Question about Ertl 580 Super M Series II Tractor
Case 580 m ac will come on blow cold then the light comes on and it stops blowing cold you can turn ac off for bout 1 min and turn it on it blow cold and kick off light on manual say light eather high preshur or low on 134
    Problem Solver:
  • 5 Answers
Take a garden hose or somthing with high water pressure and spray out all of radiators in the front of machine. This will clean out all the dust build up between all the rads and will cause your fan to cool the ac fluid as well as the others
Posted on Oct 10, 2010
2007 Toyota Yaris blowing cold air for 1 min then starts blowing hot/warm air
Vacuum leak most likely, thus not operating air blend door.
Jul 01, 2015 | AC Cars & Trucks
Air conditioner shudders, stops blowing cold, then resets every 5 mins
Cleaned the filter this AM and closed the door but now a red
light keeps flashing.
Jul 19, 2013 | Sharp Cv-p12lx 11500 Btu Portable Air...
Ac clutch relay 2001 lincoln ls location
drivers side next to the battery
Sep 11, 2012 | 2001 Lincoln LS
Car blows warm air when idling
It sounds like your AC unit could be overheating or even damaged.
AC units have a sensor that will turn them off automatically to prevent damage from overheating. If there is an insufficient amount of air flow, the unit will heat up, and then eventually turn off.
When the car is moving, more air is forced over the unit, likely keeping it cool enough to run, however, when the car come to a stop, it loses that air flow, and quickly heats up. Thus, the AC would work while the vehicle is in motion, and overheat and stop when the car is stopped and idling.
However, the AC unit could be completely blown. The cold air while moving could be just a case of air being forced into the car. Think of a house fan, the fast the wind blows on you, the cooler it gets.... Thus, it could be an illusion that the AC is working when car is in motion, when it really isn't.
Hope this helps.
Jun 09, 2012 | 2004 Lincoln LS
I have a 05 scion tc that the ac compressor will blow ice cold and after a few mins the compressor will kick off. If u turn the ac off for a few mins and turn it back on it will blow cold for a few mins...
may be a few things try checking the a/c lines when it does the shut off thing are they freezing up? may need a dryer. is the fan coming on at the radiator when the a/c comes on? it needs this to keep the head pressure down. does it drip water when the a/c is on under the car? may another sign its freezing up.
May 04, 2012 | 1953 AC 2 Litre
Driver side AC on 2003 Mercedes E500 does not blow cold air.
this problem is A/c system leaking.add enough freon R134A will solve the problem .but you must check where is leaking important.
Jun 22, 2009 | 2003 Mercedes-Benz E-Class
After approx 40 min of highway driving the AC stops blowing cold
The frosting of the line is normal. Did you use a gauge set when charging the unit? AND, most important, Did you evacuate the system before putting in the freon? Very important.What was your final low side reading and your final high side reading?
Jun 02, 2009 | 2003 Hyundai Santa Fe
2001 chevy blazer ac problems
freon level is low. add r134 refrigerant and your problem will be solved.
May 13, 2009 | 2001 Chevrolet Blazer
Ertl 580 Super M Series II Tractor Logo
246 people viewed this question
Top Ertl Toys Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Ron Knox
Ron Knox
Level 1 Expert
Are you an Ertl Toy Expert? Answer questions, earn points and help others
