Question about Sony FD Trinitron WEGA KV-SW29M50 29" TV
The on off switch in flashing twice every three seconds
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 116 Answers
Perhaps, you mean it is the on / off indicator light or stand-by light, not a switch? What flashes and then the TV to the stand-by? if true, you have to replace the crystal filter with CF506B code. tersbeut part in the main PCB board. its location in horizontal area.
Posted on Aug 05, 2010
My Sharp Aquos TV went off whilst we were watching it and won't come back on. The red power light flashes twice per second and the green OCD light flashes three times every second. Is there a re
Tries tv unplug replug the tv back about an hour later,might resetting the tv back factory setting and should work again.Still have the problems,the main board it is shorted and dead require changing.The main board that board were the incoming broadcasting signal wire plug into it.U have some basic machanic skills like take things a parts and putting it back together again.Should have no problems change this board at all..Tried websites like Shopjimmy.com,eBay.com to buy a refurbish main board for the replacement.
Feb 24, 2013 | Sharp Aquos Televison & Video
I just bought a 2003 road king classic and can not set the alarm. Can you tell the procedure?
Arming: Hold Fob button down until signals flash twice. The 'key' lamp on
the speedo will Blink to indicate the system is armed. If auto arming is
enabled, the key lamp will Stay continuously lit for 30 seconds after the ignition is turned off, then the system Will arm itself.
Disarming: 'Double-click' the Fob, the signals will flash once and the key lamp will stop flashing. If the Fob is lost or not working, the system can be disabled by entering the passcode. Without setting off the alarm, get the ignition switch to accessory, hold down both left and Right signal switches until the key lamp flashes rapidly, enter the first digit on the left And use the right as an 'enter' key, enter all five digits of the passcode and the system will Disarm, if you screw up, the alarm will activate and you will have to wait ten minutes.
Transport Mode: Allows the system to be armed with the motion sensors disabled for service, Trailering, etc. Turn the ignition switch on, arm with the Fob, turn the ignition off and Arm once again with the Fob. Signals will flash 3 times to confirm
arming, All other functions of the alarm system require entering the configuration mode. This is done by Disarming the system, run/stop switch in stop, flip the ignition switch on/off/on/off/on Then push the left signal button
twice. If power was disturbed to the alarm module, The sequence may have to be repeated to get into configuration mode. The system will respond by flashing out the module type code.
(1-TSM, 2-TSSM dom, 3-TSSM hdi)
Now that you are in the config mode, you can do the following.....
- To assign the Fobs, push the right once (one flash) then the left once (two flashes)
Then hold down the Fob button until the system recognizes it. Hold down the second
Fob until the system recognizes it. Both Fobs must be assigned at the same time.
- To assign a passcode, use the fob to send a disarm command, signal will flash once
To indicate the first digit, push the left signal button and the key light will flash out the Value of the first digit. Pushing the left button will advance the value up through 9 and Will start over at 1. When done setting the first digit, double click the fob again and The signals will flash twice to indicate the second digit, continue on through all five digits. Turn ignition off to exit.
- To adjust the sensitivity, use the fob to send an arm command (one flash) then push the Left signal button once. The signals will flash out the current setting, 1-4, push the left Button to advance the setting, turn ignition off to exit.
- To extract system trouble codes, press the right signal button three times,
pausing between Each press for the system to flash once, twice, and three times
respectively. Press the left signal button once and they signals will flash out two digit
codes. Press and hold the left button to clear all codes from memory, otherwise
turn ign off to exit.
- To enable auto arming, use the fob to arm the system twice, and press the
left button once. The system will flash the setting code, 1-disabled, 2-enabled. Press the left button to change The setting, turn ignition off to exit.
- To adjust between Sidecar mode and normal mode, push the right button
twice quickly, Then the left button once and the signal will flash out the current setting, 1-normal, 2-sidecar. Press the left button to change the setting, then turn the
- To adjust the length of time delay before going into storage mode, use the fob to send an Arm command three times, then push the left button, the signal will flash out the current setting. 1-30 days, 2-60 days, 3-90 days, 4-disabled. Use the left
button to advance the setting and turn the ignition off to exit.
Aug 31, 2011 | 2003 Harley Davidson FLHRCI Road King...
