Question about Hotpoint Dryers
How do you get the mildew smell out of a clothes dryer?
  • 699 Answers
Very unusual problem with a dryer as it gets hot and would normally evaporate moisture causing mildew!
Try the following:
  • Unplug the power point of the dryer.
  • Gently clean the interior (and exterior) with a super absorbent cloth/non-scracth sponge lighty soaked in a mild bleach soapy mixture to kill off and remove the (blackish) mildew (Nappy wash is not a bad mixture). Weat rubber gloves for protection.
  • Let the unit wet for a few minutes and then using clean warm water and sponge, remove all trace of the bleachy soap on the unit as it is corrosive. Additional drying off with disposable paper towel will help remove any trace of bleach.
  • Put a wet clean bathroom towel lightly soaking with material conditioner mixture at double the normal recommended ratio, power the dryer and dry off the towel as per normal: the fabric conditioner is also a freshner.
  • Musty milldew odour should be gone!
Hope it helps! Please let me know how you go!
Posted on Aug 05, 2010
The water spray for steam cycle in Samsung front load dryer smells musty. The clothes smell bad from steam cycle only.
water build up in the steam water resevore sitting to long and getting that mildew smell check the hose lines going into it and from it. for blockage
May 27, 2014 | Samsung Dryers
My daughter left clothes in the dryer and they werent dry now my dryer smells soured. how do i get rid of the smell?
Try tossing a tad of dry baking soda in with the clothes in may take a time or two but it would be better than tossing the dryer. If it smells like mildew also maybe try placing some charcoal inside withe door shut, charcoal draws mildew.
Nov 06, 2009 | Estate TEDX640JQ Electric Dryer
I have sour mildew smell problem with my clothes
Look inside the door to the gray rubber ring gasket thingy. Pull apart the sides and look in. Betcha a dollar to a donut there's mold in there. It's a gross, nasty problem whirlpool customer service doesn't give a damn about.That's where water sets after wash cycles. There are tablets call "Affresh" which can be run with hot water for a cycle to attempt to clean out the mold/mildew. Not cheap, not fair, and probably will only be a start to a maintenance type cure if you've had the washer for awhile. May take some manual labor with bleach as well. NOT a sanitary washer. This is an unbelieveable problem with a washer. Piece of ****.
Aug 06, 2009 | Whirlpool LHW0050PQ Front Load Washer
My neptune dryer makes all my clothes reak. I have cleaned the air vent out and I didnt see any dead cats or anything like that. Clothes smell like they have been in the dump. They come out of the washer...
You may have lint mildewing in the vent. Take the vent tube off the back and reach in the back and see if there's lint stuck in there. Clean the vent tube also. Use a dryer sheet to help with the smell
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 18, 2009 | Dryers
Maytag Neptune/ clothes smell like mildew
Go out and buy a box of "AFFRESH". Run it according to the directions.
May 28, 2009 | Maytag Neptune Washer
Kenmore Super Capacity Washer - Mildew smell
run the washer, with no clothes,
and 2 cups of bleach instead of detergent.
kills any mould in the washer
at least until you find the original cause, it wont stink
Oct 13, 2008 | Kenmore 3.2 cu. ft. Top Load Washer
Stinky clothes
The big door seal is probably the problem. Put on gloves and using a solution of Laundry detregent and hot water and rags, carefully wipe clean all the folds of the seal. It will be icky. Next run a cycle with some detergent and oxyclean or bleach if you have it.
Especially during warm weather, damp clothing left in a front loader mildew slightly very quickly- you can't really see much but you can smell it! So get the clothes in to the dryer immediately. You'll want to relaunder the smelly clothing after you have cleaned the washer.
Good luck to you and Thank You using FiX YA!
Aug 17, 2008 | Kenmore Elite 45986 Front Load Washer
Mildew smell on clothes
I have the same machines. Try using an old towel and detergent solution( use rubber gloves) and thouroughly clean the door seal. It can be just full of old lint, dirt, etc. in the grooves. Also try some oxyclean in your next load. That will help get rid of the odor also. These washers stay warm quite a long time and clothing will mildew fast in warm weather, but you probably already know that.
Aug 01, 2008 | Frigidaire ATF6000ES Front Load Washer
Bad smell
washers and dryers dont make smells themselves its a problem with something u might be putting in it. if u tend to add alot more detergent then usual to your towels then they never completely rinse the water out and will have a mildew smell
Feb 18, 2007 | Whirlpool GEW9250P Electric Dryer
Dryers Logo
192 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
