Question about Traxxas Toys
My tmaxx 2.5 seems to not want to responde very well and the throttle servo is not running in the right direction and will not change even when i change the channel on remote what is wrong with my truck oh and replaced the throttle servo and still same outcome
  • 56 Answers
Theres a swith on transmitter that reverses traval of servo. Sometimes hidden.
Posted on Aug 05, 2010
    Problem Solver:
  • 15 Answers
Thee settings may have gotten messed up. If you have a tq 2.5 controller, and there is a menu and a set button near the base, hold those two buttons down with the controller off. While still holding the buttons down, turn on the controller. The light should blink, and you should be reset.
Posted on Oct 08, 2011
  • Jason Gronstrand Oct 08, 2011
Tmaxx 3.3 starts and runs when holding off the ground but as soon as i put it on the ground it dies
Change your clutch shoes and spring, if shoes are still good,then just the spring
Mar 07, 2013 | Traxxas T Maxx 3.3 Monster Truck
I have a TMaxx 2.5 and it will trurn to the left but not to the right. I replaced the servo, but it's still doing the same thing. Even with everything disconnected. If I set the trimm all the way to the...
Have a look on all parts for anything thats catching. With servo hat of you should be able to pull and push steering levers left and right. If it still dosnt go left while pushing or pulling then there is something catching. If you can make the wheels go left then reconnect to the servo making sure servo is in the central position and all trims are in the central position.
Aug 08, 2010 | Traxxas T Maxx 3.3 Monster Truck
Hi i have a 09 r1 code 12 and 60 showing i have tried everything check all points from service manual .... Please i need help
Error code 12: CRANKSHAFT Position Sensor >>> It could be the sensor itself, but I'd check all the wires and associated connectors that run from it to the ECU and check any that pass very close to the fan blades as it has been known for them to catch on them and become damaged.
Fault code No.: 60 Symptom: Throttle servo motor: open or short circuit detected. Defective throttle servo motor. Malfunction in ECU (servo motor driving system). Probable cause of malfunction: •Open or short circuit in wire harness. •Defective throttle servo motor (potentiometer circuit). •Stuck throttle servo motor (mechanism). •Stuck throttle servo motor (motor). •Malfunction in ECU. Diagnostic code No.: 01
FIRST thing to do is CHECK the ETV Fuse - 7.5A I think - This might NOT be in the main fuse box.
Hope this helps
Jul 13, 2010 | 2007 Yamaha YZF-R1
I have a 07 yamaha r1 and im getting 2 codes 22 and 60 and im not getting a throtle response what can it be?
Fault code No. 22 Symptom >> Air temperature sensor: open or short circuit detected.
Item/components and probable cause
1 Connections Air temperature sensor coupler Main wire harness ECU coupler Check the coupler for any pins that may have pulled out. Check the locking condition of the coupler. If there is a malfunction, repair it and connect the coupler securely. 2 Open or short circuit in wire harness. Repair or replace if there is an open or short circuit. Between air temperature sensor coupler and ECU coupler.(Brown/White)(Black/Blue) 3 Defective air temperature sensor. > Replace if defective.
Code 22 > Reinstated automatically if a normal signal is received.
Fault code No.: 60 Symptom: Throttle servo motor: open or short circuit detected. Defective throttle servo motor. Malfunction in ECU (servo motor driving system). Probable cause of malfunction: •Open or short circuit in wire harness. •Defective throttle servo motor (potentiometer circuit). •Stuck throttle servo motor (mechanism). •Stuck throttle servo motor (motor). •Malfunction in ECU. Diagnostic code No.: 01 FIRST thing to do is CHECK the ETV Fuse - 7.5A I think - This might NOT be in the main fuse box.
Hope this helps
Have an older tmaxx and it goes in reverse how do i get it to go forward Do i have to adjust something or buy something to make it go forward or is something in backwards
Hi, you just need to buy the FOC and install it and take out the reverse servo. Just taking the reserve servo won't work because the shifting fork will move while you're driving and go into neutral....
Take care
Jun 06, 2010 | Toys
When i start my tmaxx it tries to take off by itself wide open i cant stop it just keeps going
Hi
Assuming the transmitter is still set correctly then the problem is either your receiver is defective or your throttle servo is defective and/or both. Don't start the engine but switch the servo wires. If the switched servo now doesn't work then your receiver is bad, if it does work then the other servo is bad. Good luck
May 03, 2010 | Traxxas T Maxx 3.3 Monster Truck
How do you change the throttle servo on a revo 3.3
Disconnect the servo at the receiver, remove the servo horn and linkage from the servo. Remove the four screws that hold the servo to the chassis. Replace with new servo, plug new servo into receiver and turn on transmitter and receiver. With transmitter and receiver on reattach servo horn and linkage. This will make sure that the servo is centered at neutral throttle.
Sep 25, 2009 | Traxxas Rc Revo Nitro Monster Truck
When I depress the throttle on my 2004 ford f-350 the engine does not always throttle up. the truck starts and runs fine and idles perfectly even when the throttle does not respond. shutting down the...
what engine? Does it set a wrench or check engine light? They have problems with the electronic throttlebody, will give you no throttle response
Mar 05, 2009 | 2004 Ford F350
Toys Logo
270 people viewed this question
Top Traxxas Toys Experts
Michael Brisco
Level 1 Expert
gbob59
paul tooker
Are you a Traxxas Toy Expert? Answer questions, earn points and help others
