Question about D-Link DIR-615 Wireless Router
I have the dlink dir 615 wireless router and a westell dsl and i need to set up on new modem so i can also use the internet on my laptop help help had it set up beofre but had to put modem in shop for repairs and do not remember how to set it up
acdr
  • 1913 Answers
SOURCE: how to put a password on dlink dir-300 wireless network
u have to setup as wep
then enable secure network then set encryption key.wihc is prompt for connect network.
Posted on Dec 30, 2008
SOURCE: how to install d link Dir 615 router
Port opening
Posted on Apr 22, 2009
SOURCE: dlink DIR-615 wireless connection problem
hi. with regards to your concern. there is a possibility that the wireless network adapter driver is corrupted.. try uninstalling the driver for your wireless adapter and reinstall again. once setup is done, view the available wireless connection and connect.. it will ask u the password if there is..then it will connect. if this solution dont work.. try to check your wireless settings, maybe there is a problem on the settings..
Posted on Aug 08, 2009
  • 10 Answers
SOURCE: sitecom WL-330 range extender with dlink dir-615- unable to use
I am guessing you have XP or vista. here are the instructions for both.
XP 1. Click ‘Start’ button (it should be located at lower-left corner of your computer), then click control panel. Double-click Network and Dial-up Connections icon, double click Local Area Connection, and Local Area Connection Properties window will appear. Select ‘Internet Protocol (TCP/IP)’, then click ‘Properties’ 2. Select ‘Use the following IP address’, then input the following settings in respective field: IP address: 192.168.0.2 Subnet Mask: 255.255.255.0 Click ‘OK’ when finish.
Vista 1. Click the ‘Start’ button (it should be located at lower-left corner of your computer), then click control panel. Click View Network Status and Tasks, then click Manage Network Connections. Right-click Local Area Network, then select ‘Properties’. The Local Area Connection Properties window will appear, select ‘Internet Protocol Version 4 (TCP / IPv4)’, and then click ‘Properties’ 2. Select ‘Use the following IP address’, then input the following settings in respective field: IP address: 192.168.0.2 Subnet Mask: 255.255.255.0 Click ‘OK’ when finish.
Next step for both All functions and settings of this access point must be configured via the web management interface. Please start your web browser, and input ‘192.168.0.234’ in the address bar, and press the ‘Enter’ key. The following dialog should be shown: Please input user name and password in the field respectively. The default user name is ‘admin’, and the default password is ‘admin’. Press the ‘OK’ button to see the web management interface of this access point: NOTE: If you can’t see the web management interface, and you’re being prompted to input user name and password again, it means you didn’t input username and password correctly. Please retype user name and password again. After you connected to the access point by web browser, the first thing you see is ‘Status and Information’ page. All system and network related information of this access point will be displayed here. The information is very helpful when you want to know the detailed information of your access point, and when you try to fix the communication problem between this access point and other wired / wireless computer / devices. You can click ‘Home’ on the left, This access point can be operated in different modes; you can click ‘Basic Setting’ to select an operating mode you want to meet for different needs: You can click ‘Mode’ dropdown menu to select operating mode, and there are 3 operating modes available: AP Access point mode, allows wireless clients to connect to access point and exchange data with the devices connected to the wired network. Station- Infrastructure Enable the Ethernet device such us TV and Game player connected to the access point to a wireless client. Universal Repeater This product can act as a wireless range extender that will help you to extend the networking wirelessly. The access point can act as Station and AP at the same time. It can use Station function to connect to a Root AP and use AP function to service all wireless clients within its coverage. You can hopefully figure it out from there.
Posted on Sep 13, 2009
Testimonial: "tanks v. much for answer, i'll try it right away"
clb199
  • 164 Answers
SOURCE: Problem for D-Link DIR-615 Wireless Router, Orange Power Light
I have had multiple problems with these routers. They tend to drop signals or have other issues that are hard to explain in a few short sentences.
After you rebooted did you open your browser and type in the IP address to connect to the router software?
can you be more specific?
