Question about Samsung (MP0804H) 80 GB Hard Drive
80 gb ide hdd on bios detected but when i creat partion.showing blue screen restart the computer. so place help me
  • 47 Answers
If you have more then on memory then try using one, one of your pc memory must be faulty
Posted on Aug 05, 2010
Can't setup OS in SATA HDD in Intel d945gccr
Hi.
XP will not install until you go into the BIOS and find the menu page (probably by moving across the top level of tabs) where the SATA hard drives are configured. On that page you will see the ports and at least one, maybe all, will be Enabled. Close to that will be the port mode, usually setable individually for each port. Choices may include IDE (or PATA) Emulation, SATA, AHCI. Set your port to IDE emulation. Now look at the bottom for the key to Save and Exit - often the F10 key, press that key and select OK, the computer will restart and you should now be able to install Windows XP without any problems.
To get into the BIOS you have to press the Del or Esc key when you first turn the computer on.
Regards.
Feb 04, 2013 | Intel D945GCCR Motherboard
Cant detect my western digital hard drive help! philippnes!
Shut down the computer.Disconnect the ide cable from hdd .Just connect using primary hdd and boot the computer. Shut down the computer. Connect the secondary hdd both IDE and power cable. Restart the system and go to bios . Check if the both hdd are detected in bios. If detected boot to desktop. If not detected reset bios settings to default.Restart computer and check. IF still not detected shutdown computer.Disconnected secondary hdd and primary hdd,connected secondary hdd to primary ide connecter and check in bios. If still not detected try connecting secondard hdd on different computer and check.
Aug 17, 2009 | Computers & Internet
I have an hdd that every computer detects it but when it runs to
Do you need the information on it? Connect it as a slave drive, then you could run the following command
Start >> Run >> chkdsk e: /r where <e:> is the drive letter.
If that doesn't work, you could format the drive in windows explorer, however you will lose all data.
Jul 26, 2009 | Seagate (ST380011A) 80 GB IDE Hard Drive
I have the same HDD but system does not recognize the full size
hi there this is because of  unpartitioned disk space i.e, you wouldnt have partitioned rest of the memory while installing OS you would have only partitioned only 130gb tat is the reason it shows tat much :)
u create a partion then u will be able to use memory for its fullest :)
Apr 29, 2009 | Samsung SpinPoint P120 SP2514N 250 GB IDE...
Unable to make partion
Domez,
Try Testdisk to see if it can restore the boot sector.
Chappo07
Sep 02, 2017 | Seagate (ST3160827AS) 160 GB Hard Drive
Sata drive not detected
just no other solution except upgrading BIOS properly
Sep 24, 2008 | Seagate Barracuda 7200.10 500 GB SATA Hard...
How to detect two IDE drives with same brand
You need to set one of the drives to be 'master' and the other to be 'slave'.
This is done by positioning jumpers on the back of the harddrives.
Pretty sure that on the drives is explained somewhere how to position the jumper, for several options.
Good luck,
Please post some feedback.
Apr 23, 2008 | Dell OptiPlex GX280 PC Desktop
SAMSUNG IDE HDD SP0411N (40GB)
Three possible reasons:
1. Your IDE cable is defective or is not seated/plug in correctly. Try to replace or re-seat/re-insert;
2. The on-board disk management of the hard disk is corrupted/defective. There is no remedy except to replace the PCboard or the entire hard disk;
3. Your motherboard BIOS/CMOS needs to be flashed and/or something is wrong with the IDE interface.
Of the 3, # 1 is the most common.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
good luck and kind regards.
Jan 06, 2008 | Samsung (SP0411N) 40 GB Hard Drive
Detection & installation problem
in bios ide configration selecl ATA select both ur sata HDD will be detected
Nov 28, 2007 | Intel Motherboard
ATA133 refusing to be accepted
Obviously mobo error, have you tried re setting bios from 'JBAT1' terminal, jumper from pins 1-2 to pins 2-3 then back on 1-2. Start up again and set time and select the auto detect HDD in standard bios settings see if correctly identified. save settings and restart pc
Jan 15, 2007 | Samsung SpinPoint P80 SP1604N 160 GB Hard...
Samsung (MP0804H) 80 GB Hard Drive Logo
46 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