Reset change oil light on 2004 bruick revendevo
hi there
to reset this turn your ignition on without starting and press accelarator all the way down three time within five seconds the oil light will flash twice and you will have reset it have a wonderful day and thank you
Aug 22, 2011 | Buick Rendezvous Cars & Trucks
How do I reset oil life low light?
This one should be turn the key on to run position and fully depress the gas pedal 3 times within 5 seconds, If done correctly the light should start flashing.
Nov 27, 2010 | 1999 Buick Regal
Can`t get the hand set to lock or unlock, and i ha...
Open the boot/trunk lid and drivers door. Switch on the ignition to position II but do not start the engine. Wait for the dash lights to extinguish. within 5 seconds of the lights going out, Rock the valet switch, in the centre console, 5 times. The system will chirp to indicate it has entered learning mode.
On models with seat/mirror/steering wheel memory functions, the first key-ring transmitter will be linked to memory 1, second to memory 2 etc
Press and hold the larger, lock, button on the key-ring transmitter whilst watching the Red LED and ether wait for it to stop flashing or for the system to chirp a confirmation it has got the signal. If the system doesn't receive any signals for 15 seconds, it will chirp twice and exit learn mode
To program further key-ring transmitters, rock the valet switch once. The system will chirp twice for remote number two, three times for number three etc, then press the lock button of the key-ring transmitter as above
When finish, wait 15 seconds for the system to time out and chirp twice, turn off the ignition, close the doors and boot lid.
May 21, 2010 | 1995 Jaguar XJ6
How do you read the flashing check engine light codes on a 93 chrysler town & country?
Turn key on and off twice without starting engine. count flashes, their will be slight hesitation, make one digit after hesitation make second digit.(flashes 5 times hesitates flashes three times hesitates your code is 53) if it countiues to flash, its making second two digit code.
Jan 27, 2010 | 2005 Chrysler Town & Country
I would like to know how to reset my oil light on a 90 Cutlass Supreme Oldsmobile
Try turning the ignition switch to the "RUN" position with the engine off. Fully depress and release the accelerator pedal three times in five seconds. The light will flash twice and go out. I know many GM vehicles use that method
Nov 03, 2009 | 1990 Oldsmobile Cutlass Supreme Conv
Need code for Directv remote for 26LG Flat Screen TV
Program TV Code
1. Turn on the TV.
2. Locate the 5-digit code for your TV.
3. Slide the MODE switch to the TV position.
4. Press and hold the MUTE and SELECT keys at the same time until the green light under the TV position flashes twice, then release both keys.
5. Using the number keys enter the 5-digit code for your brand of TV. If performed correctly, the green light under TV flashed twice.
6. Aim the remote at your TV and press the PWR key once. Your TV should turn off. If it does not turn off, repeat steps 3 and 4, trying each code for your brand until you find the correct code.
7. Slide the MODE switch to the DIRECTV position. Press TV POWER. Your TV should turn on.
Program DVD, VCR, Stereo Receiver, and Stereo Amplifier Code
The AV1 and AV2 switch positions can be setup to control a VCR, DVD, STEREO, second DIRECTV Receiver or second
1. Turn on the component you wish to control (e.g. your DVD Player).
2. Locate the 5-digit code for your component.
3. Slide the MODE switch to the AV1 (or AV2) position.
4. Press and hold the MUTE and SELECT keys at the same time until the green light under AV1 (or AV2) flashes twice, then release both keys.
5. Using the NUMBER keys, enter the 5-digit code for the brand of component being set up. If performed correctly, the green light under the selected position flashes twice.
6. Aim the remote at your component and press the PWR key once. The component should turn off; if it does not, repeat steps 3 and 4, trying each code for your brand until you find the correct code.
7. Repeat steps 1 through 6 to set up a new component under AV2 (or AV1).
Unable to Find Correct Code
If you were unable to find the code for your brand of TV or component, you can try a code search. This process may take up to 30 minutes.
1. Turn on the TV or component. Insert a tape or disk if applicable.
2. Slide the MODE switch to the TV, AV1 or AV2 position, as desired.
3. Press and hold the MUTE and SELECT keys at the same time until the green light under the selected switch position flashes twice, then release both keys.