Posted on Nov 24, 2009
Testimonial: "There was a problem with router itself, after replacement everything works fine. Thank you for an advice"
Talk talk, technical assistance
How did you connect the computer to the router. If you are using a DSL modem it will have a DHCP server in it that is allocating IP addresses across your network. If you added the router to the computer via a hub or network switch what is the computers ip .
address. Remove the WI FI router - turn off P.C and then Go to cmd or dos prompt if windows based system and type in ipconfig and press enter to see if ip addresses are 10.0.0.2 if they are your dlink router uses 192.168.0.1 so you need to make the dlink router ip addressand subnet setting to match the Modem ip addresses of the DHCP server. Change the ip address of the dlink router to be 10.0.0.2 and change the modem to allocate DHCP IP addresses from 10.0.0.10 to 10.0.0.255. Only do this if IP addresses are 10,0,0,1 to 10.0.0.,254 on the desktop p.c with the dsl or cable modem connected.without the router being involved. (you may need to ask the ISP what the user name and password is of the modem and it should be ip address xx.xx.xx.1 so type this into a browser to change the modem settings. 10.0.0.1 or 192.168.0.1 just remember if the modem is 192.168.0.1 so is the Wi router from d-link and you will have an ip clash problem)
. How do you do this by ethernet connection from only the desktop directly with only the Wi FI . router. Go to a internet browser and type in the URL 192.168.0.1 and then change the router ip address to match what the DSL modem DHCP issues..
Page 14 of Router instructions see http://files.dlink.com.au/Products/DIR-615/Manuals/DIR-615_C2_Manual_v3.10.pdf
in the manual it states to use a direct ethernet connection for the setup program but you need to be connected to the internet for it to work but if the IP addresses are wrong or clashing will have no internet. You also want to set the modem as the DCHP server and disable the DHCP server in the set up of the wi fi tand set the WI FI router default gateway as the ip address of the Modem. if any DHCP server options in the WI FI router sert to the modem ip address. .
Sep 08, 2014 | D-Link D Link Dir 615 Wireless Router...
My DIR-615 Dlink router always has the Orange globe. How am i supposed to fix this, the modem works perfectly fine as i tersted it without the router and internet works. But my wife needs the laptop and...
In the web interface of dir-615 switch it to router mode, adjust wan connection (username, password... depend on your Internet provider, in fact, it is easier to ask their tech support to provide all necessary information) then configure wireless network.
May 19, 2011 | D-Link DIR-615 Wireless Router
I JUST BOUGHT THE D-LINK DIR-615 (N300) _ WIRELESS ROUTER, IT TELLS ME TO HOOK UP TO MY MODEM BUT I DO NOT HAVE A MODEM, I HAVE DSL BUT IT IS RUN FROM THE OUTSIDE BOX ALONG WITH MY TV AND PHONE, MY DSL...
The router needs to have a modem to run off from, Even DSL provides modems if you do not have a modem then your DSL ISP (Internet Service Provider) did not provide you with one. I would suggest to follow the ethernet cord and see where it plugs into. You will need a modem to use a router.
Feb 18, 2011 | D-Link DIR-615 Wireless Router
I have a Westell DSL modem & a D-Link DIR-625 wireless router. Everything has worked fine for years but a few days ago the Internet connection went down. I contacted AT&T for support. During the...
you need to configure the dsl modem to be on bridge mode after you did it successfully. that is the time you configure your d-link for you to connect to the internet.
call first your ISP to configure the modem to Bridge mode after that call your manufacturer of the dlink for them to configure your connection
Jun 11, 2010 | D-Link DIR-625 (790069292637) Wireless...
Trouble replacing a USB modem with a Dlink 615 on Virgin Media
First: Turn off your USB modem.
Second: Setup your D-Link for connection
Feb 25, 2010 | D-Link DIR-615 Wireless Router
Trying to hook up a dlink router using cricket broadband wireless modem. need help?!?!?
Cable-modem (or DSL-modem) --> WAN port on CRICKET
and you _have_ a wireless network, without using the D-Link.
If you really want to get yourself confused:
LAN port on Cricket <--- Ethernet "cross-over" cable ---> WAN port on D-Link router.
Jan 28, 2010 | D-Link DIR-615 Wireless Router
Set up a d-link 615 wireless n router with laptop?
Assuming you have a broadband connection, yes, the D-Link 615 router can be set up to share your internet connection with your laptop. Please consult with your router manual on the proper steps to configure the device. http://www.dlink.com/products/?pid=565
Oct 12, 2009 | D-Link DIR-615 Wireless Router
I cant connect my wireless n router to my internet connection
hey can you see your router pppoe connectied to you pc or laptop
Jul 05, 2009 | Computers & Internet
D-Link DIR-615 Wireless Router Logo
152 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
