Question about Digital Leisure eJay Hip Hop 6 Full Version for PC
I have a ejay 6 full version and i cannot save or export any of my music i create, please give me help
Eversince i can not install microsoft word.. what do you think is the problem
Hello. Try this, it works.
"1) Create a Windows Account with full control admin rights, and then go ahead and log into that new account.
2) When under the newly created account, open every Office product you have, then close one at a time (Excel, Word, PP, etc...)
3) After opening every Office App, go into the registry editor (Start ' Run, then type in Regedit)
4) Go to HKEY_CURRENT_USER ' Software ' Microsoft ' Office, and highlight Office
5) Then right click on Office, and go to Export, save the .reg file to somewhere you will be able to find it (Root of C: for me)
6) Log off your temp Windows account, and log back in under your normal Windows account that was giving you the error.
7) Open regedit again, and then go to File ' Import and pick the file that was exported.
icon_cool.gif After it says that it was successfully imported, go ahead and try the app that was giving you problems.
Now it should work, just like it did for me. Also, remember you delete the temp account that you created!!
Aug 08, 2011 | Microsoft Computers & Internet
I have steinberg clean 4 & 5 but both versions only show CPF file choice .i want to save as wav.
On the File menu you will find an option named "Export Audiotrack as WAV" as well as "Export Audiotrack as MP3". This will allow you to Save or Export the files you create as either the .wav format or the .mp3 format. Check your Help file, specifically page 86, if you need further information.
Mar 17, 2011 | Pinnacle Steinberg Clean 4.0 (210100265)...
My anime studio pro 6 program used to let me export .AVI but now it doesn't. The export format is on "AVI movie" (only 303 frames to test my export). Only Antialiased edges, apply shape...
It sound like you have a defect codec installed. Try updating (uninstall / reinstall) your codecs.
or disable the codec befor trying to export.
Disable codec: http://kb2.adobe.com/cps/404/kb404892.html
Mar 13, 2011 | Smith Micro Anime Studio Pro 6 Full...
How can i export the data tally to excel
There are 2 ways to do it..
Step 1
You can export as text and import it back to excel using the text file you created.
Or
You can select HTML and give the file name as eg-XYZ.xls
Step 2
You can export all reports and statements. For this a separate export button is provided in right hand button bar. To do this go to any report e.g. day book you to export or any statement e.g. balance sheet. You would see export button on top right hand side on button bar. Press it and a screen would pop up with export related options.
The first option is format of data to be exported namely ASCII, HTML, SDF, and XML. Which ever application you are importing this data in would decide in which format you should export the data.
For statements like balance sheets and trial balance which we use to send and import file in word and excel etc. HTML format is good. We need minimum formatting in this format while using it in MS Word and MS Excel.
certain applications accept continuous data where we have defined field length. Then ASCII format is better.
For application which accept SDF and XML format these formats can be chosen.
Give a file name and the exported file is saved in the parent Tally directory on your computer. You can now use that file to import its contents into another program, send it as it is (say if it is HTML file) to a colleague or view it using a browser.
Step 3
Consider exporting day-book.Go to day book press export button or use shot cut key Alt+E. Exporting screen will displayed.
Press Back space on your keyboard. And select Format as ASCII (comma delimited). Now give output File Name as Daybook.csv, now select some other option you want to export from the bottom of the screen.
Press enter to accept screen. Day book is exported in to tally program folder. Check program folder for file daybook.csv,
Double click on it, the file will open in excel program. If you want it in excel work sheet file, use the option Saveas, and save it in Microsoft excel workbook (*.xls) format.
Hope this is helpful. Let us know if the issue is resolved.
*Rating and Comments are invited for this solution
Nov 24, 2010 | Tally T2245 Matrix Printer
Cannot export or save on corel x4 full version
This usually happens if you using cracks for corel registration.
May 07, 2009 | Computers & Internet
I have magix music maker 7 but have not used it much! i want to create some samples from songs for a school project by cutting them down on MM7 and saving the file in a format that windows media player or...
I am not much aware of this new MAgix Music Maker but there is similarity with issues with other softwares before.
One possibe solution to your issue is by saving the music created on the MMM7 directly into a format that is playable on any standard player. If MMM7 has this option the music created may play on other devices such as dvd or mp3 players. Changing the file extension after you saved a music from a MMM7 format will not work and will not be detected or read by other music players. Try this and it might work and if MMM7 has this option to save MMM7 music to a standard format accepted by other players , then have fun with the music.
Jan 24, 2009 | Magix Music Maker 7 (601001) for PC
Conecting withmy laptop
Download the latest version of itunes onto your pc from here
http://www.apple.com/itunes/download/ it is free. This will let you load music and videos for your ipod then sync your ipod, and let your view your music vids etc,,, using itunes.
If you do not want to lose anything from your ipod that you have already saved then click on the link below and download the program. It will export your ipod data into itunes, so you will not lose anything you already have on there. Once you have created a library in itunes you only need to plug in your ipod and it will automatically update your ipod using the playlist you created.
http://www.ipod2computer.com/index.php?SRC=6&gclid=CNPN9JDG0ZYCFQOx1AodBhhV3Q
I hope this helps
Oct 31, 2008 | Apple iPod MA446LL/A MP3 Player
Save quark 7 as quark 6
Navigate to File>.Export layout as project>>Choose version 6 and Export the document
Jan 11, 2008 | Adobe Photoshop 7.0 for PC
Digital Leisure eJay Hip Hop 6 Full Version for PC Logo
136 people viewed this question
Top Digital Leisure Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Digital Leisure Computer and Internet Expert? Answer questions, earn points and help others
