Question about Cell Phones
I WANT TO SWITCH OFF THE VIBRATION OF HM 1500
  • Sertac Sever Aug 14, 2013
    Hold call button and volume down button together for 4-5 seconds. It worked for me
Hi
how can stop vibretion
Posted on Feb 15, 2013
  • 74 Answers
To switch it off or on. Generally, you goto: menu/ settings/ sound settings/ general settings and thre you'll choose to switch vibration off.
Posted on Apr 08, 2015
    New Friend:
To turn off the vibration for samsung HM1500 press and hold the main button and button for volume up.
I have an HM 1500 demolition Hammer replace the switch and it won't run
BLACK+DECKER drill quickly replaced my cordless drill for all of the heavy duty tasks, and it continues to be a great "work horse". More details about the drill Best Hammer Drill
Apr 13, 2018 | Hammering
How can i hear any sound for my iphone 5s to the samsung hm 1500 bluethooth headset?
Check that the BT headset supports short ringtones like messaging
try the same thing on another (non Iphone phone)
Apr 24, 2014 | Samsung HM1500 Bluetooth Headset
1996 Kawasaki VN 1500 Vulcan Classic excessive vibration
Hi, Anonymous and the usual suspects are:
1. Wheels and or tires worn or damaged.
2. Engine/transmission/vehicle not aligned properly.
3. Primary chain is badly worn or links too tight as a result of insufficient lubrication or misalignment.
4. Engine to transmission mounting bolts loose.
5. Upper engine mounting bracket loose.
6. Ignition timing incorrect due to a poorly tuned engine.
7. Internal engine problem flywheels have shifted.
8. Broken frame.
9. Stabilizer links worn or loose.
10. Rubber mounts loose or worn.
11. Rear fork pivot shaft nuts loose.
12. Front engine mounting bolts loose.
13. Worn out or broken universal joint on shaft drive models.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
1500 Classic Engine Vibration Kawasaki Vulcan Forum Vulcan Forums
http://www.kawasakimotorcycle.org/forum/kawasaki-cruisers/4857-03-vulcan-1500-classic-vibration-low-speed.html
Kawasaki VN1500 Service Manual
OEM Parts for Kawasaki
1996 Kawasaki Vulcan 1500 Classic Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Oct 05, 2013 | 1996 kawasaki VN 1500 Vulcan Classic
04 acura ti 3.2 litre engine vibration from idle to 1500 rpm
Wow thats a bunch of miles for only 9 yrs.
I would want to know if it is something related to the engine or transmission, or the wheels and suspension.
Does it happen in all gears, and at any road speed ? Can you rev up the engine and make the vibration, or does the car have to be moving ?
Jul 01, 2013 | Acura TL Cars & Trucks
How do i install panasonic hm-ta1 camcorder
Disable the webcam function in the menu. Connect the cable to USB, switch on, a window will appear with some files. Run setup.exe.
Nov 12, 2011 | Panasonic HM-TA1 Camcorder (Grey)
HI MY 2006 S AWD MURANO HAS STARTED THIS IRRITATING VIBRATION..CAUSES EVERYTHING FROM THE SEATS AND THE MIRRORS TO VIBRATE. I HAVE CHECKED BALANCING, TIRE ROTATION AND ALIGNMENT..BUT PROBLEM PERSIST. DO...
Hm. I had an irritating vibration at highway speed with tires that came with my car. I had the balance checked and it was determined that there was an out of round tire. I replaced the tires, had them spin balanced, and the rims were perfect. After that, the vibration at highway speed went away.
Tires are the most common problem for vibration at various speeds.
Where did you buy your tires or have them spin balanced?
Oct 12, 2010 | 2006 Nissan Murano
Replaced U-Joints and had vibration ,had driveshaft balanced and still vibration 45MPH on up. 2000 1500 extend cab 4 4 8'bed 2-piece drive shaft with carrier bearing, any ideals also fan switch speeds 1...
check your tires for a bad spot or a knot. this could cause the vibration. check you switch and see if it has power. if it does maybe the a relay.could also be a lose ground wire.
Sep 17, 2010 | 2000 Chevrolet Silverado 1500
I NOTICED THAT THE POWER STEERING FLUID SPLASHES IN THE RESERVOIR AND I HAVE ENGINE VIBRATION AT IDLE AND UP TO 3.000 R/M. HAS IT TO DO WITH P/S PRESSURE SWITCH ON THE PUMP?
Hi:
It is doubtful that the power steering pump is the cause of your vibration, but to find out for sure, remove your serpentine belt, and start up the truck and run it briefly without the belt to see if the vibration goes away. If so, you know that it is caused by a belt driven accessory..Then you can individually check the power steering pump, the alternator, and the AC compressor if you have one.
Apr 29, 2010 | 2004 Dodge Ram 1500
Vibration in the steering wheel on a 4wd truck
I just had the same issue with a 1999 2500HD and the vibration got worse above 50 mph. Problem was resolved with a new driveshaft. Old one (aluminum) was badly out of true and the problem didn't really occur until I had the U joints changed - then bent driveshaft vibration was noticeable. New driveshaft resolved issue.
Dec 03, 2009 | 1999 Chevrolet Silverado 1500
Cell Phones Logo
415 people viewed this question
Top Cell Phones Experts
Marvin
Marvin
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
