Question about Yamaha Water Sport
I am trying to replace the impeller on my Yamaha 2CMH outboard and I can't get the impeller housing to slide off the drive shaft.
  • 11 Answers
SOURCE: pump seals
The impeller is threaded on to the shaft. The trick is to hold the shaft in order to untread the impeller. The surest method is to disassemble the back of the motor, exposing the opposite end of the shaft. There should be a spot to put a wrench in order to hold the shaft immobile. Then, it's simply a matter of unthreading the shaft. A strap wrench does a great job of holding the impeller without damaging it.
Posted on Jan 03, 2009
Fame_Guru
  • 483 Answers
SOURCE: Yamaha outboard motor manual
You got it :
http://www.yamaha-motor.com/outboard/service/viewmanuals/outboard_manuals.aspx
here !
Posted on Mar 20, 2009
  • 135 Answers
SOURCE: I have a 1979 Sears gamefisher 7.5 hp outboard
TRY TURNING THE FLYWHEEL TO HELP LINE UP THE SPLINES ...
OR PUT THE LOWER UNIT IN GEAR SO THAT WHEN YOU ROTATE THE PROPELLER THE SHAFT TURNS... THAT SHOULD HELP YOU LINE IT RIGHT UP
HOPE THIS HELPS
Posted on Aug 08, 2010
john224
  • 1378 Answers
SOURCE: I have a proline 1.5hp
Keep trying - It is stuck and will likely break but you have to remove it to change the seal. It is not uncommon to need to replace the impeller when the seal fails since the water gets behind the impeller shaft and rusts the metal causing the impeller to bind. If you still cannot get it free pull the motor thru-bolts and lock the rotor once removed from the motor in a vice. Use a large pair of channel locks to break the impeller free...replace it if necessary.
John
Posted on May 16, 2011
SOURCE: 2003 Toyota Camry drivers side power seat stuck
This is not necessary...as many have stated...use a hammer with switch in reverse position. Hammer the seat back...it will catch...
Posted on Aug 07, 2011
Just changed the impeller on my 2012 Yamaha 90hp outboard, but no water coming out of the tell tale. what could be wrong?
howd the pump drive shaft nib look when you replaced the old one ??? if it was worn round and not "D" shaped it wont drive the new pump
Aug 12, 2016 | Boating
Boat impeller
Undo gearbox bolts,take off trim tab,undo bolt in trim tab cavity,disconnect speedo tube,pull off gearbox. You will see pump housing,undo 4 bolts,pull off housing exposing impeller,there maybe a clip on top of impeller depending on model,pull off clip then impeller.yamaha didn't make outboards in 75
Aug 25, 2014 | Boating
Coleman outboard overheating
You should change your impeller.
It is located at the top of the gearbox, around the vertical engine shaft.
First, disconnect the gear control. Underneath the steering bracket, you'll see a long nut with a counternut. ( Maybe you'll have to shift FWD or BWD to get better access ). Loosen the counternut 1/4 turn and then turn the long nut up ( 2 open box wrenches 10mm ).
Then remove the 4 bolts holding from lower to upper the gearcase ( just above the anti-cavitation plate )
The gearbox should drop down easily.
Then remove the 4 screws of the waterpump ( top of gearcase, around the long vertical shaft ). Lift the waterpupp housing, you'll get the impeller.
To reassemble the waterpump, grease the cup in the housing with PTFE or silicone grease, and while pushing the housing down over the impeller, rotate the shaft clockwise.
Reassemble all the rest in reverse order.
Check and adjust the gear shifting...
Apr 01, 2014 | Coleman 9.9 HP Manual Start Outboard Motor...
1989 johnson 25 hp outboard water pump replacement ? shift linkage issues.
Line up the water pump housing with the drive splines and look straight down on it all -there will be a clearance cast in the pump housing some where. It's a matter of perspective. Or you have the wrong pump.
Jul 29, 2012 | Boating
1977 9.8 hp Mercury Outboard Motor Serrial # 4605112, it's an electric start with a short shaft
put it in forward gear. Drop the lower off by releasing the bolts and nuts holding it holding the lower on. (one is hiding under the back pick up screen)- some models had a plug in the back top of the exhaust/intermediate housing hiding an allen head bolt pointing down.
Once released, put a protector in a vise and clamp the lower to the bench.
