Question about HP Compaq Presario V2000 Notebook
Compaq Presario V2000 Widescreen Laptop Computer
My laptop computer will not turn on...I have two laptops so I tried switching the batteries to see if that was the problem, and still nothing. I was so frustrated with it that one day about 2 weeks ago I decided to unscrew the back compartments and just see if anything looked out of place, of if it was dusty...After doing that and screwing everything back into place I tried to turn it on, and it worked! BUT, now it is doing the same thing, where it won't turn on again, and after unscrewing everything again, it is still not turning on...I have no idea what is going on, but I need this laptop to work because it has alot of important stuff on it...Can anyone help?
    Problem Solver:
  • 14 Answers
Solution #1 posted on Apr 28, 2008 Compaq Presario V2000 Widescreen Laptop Computer - 0%20stars.png
Compaq Presario V2000 Widescreen Laptop Computer - nonexpert_s.gif>
Rank:nonexpert_s.gif Apprentice
Rating: 78%, 2 votes
I have also had the same issue when my bios battery is loose or dead. The battery can be accessed from the memory area. Once you open it on the left should be memory and on the right will be the wifi card. You don't need to unplug the cables just remove the wifi card and examine the battery. The battery is held by a very very flimsy piece of platic and really easy to break. The best thing I have found is using a little piece of cardboard from a box or something and using it to keep the battery tight, just dont go shaking the laptop alot and it will hold it. It might also be possible your bios battery is dead.
From what I say I would hit power it would power for about 3 seconds the power light would flash then turn off.
Posted on Apr 28, 2008
    Scholar:
  • 87 Answers
Can't help you with repairing laptop but it's easy to save any important documents, pictures etc. Buy a hard drive 'caddy' -costs less than £10 on Ebay - must be a caddy only and not an external hard drive. Take the hard drive out of your broken laptop and put it in the caddy - connect this to your other laptop and it shows up as and external USB drive. Just copy the info you need to your laptop. No damage done to hard drive and it can if needs be just be put back into the non working one so you can mess about without risking losing everything.
Posted on Apr 27, 2008
How can i change the CMOS battery of my Laptop Compaq Presario V2000?
Here is the location of the appropriate Service Manual - you will have to partially disassemble your computer to reach the battery and replace it.
http://h10032.www1.hp.com/ctg/Manual/c00444244.pdf
Sep 19, 2012 | HP Compaq Presario 2200 Notebook
Compaq presario v2000 is dead!!!
Well oviously when you dropped it, it had done alot of damage. There is defenently something in there that needs replacement. I can't acctually see the inside of your laptop so i don't know what. Go see a computer pro.
Jun 09, 2009 | HP Compaq Presario V2000 Notebook
Compaq presario V2000 doesn't start
you might have shot out your battery because if electrical curent is goging in to the computer (te orange light is going on) but the computer wont turn on it might be a problem with your battey
please rate
May 30, 2009 | HP Compaq Presario V2000 Notebook
How do I remove the 6 cell battery for shipping it?
Hey,
In the bottom of the laptop, there is a slider, slide it to the other position to eject battery form the computer.
For example, another computer bottom, how to remove battery
1. pull the slider / lever
2. pull the battery out
Thanks and good luck.
Ekse
May 05, 2009 | HP Compaq Presario V2000 Notebook
Compaq Presario V2000 battery
if the computer will turn on with it plugged into ac power than it is most likely the battery. batteries on these machines are cheap. Mine died after a year
Jan 18, 2009 | HP Compaq Presario V2000 Notebook
It sounds like one of the most frequent failure for a laptop, the plug on the back of your laptop is probably broken. Check if it's loose, try to move the plug until you get the orange light. If it's the case, someone need to resolder/replace the plug on the motherboard.
Hope this helps! Let me know how it goes.
Alex
Nov 11, 2007 | HP Compaq Presario V2000 Notebook
AC charger for a presario v2000
use ebay, same thing but cheaper in prices... i got my presario v2000 ac power charger for 24.50 with shipping and handling.... took 3 days and it arrived unless u want to do overnight shipping which is like an extra 12 bucks which is good too... WELL WORTH IT EBAY IS THE PLACE... i think his name is "honestworks" or something like that buy it from him he has a one year warranty if any defects occur...
Oct 18, 2007 | HP Compaq Presario V2000 Notebook
Computer will not start
Disconnect battery and unplug from power, test for voltage on power cord and re-insert, hold down power switch. If nothing try battery without power cord. Still nothing (no lights, no sounds) then it may need system board replacing.
Sep 19, 2007 | HP Compaq Presario V2000 Notebook
HP Compaq Presario V2000 "Doesn't turn ON"
1) Unplug the laptop. 2) Press and hold down the standby switch under the lid in the upper left hand side of the laptop while pressing down the power key. You should have full power startup now. Let me know if it worked..
Jan 27, 2007 | HP Compaq Presario V2000 Notebook
HP Compaq Presario V2000 Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
