Question about Epson Stylus Pro 4800 InkJet Printer
Morning My Epson 4800 is giving me a Service Req. 1000180 error. All I can find is that it is a "CPU reserved command code exception" error. I can't find any documentation or write-ups on fixing it. Please could you explain to me what the error means, how it occured, and how do I go about fixing it, and IF possible, how to prevent it from happening again. Your assistance would well be appreciated. Thank you Paul
4 Suggested Answers
  • 33 Answers
SOURCE: epson 4800 pro
Make sure that the "Encoder Strip" is clean and in the channel for the sensor located on the back side of the printhead carriage.
Posted on Jan 09, 2009
jacklee366
  • 541 Answers
SOURCE: Turn the printer on and I get this message:
try this turn off the printer
then...
hold the power button and the pause button together, it enters factory rest mode
Posted on Mar 09, 2009
  • 47 Answers
SOURCE: epson error code 0104
00000104 Auto print head optimization system is all the manual says. No solution given.
Posted on May 15, 2009
Message is Service call error 00010014 I have an Epson Stylus pro 9800 and I am getting a message saying: Service call error 00010004 error 00010004 SERVICE CALL 00010004DescriptionFailure of ...
Epson Stylus Pro 4400/4800/4880 Error Codes
Maintenance Request Codes:
• 0002 - CR Motor near end of life - Replace carriage return motor ASAP
• 0006 - Battery shut off - Replace RTC back-up battery
• 0040 - Cleaning unit near end of life - Replace cleaning unit ASAP
• 0080 - Date not set - Set the date through the printer control panel
• 0088 - RTC backup battery not installed - Install RTCbackup battery
• 0100 - RTC backup battery pressure is temporally low - wait for a while
• 0200 - The number of ASF paper feeding has reached predetermined value
• Service Call Codes
• 00000101 - CR Motor reached end of life - Replace carriage return motor
• 00010000 - PF encoder check error
• 00010001 - PF motor is out of step
• 00010002 - PF motor overcurrent has occured - Replace PF motor
• 00010003 - PF motor out of postion time-out error
00010004 - CR encoder check error - ensure enoder strip is clean & dust free
• 00010005 - CR motor out of step - click here for more info
• 00010006 - CR motor over current
• 00010007 - CR motor out of position time-out error - Replace the board assembley, main
• 00010008 - Servo interupt watchdog time-out error - Replace the board assembley, main
• 0001000A - Carriage home position detection error
• 0001000C - PG home position detection error
• 0001000F - CR motor PWM output faulty
• 00010010 - PF motor PWM output faulty
• 00010012 - CR overload (high sensitivity) error
• 00010013 - PF overload (high sensitivity) error
• 0001001B - Head Driver (TG) temperature error
• 0001001D - CR servo parameter error
• 0001001E - PF servo parameter error
• 00010020 - CSIC reading/writing error
• 00010022 - Ink type error (setting on printer body side)
• 00010023 - RTC analyzing error
• 00010025 - SCIS ROM communication error
• 00010026 - RTC communication error - click here for more info
• 00010028 - Head error - replace print head
• 00010029 - Unidentified NMI
• 0001002A - CR ASIC ECU error - Reinstall/update firmware
• 0001002B - PF ASIC ECU error
• 0001002D - Cleaning unit has reached end of life - replace cleaning unit
• 0001002F - 360 DPI writing time-out error
• 00010030 - Multi sensor error
• 00010031 - ASF phase detection error
• 00010032 - ASF drive switch error
• 00010033 - Eject phase detection error
• 00010034 - Eject movement error
• 00010035 - Pump phase detection error
• 00010036 - Type-B board installation error
• 00010037 - Head thermistor error - Replace print head
• 00010038 - Transistor thermistor error - Replace board assembley, main
• 00010039 - PG adjustment value incorrect overwrite error
• 0001003A - PG adjustment value outside range error
• 0001003B - Cutter installation error 1
• 0001003C - Cutter installation error 2
• 0001003D - Cutter installation error 3
• 00020000 - NVRAM error - Replace board assembley, main
• 00020002 - SDRAM error - Replace board assembley, main
• 00020003 - Boot program SUM error - click here for more info
• 00020009 - Flash memory SUM error
• 0002000A - Program load error
• 0002000B - The internal memory is insufficient
• 100000E0 - CPU address error (load)
• 10000100 - CPU address error (store)
• 10000180 - CPU reserved command code exception error
• 100001A0 - CPU slot undefined command exception error
• 100001C0 - The AC power is shut off
• 100005C0 - CPU DMA address error
• 10000xxx - CPU error
• 0003xxxx - Debug orode
• 0Dxxxxxx - An error code for debugging
• 0Exxxxxx - A time-lag of the RTC timer
Mar 24, 2018 | Epson Office Equipment & Supplies
What does error message 100001C0 mean?
