Question about Microsoft Windows Vista Home Premium Edition for PC
Samsung HDD not seen by Vista I recently purchased a Samsung HD154UI Hard Drive for my Vista 64BIT System. I have enabled the hard drive in the Bios. I now have a 500GB drive on SATA 1 and the new 1500TB drive on Sata 1. My DVD sits on SATA 2. SATA 3 is empty. I can see the hard drive in Computer Management, but I cannot select it to format the drive. All suggestions welcome. Thanks
    Problem Solver:
  • 8 Answers
This won't be the best solution for you perhaps because I'm not a windows guy, but download the gparted (just google for gparted) cd image, burn it to disk and boot it up. Use that to partition and format the drive.
Posted on Aug 06, 2010
HOW TO REMOVE FORGOTTEN PASSWORD FOR SAMSUNG CORBY GT-S3850
These WEB sites may help remove the hard drive password.
HARD DRIVE PASSWORD UNLOCKING - Purchase
http://www.hddunlock.com/purchase/ A-FF HDD Unlock Wizard (HDD Password unlocking - Free)
http://www.hddunlock.com/download/
Jan 03, 2013 | Samsung Computers & Internet
Hdd is locked
Hard drive passwords are difficult to remove.
These WEB site maybe able to help you.
Nov 03, 2012 | Samsung HM250HI SpinPoint M7 Hard Drive...
Wants to unlock my samsung hard drive
Hard drive passwords are difficult to remove. These WEB site maybe able to help.
http://www.hddunlock.com/download/ b>
Sep 27, 2012 | Samsung SA07HD103SJ Samsung HD103SJ 1 TB...
My Samsung 1.5 TB external hard drive spins up and makes about 5 clicking sounds. My laptop cannot detect it. What can I do to recover the data.
A clicking sound for samsung drive is most like due to faulty heads and the only way to recover data off it is to perform a head swap. You need to buy a compatible donor online like ebay. If you don't know how to do this, i suggest you send it to data recovery company, as this is a very dangerous procedure. It can cause severe damage on your hard drive if you perform it without any knowledge and the right tools to do it.
hope it helps.
May 05, 2011 | Samsung HD154UI 1.5TB 1500GB SATA DRIVE...
Samsung hd154ui hard drive - cannot format above 1 TB says 500gb available but does allow one to create a partition
The drive has developed some bad sectors on it
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive or
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input may damage your computer
then defragment your hard drive
or you could download partition magic
when you download partition magic you will have the option to make rescue to disks to boot from make these disks then change your first boot device your to floppy drive this will give you options to partition then partition only the good sectors of your hard drive and install an operating system to the good partition Partition Magic 8.0 Partition Magic 8.0
note: after you loaded your operating system you will have to change the boot order back to your hard drive
During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos to restart
http://www.filehoo.com/download/Partition-Magic-8,0.aspx
Hope this helps you
Apr 06, 2011 | Samsung 1.5TB F2 HD154UI/Y HDD EcoGreen F2...
Hi! I have a laptop samsung r70, in which I have recently re-installed Windows Vista. Suddenly the computer started making a weird noise just before the system collapsed. Now Im trying to re.install...
I would suggest that it is most definitely a hard ware failure most likely your hard disk drive failed do to the fact that it only makes the sound when you try to access it. All you need to do is go purchase another HDD install it and then just reinstall windows. HDD's are fairly cheep now a days and you can pick one up for 20 or 30 dollars. also attached i place a link to directions on how to change out your HDD.
http://www.ehow.com/how_4424308_replace-hard-drive-computer.html
I hope this helped.
Thank you,
Norse
May 18, 2010 | Computers & Internet
Samsung Ecogreen F2 (HD154UI) 1.5TB HDD not found on 2/3 PCs?
Vista and XP are a pain in the **** to make work as a network. as for the driver. Vista may have drivers built in to see it. and XP may not. see if there are any drivers for the external drive on the samsung website.
May 09, 2010 | Computers & Internet
No drives found
Tour full installation guide
http://www.windowsreinstall.com/
This will help you to get you hdd and windows running.
Aug 11, 2008 | Toshiba MK1637GSX 160 GB IDE Hard Drive
Harddisk
Check the jumper settings on the back of the drive, if this is the primary HD, set it to master, if secondary, set it to slave, if secondary still does not recognize, switch the ide cable so that the two drives are not on the same one.
Nov 19, 2007 | Computers & Internet
Microsoft Windows Vista Home Premium Edition for PC Logo
69 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
