Question about Panasonic PT-53WX54 53" Rear Projection HDTV
PT-53WX54 53 in. Rear Projection HDTV Television
I have this television and I am having a problem with the picture. The picture slants downward and to the right. You responded to someone else's post about how to correct this problem, however I was wondering if you could describe to me exactly how to fix the problem.
Thanks!
  • jwade Apr 26, 2008
    Hello Shuttle83,
    First off, thanks for your help.  If this is a simple fix hopefully I can avoid paying $100 just to have someone diagnose the problem.  I tried to attach a picture to this, but it is saying the image is too big.  Do you have an email address I could send it to?  Again, I really appreciate your help.
    JWade
    Genius:
  • 1,139 Answers
Hello jwade,
This looks like it could be a problem in the Convergence/Deflection section. If possible could you send me pictures of the actual problem. Because they will let me know if this is a convergence or a deflection issue. The problem is these two sections are dependent on each other, but follow certain troubleshooting methodologies. Again post or send me pictures of the actual screen, and from that I should be able to help you.
Thank you,
Shuttle83
Posted on Apr 26, 2008
  • Henry McKelvey
    Henry McKelvey Apr 26, 2008
    Hello jwade,
    electronagetec@aim.com
  • Henry McKelvey
    Henry McKelvey Apr 27, 2008
    Hello jwade,
    Just as I suspected you have a deflection problem causing a slight convergence problem. What has happened; is your deflection circuit has caused your deflection coils to shift the picture off horizontal axis. This in older single tube TVs would have been a manual adjustment, but since these projection TVs have three tubes the adjustment is usually controlled via internal diagnostics.
    Question is have you tried using the dianostics available in your menu? If you have not I would suggest trying that first. If you have then you will have to do a manual adjustment by setting the voltages on the deflection coils. At this point I should tell you that it would be best to get this taken care of by a professional, because of work involved and the chance of permanent damage. It takes time to perform these types of adjustments, and the equipment needed is expensive. So here are the basic instructions on how to adjust deflection using the manual method without using the internal diagnostics (I am giving you these instructions because the on-board dianostics and adjustments should be included in your owners and or service manual):
    1) connect a Universal Video Analyzer Signal generator to your tuner.
    2) adjust it per the instructions to inject a signal on channel 2
    3) set the pattern control to crosshatch
    4) using a mirror make sure you can see the full screen from behind the television
    5) find the manual deflection adjustment controls or use the controls actuated from the remote control (see the service manual for these settings)
    6) adjust the settings of the vertical and the horizontal per the service manual instructions
    7) after the set is adjusted use the remote control to lock (save) the settings.
    This should get rid of the combination of the deflection/convergence issue
    Now again I must advise that you get this done by a professional, because I have been doing this for close to 25 years and I never get it right the first time, and to be honest, if anyone says they can I would doubt them.
    I know there is not much to solving your problem but it is just tedious.
    I hope this helps
    Shuttle83
I need to reset lamp on PT-52LCX16 Panasonic rear projection tv how do I do that
MODEL INDICATED DOES NOT USE A "LAMP", IT IS A CRT (picture tube---has red, green and blue picture tubes).
Verify model number is or is not correct.
What is problem with this set?
SD TECH
Aug 16, 2010 | Panasonic PT-53WX53 53" Rear Projection...
PT-50DL54 50 in. Rear Projection HDTV-Ready Television: started to get dimer and dimer and finally picture...
You should have received a message on the screen about replacing the lamp. Also, the LAMP led on the front should be lit in red.
You can replace the lamp assembly easily for about $150 - $250.
Don't try to replace the bulb only.
A new Panasonic Plasma TV will cost about $1000 and good for another 5 to 6 years.
May 05, 2010 | Panasonic PT-50DL54 50" Rear Projection...
PT-53TW53 53 in. Rear Projection has sound but no picture
It is. And I hope you some cash set aside for this extremely costly repair.
I once had a rear projection TV and was told by the repairman that each of the 3 flourescent lamps run about $200.00 to replace.
Needless to say I did not get it fixed
Oct 12, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Red screen with double picture
i have a Panasonic Projection HDTV pt-47wx49e and the picture comes in jumpy and very discolored is there any thing i can do to fix it.
Mar 28, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic pt 53tw53 rear projection
Check the vertial output IC. either for defective solder or defective IC. This model has a feature if the vertical output IC fails for any reason the picture tubes blank out as a safety issue.Thereby giving no picture but audio still functions.
Mar 11, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Phillips hd 1080 60 inch rear projection
if your colors are off i fixed it myself they wanted alot of money to fix it so i did it myself......here's my email if you need my help....
sniper4_0_3@yahoo.com
Jan 23, 2008 | Philips 60PP9202 60" Rear Projection...
Picture Slant
You will have to adjust the yoke transformers on the necks of the color guns. this should clear up the slanted picture.
Sep 24, 2007 | Panasonic PT-53WX54 53" Rear Projection...
Panasonic PT-53WX54 53" Rear Projection HDTV Logo
50 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