100001C0
AC disruption (AC Power) (Unplug and wait 30 sec., then plug back in)
Thursday, 10 July 2008
Epson 4800 Error message - Service req. 100001C0
I was printing quite happily on my Epson 4800 one evening recently, but the next morning the automated nozzle check sent by Harvey Head Cleaner did not print and there were a couple of flashing red LEDs and the printer's LCD display was saying "Service req. 100001C0". What to do? I was about to set off for the day job so I just had to leave it flashing away as I had no idea what to do, but fear the worst...
I did a quick web search that evening and found very little, but a couple of posts seemed to think that turning off the printer was the solution.
I had a look at the Espon Field repair guide that I have and found the following in the error codes section:
100001C0
I have the printer plugged into a
power surge protector block so there should not have been any problems and no other equipment was saying that there had been a power outage, but...
So I turned off the printer and left it for a day while I got on with the day job again. When I turned on the printer there was a lot of whirring while it went through its "auto something or other" routine (see previous postings for my thoughts on this) which I watched with a lot of trepidation as this often converts a perfect nozzle check into one with one of more colours completely missing.
Eventually it told me to press pause and then went into it's "Ready" mode.
I ran a nozzle check and it came out perfectly, so all was well again.
May 27, 2014 | Epson 4880 Stylus Pro InkJet Printer
Print head error 00010028
i have epson 4880. but now printer showing service Req. 00010028. pl tell me how to solve this problem
Jan 26, 2010 | Epson Stylus Pro 4800 InkJet Printer
What means service 82 on aculaser cx11nf
Service Req C0082 CPU error (TLB miss exception [Load/Fetch]). Generally it is an envirnmental problem. Power the printer off and disconnect all cables. After one minute reconnect the power cable only and power on.
Then try a Starus Sheet, press the right arrow button 3 times. If the sheet prints then the problem may bea the network or corrupt documents been sent from the Netwrok or PC.
If the issue remains then you will need a new part so you will need ot contact Epson for further assistance.
Dec 21, 2009 | Epson ACULASER CX11NF All-In-One Printer
EPSON AcuLaser C1900 with Error "Service Req E020"
ERROR CODE: E020
“SECONDARY TRANSFER VOLTAGE CONTACT/RELEASE PROBLEM”
Solution
�� Electric parts which can cause the trouble:
• Transfer Roller Pressure Solenoid (SL2)
• Transfer Roller Pressure Position Detection Sensor (PC7)
• Engine Board (PWB-A)
May 18, 2009 | Epson AcuLaser C1900 Printer
Epson stylus pro10000 problem service reg
SERVICE REQ. 00020000:NVRAM ERROR
SERVICE REQ. 00020001:NVRAM COMPARISON ERROR
SERVICE REQ. 00020002:SDRAM ERROR
SERVICE REQ. 00020003:FLASH MEMORY ERROR
Problem
Abnormal detection in a corresponding element
Solution
1. Once save parameter to Flash memory card and install it to the printer again.
2. C362DRV board. replacement
Feb 18, 2009 | Epson Stylus Pro 10000 InkJet Printer
Epson 4800 pro
Jan 06, 2009 | Epson Stylus Pro 4800 InkJet Printer
Service Req C0302
CPU Error. Mainboard is faulty.
Jul 04, 2008 | Epson AcuLaser C1900 Printer
Epson Stylus Pro 4800 InkJet Printer Logo
52 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
