Question about Kenmore 700 6972 Dryer
Kenmore 70 series clothes dryer. will come on then cut off, there is a burning smell before it cuts off.
  • Kenmore Master
  • 8,220 Answers
You should inspect for lintkenmore 70 series clothes dryer.  will come on - 57802a1.jpgfab1e75.jpgad69bd2.jpg9328776.jpgRemove lent from inside. Use HVAC quality Zoomspout oil45bc4a7.jpg to lube the rollers and idler0015e3d.jpg More here
Posted on Aug 05, 2010
2 Suggested Answers
  • 63 Answers
SOURCE: Kenmore 70 series electric dryer. Clothes are
most common reason for this would be clogged vent...check all the way in and out!
Posted on Mar 16, 2009
Kenmore 80 series electric dryer. metalic sound/burning smell
drum bearing on the rear has gone making the front of drum rub on the caseing re metalic sound
Aug 17, 2012 | Kenmore Dryers
Kenmore 70 series electric dryer not heating
You either have :
-A bad heating element
-A bad thermal cut-off
-Thermostat
OR
-A bad fuse.
May 12, 2012 | Kenmore Dryers
I have a Kenmore Series 70 Dryer and I changed the thermal fuse got hot for a few minutes the model #110.74722400
The cycling thermostat must also be replaced when replacing the thermal fuse. The cycling thermostat's failure to cycle off the heating element results in overheating of the dryer which consequently blows the thermal fuse open.
Replacing only the thermal fuse should the dryer stops running and fails to start will result in its premature blowing or even the thermal cut-out (cut-off) located on the heater duct. Like the cycling thermostat, the high-limit thermostat must also be replaced once the thermal cut-out blows open. Refer to the parts diagram in the link below and look for item numbers 31(thermal cut-off), 34(hi-limit thermostat), 39(thermal fuse), and 41(cycling thermostat.
Kenmore Series 70 Electric Dryer (110.74722400) Bulkhead Parts
Aug 21, 2011 | Dryers
When i put clothers in my dryer it does not move and it make a sound when i push the start buttom
Feb 24, 2010 | Kenmore Dryers
Kenmore Electric Dryer Series 80 Model
Disconnect the dryer from your vent completely,. pull dryer out 3 ft. from wall and test to see if the smell continues, You have to test for a few minutes to clear out any burning lint from vent restrictions. If the smell hoes away then you know you have venting problems. Also check on the grate that covers the element( the part you look through when you see the orange glow from the element) sometimes plastic or clothing burns onto this grate and needs to be cleaned off. I the smell remains, you will have to tear down the dryer to see if you can find the cause of the smell.
Sep 21, 2009 | Kenmore 62802 Electric Dryer
Fabric looking belt came out of dryer. when i try to dry clothes it makes a loud noise and smells like something is burning and my clothes get twisted. how do i fix it? I have a kenmore 70 series dryer
Stop using your dryer in its current condition. That fabric looking felt is probably your drum seal. They commonly wear out. I will need your dryer model number in order to confirm how your dryer is configured and give you accurate advice on part numbers and directions on how to replace. The model number should be listed on a name plate around the door opening.
Apr 22, 2009 | Kenmore 63942 Dryer
Kenmore 70 Series Dryer Model# 110.64742400
check the thermal fuse if it is blown also change the high limit thermal cut-off fuse www.repairclinic.com shows your parts. go there and enter model number. Also check the heat element. to get into it remove the lint filter and the two screws you'll see there then pry the top up at the front corners. And through the back you should find the heat element and blower housing and thermal fuse and high limit fuse and cycling thermostat.
Apr 06, 2009 | Kenmore 64742 Electric Dryer
Mar 16, 2009 | Dryers
Kenmore 70 Series
hello,
i have a kenmore series 70's gas dryer that will not heat up when it is turned on and i am now smelling gas when i do try to dry my clothing. it was working yesterday but now this is happening? please help.
thank you,
tina
Jan 05, 2008 | Kenmore 74602 Gas Dryer
Kenmore 700 6972 Dryer Logo
508 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
