Question about MSI P4M900M-L Motherboard
Every time I on my PC it appears in screen unknown bios error. error code 8302 press f1 to resume
    President:
  • 635 Answers
You need to flash your bios before it becomes totally corrupted. You are losing small bits of information that your motherboard needs to continue functioning.
I have what i believe is the proper page for your bios, but your exact model doesn't show up when I search the site, so the best solution for your problem is the MSI live bios update located at the bottom of this webpage:
http://www.msi.com/index.php?func=downloaddetail&type=bios&maincat_no=1&prod_no=1150
Simply install that and allow it to automatically fix your bios for you.
Posted on Aug 05, 2010
Emachines pc unknown error code 8302-press f1 to continue
http://www.tomshardware.co.uk/forum/295726-30-bios-error-code-8302 READ IT.IT EXPLANES THE PROBLEM.
Apr 05, 2013 | E-Machines eMachines Desktop PC
Emachines pc unknown error code 8302 press f1 to continue
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Remove power from the PSU, then do >>Clear CMOS Guide<<
then leave one memory stick only in 1st DIMM close to CPU socket.
Then try to boot, if that can be done, enter in BIOS Setup and "Load BIOS Optimized Defaults" followed by save and exit.
Apr 05, 2013 | Computers & Internet
Bios error 8302
Hi, there could be a number of reason for this ..
1. Hardware problem
2. BIOS setting has changed, entering the bios can sort this.
3. Real time clock battery voltage has dropped too low therefore contents of BIOS not held when turned off, this can be sorted by replacing the CMOS battery
http://www.computerhope.com/issues/ch000239.htm
Please keep me updated.
Regards
Dec 21, 2012 | Acer AM3400U2502 PC Desktop
Hello, I went into my bios settings and did something wrong now when I start up my computer it takes me to the mi bios megatrend screen at the bottom of the screen says driver bad press f2 to resume f1...
go back into the BIOS by pressing F12 and look for the set BIOS to default values or something along those line. save those settings and reboot..
Please give feedback...
Dec 18, 2012 | Lenovo Computers & Internet
Iam at black screen that said F1 to resume i pressed and sendme to bios utility how can i go back to regular screen windows
What was the error-message just BEFORE that 'F1' message?
Turn the computer off, wait, and turn the computer on.
If you get into BIOS SETUP,
use the "arrow" keys (UP, DOWN, LEFT, RIGHT)
to highlight the 'Load BIOS defaults' menu-item.
Press ENTER to apply that option.
Use the arrow keys to select "Save and Exit from BIOS setup".
Press ENTER to apply.
Oct 24, 2010 | Computers & Internet
UnKnow Bios error Error Code =8302 Sr, Computer Opening No Display ....F1 Press Continue Display Ok
Hi, this can be caused by a BIOS update or a faulty motherboard battery. You can reset BIOS to default settings by pressing the F1 key during bootup, which will take you to the BIOS screen.
Aug 04, 2010 | MSI P4M900M-L Motherboard
Error code =8302
check your bios settings that the vid output is set to boot from the right device that you want it to be from. try reseting defaults
Feb 24, 2009 | MSI P4M900M-L Motherboard
Press f4 to resume
u need to go into bios setup.this can be done by pressing del button on ur keybadr while booting is goin on. some time the key to be pressed will be F10 or F1 instead of del key.
There will be an option as stop booting on error. disabl;e that..n it ll be fine.. btw to find out the error u'l have to specyfy each n every settings in ur bios.So its better u to ask for a person who knows these things to ur home.. Else u can do by exploruing these things urself.It ll be fun..i would prefer this..
Feb 12, 2009 | HP Pavilion dv2000t Notebook
Press (F1) to resume, (F10) to setup
I need a bit more info to try to give you an accurate solution
Does the screen change after you press "F1" ?
Do you have access to an external keyboard, if so try plugging that in while the computer is off and then using that to press "F1"
Nov 15, 2007 | Compaq Presario M2000 Notebook
MSI P4M900M-L Motherboard Logo
414 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
