Question about Miele Washing Machines
I have a Miele washer dryer Softronic WT2670 and it sometimes smells when I take the clothes out so I bought Dr Beckmann Service it washing machine cleaner but before i use it i wanted to know if it is safe to do so as the machine is under guarantee and i do not want to damage it in any way. I have also been told over the telephone to use soda. Is this better? Your reply will be much appreciated. kyria.m@hotmail.co.uk
Yozzer6821
  • 116 Answers
SOURCE: Admiral Washer Model# AAV7000AWW
Your problem sounds like a defective water level switch, the rinse switch bypasses this switch therefore your get water whan you go to rinse.
lift the top cover, look at the front of the machine, insert a flat knife approx 4" in at each side of the seam between the front panel an the lid to release the clips, this will allow you to lift the lid, the water pressure switch is at the back (usually round with 3 wires and a small hose to the outer drum low down, ensure the small hose is connected, or with a mais tester check the output (orange/purple wire terminal 2), no mains voltage=no water, the input is grey (terminal 1) from the timer and should be live, the 3rd wire is the output telling the timer "the washer is full" (light blue terminal 3) and will be live when full.
Posted on Apr 13, 2008
SOURCE: maytag neptune front load odor
its better do a maintenance, or put it to wash without cloths, only water and clorox, and varsol with the max level (water)
Posted on Nov 12, 2008
SOURCE: Miele WT2670 message on screen
I've just had this fault on this model, Its caused by a leak of water into the tray at the bottom, which activates a sensor to shut the water in flow off and thus prevent a flood. The fix is as for a posting by halldor to a question about the w4146 - ie.
Turn off and unplug, drain by the filter plug, lean the machine forward - the water flows out the bottom, plug in and it should work.
You do need to establish the cause of the leak first. Mine was a draw cord on some trousers dangling out of the door, thus preventing a proper seal, the water dribbled down the front and into the tray. Miele stated it could only be fixed by their service mechanics - I'd have had to wait 10 days!
Posted on Aug 01, 2009
  • 177 Answers
SOURCE: miele front loader washing machine W3275- error co...
hi,
this is a tachogenerator fault or the drive motor brushes are faulty. you will need a Miele service tech or a Miele service agent to look at this.
Posted on May 24, 2010
blueextc3221
  • 15935 Answers
SOURCE: wps code
Simply disconnect it. Water completes the circuit - so you want to make sure it is open.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 16, 2010
Black mould in rubber door seal beko washing machine how to remove?
Hi, the best way is to try and get a damp cloth and i use the end of a wooden spoon with the cloth to remove as much as i can. Then if and when you finish doing that i obtained from the supermarket a washing machine cleaner called Dr Beckmann deep clean .
Mar 18, 2016 | Beko Washing Machines
Where can I get a service manual for dryer Miele softronic T 4422 C
Manual is normally hidden inside the case, either bottom right, or inside the console at the top.
Make sure all the vents and pipes to outside are clear of lint and obstruction.
Jul 28, 2015 | Miele Dryers
How to fix Miele WT2670. No issue in doing the wash, but when it comes to drying, it seems to be stuck in the last 12 minutes . Then eventually the machine stops, but the clothes are still not dry
perhaps the timer has gone bad many times the washer does not spin out as fast as they should thereby making the dryer work even harder to dry the clothe completely .
Apr 06, 2015 | Miele Washing Machines
Is there a limescale and detergent remover for indesit witl 62
Try "Dr Beckmann Service-it" washing machine cleaner, available from most supermarkets.
Mar 09, 2015 | Indesit Washing Machines
My brand newly installed dryer makes my clothes smell like gaas when dried. We checked for a gas leak and there in not one. HELP!
Check that the smell is not coming from the washer, a VERY COMMON issue is the washer generates mold like smell, there is a cleaner that needs to be run through the washer every month. Not a detergent, but washing machine cleaner...
Aug 02, 2011 | Miele Dryers
Dryer has sour odor that is transfering to the clothes
This smell usually is a washing machine issue. Run a washing machine cleaner through on a monthly basis and the smell will be gone.
Jun 20, 2011 | Miele Novotronic T1515A Electric Dryer
Washer/dryer smells like a dirty disclothe. I dont' use fabric conditioner and I have serviced was at 90 deg with no clothes in and biological powder but it still smell. I have only used the dry cycle...
Hello
What did the guys say the did the service on your washer? I recommend you add 3 scoops of dishwasher powder and set your washers temp to 90 deg and let it run the problem is that your clothes washing powder dose not remove any build up or smell.
Thanks
Jun 15, 2011 | Zanussi WJS1265W Front Load Washer/Dryer
How do i remove the lid of a miele wt2670 wasing machine
Two small screws at the back and one on either side (behind little covers)
There are two hinges at the back, so lift off from the front up.
Aug 28, 2010 | Miele WT945 Front Load Washer / Dryer
Wps code
Mar 26, 2009 | Washing Machines
Washing Machines Logo
95 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