4. Enter 9-9-1 followed by one of the following four digits:
Satellite - 0
TV - 1
VCR/DVD - 2
Stereo Receiver/Stereo Amplifier - 3
5. Press PWR, or other functions (e.g. PLAY for VCR) you want to use.
6. Point the remote at the TV or component and press CHAN+. Repeatedly press CHAN+ until the TV or component turns off.
NOTE: Every time CHAN+ is pressed the remote advances to the next code and power is transmitted to the component.
7. Use the CHAN- key to step back a code.
8. When the TV or component turns off, stop pressing the CHAN+ key. Then, press and release the SELECT key.
NOTE: If the light flashes 3 times before the TV or component responds, you've cycled through all codes and the code you need is not available. You must use the remote that came with your TV or component.
Verifying the Codes
Once you have set up the DIRECTV Universal Remote Control using the above steps, use the following instructions to find out the 5-digit code to which your component responded:
1. Slide the MODE switch to the appropriate position.
2. Press and hold the MUTE and SELECT keys at the same time until the green light under the selected switch position flashes twice, then release both keys.
3. Enter 9-9-0. (The green light under the selected switch position flashes twice.)
4. To view the first digit in the code, Press and release then number 1 key. Wait three seconds, and count the number of times the green light flashes. Write this number down.
5. Repeat step 4 four more times for the remaining digits; i.e., press number 2 for the second digit, 3 for the third digit, 4 for the fourth digit and 5 for the final digit.
Depending on how you set up your remote, the VOL and MUTE may control the volume only on your TV, regardless of the position of the MODE switch. This remote can be set up so that the VOL and MUTE keys work only with the component selected by the MODE switch. To enable this feature, perform the following steps:
1. Press and hold the MUTE and SELECT keys until the green light under the DIRECTV position flashes twice, then release both keys.
2. Using the number keys, enter 9-9-3. (The green light will flash twice after the 3.)
3. Press and release the VOL+ key. (The green light flashes 4 times.)
Now the VOL and MUTE keys will work only for the component selected by the MODE switch position.
To Lock Volume to AV1, AV2 or TV
1. Slide the MODE switch to the AV1, AV2 or TV position to lock the volume.
2. Press and hold the MUTE and SELECT keys until the green light under the selected switch flashes twice and release both keys.
3. Using the number keys, enter 9-9-3. (The green light flashes twice.)
4. Press and release the SELECT key. (The green light flashes twice.)
Jan 14, 2009 | Directv RC23 Remote Control
Directv remote
1) Use 2 new AA batteries in RC32 remote control;
2) Slide mode switch to "TV";
3) Press and hold the MUTE and SELECT keys at the same
4) Enter 9-9-1-1.
5) Press PWR button on TV.
6) Point the remote at the TV and press CHAN+. Repeatedly press CHAN+ until the TV turns off. Every time CHAN+ is pressed the remote advances to the next code and power is transmitted to the component.
7) Use the CHAN- key to step back a code.
8) When the TV turns off, stop pressing the CHAN+ key. Then, press and release the SELECT key. If the light flashes 3 times before the TV or component responds, you've cycled through all codes and the code you need is not available. You must use the TV remote control.
9) To verify the code, slide the MODE switch to the appropriate position.
10) Press and hold the MUTE and SELECT keys at the same time until the green light under the selected switch position flashes twice, then release both keys.
11) Enter 9-9-0. (The green light under the selected
12) To view the first digit in the code, Press and release then number 1 key. Wait three seconds, and count the number of times the green light flashes. Write this number down in the TV owner manual.
13) Press number 2 for the second digit, 3 for the third digit, 4 for the fourth digit and 5 for the final digit.
To control TV volume from Directv RC32:
flashes 4 times.)
Feb 11, 2008 | Polaroid TLA-01511C 15 in. LCD Television
Code
Hello, you can try the search method,
you do this by either holding down the device button eg: TV or if you have one the "magic" button for three seconds, a light should then flash twice to say you have done this correctly.
then press the keys 991 then the power button.
you must now press the channel up key (ch+) possibly upto 150 times while the remote cycles through every code.
Once your tv or device switches off stop pressing the ch+ key and press the power button to make sure it switches back on,
(if you press ch+ too many times you can go back by pressing ch-)
When complete press the magic or device key again to save the settings (light should flash twice to confirm)
Many thanks
Mark
(www.sparky-uk.com)
Nov 30, 2007 | Televison & Video
Sony FD Trinitron WEGA KV-SW29M50 29" TV Logo
91 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
