Question about Scientific Explorer My First Chemistry Kit
Solid to gas - Scientific Explorer My First Chemistry Kit
    Scholar:
  • 32 Answers
Hi, Udtohan_jona, what is your question??
Are you meaning to ask "What is happening when a solid changes into a gas in one single step?" If that is the case, solid to gas is the process called "sublimation." The atoms or molecules that are in the solid go directly from the crystalline state to the same particles in the gaseous state, but in the gaseous state, they are much farther apart.
Posted on Jan 10, 2011
Replaced the gas valve in my goodman furnace now it won't light and red status light stays solid
solid means it is on stand by, no call for heat, put jumper wire between r and w it should start, if it does check t- stat
Oct 27, 2015 | Goodman Heating & Cooling
What can cause a car to lose power
a Vacuum leak, poorly adjusted spark advance, bad gas, sticky choke, corroded plug wire connections, weak coil(s)...etc etc.
Jan 27, 2015 | Cars & Trucks
Example of a gas and a solid
Solid; cheese.
Gas; vapor.
May 28, 2014 | Cycling
Hobart handler 140 mig welder gas wont shut off
Looking at the Hobart manuals, that is how they set them up at the factory.
One way to make a change to that is to wire in a solid state relay or solid state Triac and pick up an energizing voltage off of location RC2-1 or RC2-2 on the control board when the trigger is pressed, or as an alternate location from the feed motor through a resistor and rectifier. Once you know if the voltage goes low, or voltage goes high at your point of signal, you pick the contact you want on the relay so when the wire is feeding out, the gas is flowing. and when it is not feeding wire out, the gas is shut off.
Dec 31, 2011 | Hobart Welding Tools
I have an SL100 - 10W La Germania table top oven (gas) I did not receive a operations manual with purchase of the oven and I do not understand its operation. Questions 1. How does it maintain the set...
I GOT THE SAME QUESTION .. IT IS A GAS OVEN . WHEN THERMOSTAT IS SET TO GAS MARK 4 WHICH IS EQUIVALENT TO 350 DEGREES , AFTER 10 MINUTES, IT REACHES ITS DESIRED TEMP. BUT IF I DON'T ADJUST THE FLAME, THE TEMP WILL RISE HIGHER AND HOTTER THAT I NEED TO OPEN THE OVEN DOOR TO DECREASE THE TEMPERATURE INSIDE. ANYONE KNOWS IF THAT IS NORMAL? THANKS12_1_2012_3_54_19_am.jpg
Oct 26, 2010 | Ovens
Goodman furnace model # GMNT100-4B On vacation, neighbor checked house, house filled with gas. He shut off main and furnace. came home turned on gas to everything except furnace. All good. Furnace will...
Solid red typically means bad controller. Try unplugging the furnace, wait about 30 secs, then plug it back in. The possibility that the controller was sending voltage to the valve even when there was no flame is a bad sign. If the controller starts the furnace, watch it very closely and see what it does. If the solid light comes back on, it's time for a new board.
Mar 24, 2010 | Goodman GMS90703BXA Heater
Check engine light came on yesterday. solid on.
take pos.battery cable loose from battery for 10 seconds and put it back, clears all computer codes, if it comes on again, go to auto zone for a free computer check, they will tell you what it is and how to fix it, hope this is some help to you,
Jul 10, 2009 | 2005 Chevrolet Impala
The amber colored engine symbal just came on
Check your gas cap, make sure it is properly tightened. This is the no 1 reason for a solid engine light. Other reasons for a solid light include dirty o2 sensor, dirty Mass Air Flow Sensor (both of which need to be replaced or professionally cleaned), clogged air filter or dirty spark plugs. If it isn't the gas cap, either get a code reader and check the code yourself or take it to a shop to have the code read.
Jun 06, 2009 | 2004 Dodge Caravan
Scientific Explorer My First Chemistry Kit Logo
107 people viewed this question
Top Scientific Explorer Toys Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Scientific Explorer Toy Expert? Answer questions, earn points and help others
