03 Undervoltage: Indicating voltage higher (lower), the generator will self- braking. P-04 Generator ... KDE16STA3 KDE19STA KDE19STA3.
[PDF]2
www.kipor.com/upload/spec2011061109073968.pdf
P-03. Decrease load less than the related load, turn on the breaker. P-04. Replace the fuse of the same type. Check the circuit and inserter. Replace the starting ...
Oct 31, 2015 | Kipor Electrical Supplies
I have a Sceptre X7G-Naga VI 17 inch LCD Monitor When I turn the monitor on and boot the computer I get the red light for a sec then the blue light comes on I will also see windows booting up but the...
try with restarting computer & press F8 at the same time. u will see a menu where choose "safe mode" & start the computer. in safe mode see the display properties, set the refresh rate & resolution according to monitors specifications, apply & restart again. if that does not work, replace the main board of lcd monitor.
Aug 25, 2011 | Sceptre 17" LCD Monitor
Aug 25, 2011 | Sceptre X20G-Naga II 20.1" Flat Panel LCD...
When I switch on my computer, Windows XP start loading and then my Samsung Samtron 45Bn monitor's screen goes blank and the green light keeps flashing every 0.5 secs.
It sounds like your video is set to the wrong resolution. Try booting into safe mode by pressing F12 at the start of the boot process. If you get into windows that way, then adjust the display to something you monitor can display like 1024x728@32bits. The monitor can only display a certain amount of pixels and if you set the video card to high you will lose visual. Hope this helps.
Mar 19, 2011 | SAMTRON 55V 15" CRT Monitor
Whenever I am trying to boot my desktop....it is going to hibernation...I have checked the monitor, which is working good
press F11 on start and see if it wants to boot in safe mode.. ..if you manage to boot it ..it means that it is just a setting from the video card made wrong ..and I suggest to reinstall the video card ..
If it do not boot atall ..and just beeps a sec and shuts down ..open it and see if the CPU cooler is spinning ...and also check the Ram memory ...If you have more than one units for ram ...remove them one by one ..and try to boot the computer with one at he time and see if any of them is damaged..
In case the ram memory is damaged..the computer will actually not boot at all ..and will not show the device check on start ...but just spins the hdd and clicks in a loop ..
If the computer shows the devices..but goes off when windows is trying to start it needs eiter the video driver to be reinstalled to correct any odd settings ..or the operation system is unable to start and this is cause by the hdd not being detected or a malfunction of the operation system ...In this case..check the HDD to work well ..or reinstall the OS..
Dec 24, 2010 | HP Compaq Presario SR1265CL-B...
Hi my computers screen is blinking it goes down for 2 secs and com back again from boot to startup but monitor is working fine on other computer
Make sure the plug from the monitor to computer is plugged in securely. Then, if the problem continues, replace it. It's on it's way out.
May 20, 2010 | Envision EN-985e Monitor
5 sec after starting windows the monitor goes to sleep itself.
go to safe mode.. change the power settings for windows...
to go to safemode.. simply restart your computer.. then press f8 several times til you see the boot menu.,.. select safe mode.. from there.. you should be able to boot windows.. change the power settings in control panel
Jul 09, 2009 | HP Compaq FP 7317 17" Flat Panel LCD...
Monitor goes black............
try checking the cables first.
May 28, 2009 | Dell E176FP 17" LCD Monitor
Blank screen with intermittent operation
you have bad capacitors in the power board inside the monitor replace these and the monitor will work fine
Dec 09, 2008 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
Acer AL2017 20 inch LCD Monitor comes on for 2 sec during start up then goes black. I 've had it for a year now. During start up it comes on 2 sec goes black then as the start up continues comes on 2 sec...
Hi
I repair monitors
Based on other models , it sounds like you are having a powerboard-inverter issue.
It just so happens that I hjust got one in that's doing that, I should know in a day or two (maybe sooner) what the whole story on this model is.
Good timing !!??
ebaysbammbammfran
Oct 14, 2008 | Acer AL2017 20" LCD Monitor
Computers & Internet Logo
264 people viewed this question
Top Ricoh Computers & Internet Experts
Chris Braid
Level 1 Expert
Marvin
Marvin
Are you a Ricoh Computer and Internet Expert? Answer questions, earn points and help others