2 screws or bolts will hold the water pump cover on. (the drive shaft runs thru it) Clean the carbon and rust off the drive shaft will allow the pump housing and impeller off the lower. Retrieve the funny looking key drive which runs the pump.
Inspect the shaft, the lower unit oil for water. and find all the pieces of the water pump impeller which may have gone places they shouldn't have.- including the outlet tube from the power head. Check this by putting a tube on the end and blowing- you should hear and feel the pressure in the exhaust and tell tale hole.
Now take the model number , the old pump parts to the marina for a replacement. Do a side by side comparison at the marina so you get the right stuff. Check the inside drive of the rubber impeller and see if they are exactly the same.
NOW- put the new wear plate / gaskets and drive key on, hold in place with grease. Slide the impeller on the key and spin the drive in both directions to be sure it has the impeller and will securely turn it.
Put grease in the cup of the pump housing to prevent dry start and help seat the impeller blades. Spin the shaft as you lower the housing in the pump so the blades all face in the right direction (clockwise). Screw in the bolts. Grease up the seal the watertube goes in and the spline end of the drive shaft.
Up the hole it all goes, now you only have to spline the shifter (it hasn't moved has it?) The drive shaft and the water tube all at the same time.
Check the shifter for correct position and bolt it down
Jul 28, 2012 | Mercury Mark 30 Hipo Outboard Motor...
Where and how do u get to the water pump it is a 1978 105 chrysler outboard do u have any diagrams? BOAT
all the outboards i have repaired require the removal of the lower gearbox to get to the water pump impeller ,it sits on top of the gearbox driven by the engine drive shaft in a little housing
May 29, 2011 | Car Audio & Video
1997 Evinrude 50 HP SPL. I have removed all the bolts holding the lower rnd to the engine, it seems to be hanging up on the shify shaft, and I can't find a way to drop the unit. It drops down about...
Okay this is on total memory. The shift shaft for a lot of those engines goes right up through the pilot shaft and exits just in front of the block under the carburetor(s). You will see the **** linkage arm connected to this shaft sometimes it's double nutted. See if you can slide the lower unit back up to the housing and put a bolt in it to hold then undue the shift shaft linkage, Remove the bolt and drop the lower unit. Be careful of the water tubes and check make sure the rubber grommets are in place in the pump housing not on the tubes. Clean up the pump housing and install the new impeller kit.
Put the impeller down the shaft on top of the impeller plate, lightly grease the inside of the housing the impeller plate and impeller. Then lower the pump housing down to the impeller while turning the drive shaft clockwise lightly push down on the impeller housing. This will fold the impeller blades all in the correct position and provide lubrication to the pump until the water gets into the pump. To make life easier re-grease the drive shaft spline and the water tube grommets this will ad ease in reinstalling the lower unit. be careful to make sure you thread the drive shaft, water tubes and shift shaft all in at the same time. After installation you may find you need to adjust the **** linkage.
Dec 11, 2010 | Boating
How do i replace a force 120 impellar pump?
Most impellers are in the leg and require the lower oart of the leg to be removed by disconnecting the gear linkage and undoing the bolts that hold the lower half of the leg on, they are just above the water intake.Don't forget the bolt near the prop. Wiggle the leg and slide it down to remove, then place the leg on the bench. The drive shaft protrudes through the impeller housing, remove the bolts that hold the housing on and slide it off. When fitting the new impeller be sure to fold the fins in the correct direction. When re installing the leg be careful to align the cooling pipes correctly.
Cheers, Timo.
Apr 16, 2010 | RTO Outboard Motor Bass Fishing Boat Rod...
Where is the water pump on a 1985 yamaha 25 horse?
In the leg, undo the gear link and undo the bolts that hold the lower half of the leg on, they are above the water intake pointing up, don't forget the bolt neat the prop. Wiggle the leg off and put it on the bench. The drive shaft protrudes from the center of the water pump housing, remove the bolts and slide the housing off. When you replace the impeller make sure the fins are folded in the correct direction to avoid pinching. Be sure to align the water cooling pipes when reassembling the leg.
Cheers, Timo
Apr 12, 2010 | Boating
Water Sport Logo
59 people viewed this question
Top Yamaha Water Sport Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Craig Butler
Craig Butler
Are you a Yamaha Water Sport Expert? Answer questions, earn points and help others
