Everytime I log in to my yahoo messenger it disappear right away and it says that there's an error occured while I'm trying to access social view plug in..pls help me what to and find solution for that error..
  • 34 Answers
Reinstall the program , download the yahoo messenger here http://messenger.yahoo.com/
Posted on Aug 05, 2010
When I start yahoo messenger, a window appears! it says :" An error occurred when accessing to plug-in social view "! I don't understand and how can I solve that?
think the plug-in referred to is the Yahoo server one as opposed to any of the plug-ins for Yahoo Messenger
It seems your having trouble navigating the Yahoo Server
Make sure your IE is up to date and not set to 'work offline' in tools - Even if you have another browser set as default IE is interlinked with Messenger
Check you have all your support software loaded for Messenger using the links on this page to help
http://help.yahoo.com/l/us/yahoo/messeng...
Note - Flashplayer and Shockwaveplayer must be for IE
Restart your computer
If you still have a problem try running Yahoo Messenger in Compatibility Mode (if its a windows 7 issue)
Right click on your Messenger desktop icon and select 'Properties' Click the Compatibility tab and select to use compatibility mode - choose an OS that you know was successful and click OK
May 02, 2011 | Computers & Internet
An error occurred while trying to access social view plugin
An error occurred when loading this plug-in
Mar 28, 2011 | Yahoo Messenger
What can must i do to my yahoo messenger in everytime i open it it said an error ocurred while trying to access social view plug in.
Reboot your computer. 2. Press Ctrl+Alt+Del on your keyboard. This will bring up the Windows Security window. Click the "Task Manager" button and then click the "Task Manager" tab. 3. You will see a list of files/applications. These are the applications running in the background on your system, whether they show on your taskbar or not. Any one of these applications could be causing a conflict with the Yahoo! Messenger installation. 4. Click the top item on the list to highlight it. Then hold the "Shift" key down and click the last item on the list. This should highlight the whole list. 5. Click the "End Task" button. This will temporarily close all background applications on your system. 6. Click the "X" in the upper right corner to close the Task Manager window. 7. Install Yahoo! Messenger. You should not experience the same issue that you had before. 8. After Yahoo! Messenger is installed,run registry cleaner reginout also reboot your system. All other background applications will return to their original configurations.
Nov 22, 2010 | Yahoo Messenger
Everytime i open ym,social-view plugins error occured..whaat is the best solution??i tried to reinstall it 5 times and the error is still there
First uninstall it and run a system registry after uninstalling. If you can find the Yahoo messenger folder in your root drive directory (C:\) then delete it before you reinstall a fresh copy of yahoo messenger. Good luck. Thank you for using FixYa.
May 30, 2010 | Yahoo Messenger
Messenger 10 social-view plugin error is occuring when signing on, then no other plugins will appear
Uninstall everything yahoo related from add/remove programs. Go to your C:, then Program Files and delete the yahoo folder from there also. Now go download ccleaner from www.download.com and run the cleaner, once that is done run the registry cleaner a couple times.
Try re-installing the latest yahoo from there. IF that failed also, you have one last shot that will work but it can be tedious a bit and a little dangerous so make sure to back up your files before proceeding. If the error still happens, do all of the above except for re-installing the yahoo. Now from the run command (Windows Logo Key + R), type: regedit <Hit ENTER>. Up top click on Edit and then click Find. Type: Yahoo! <Hit Enter>. Delete what it found and then press F3 to find the next yahoo! item. Delete everything it finds till there are no more matches found. Close the Regedit and reboot the pc. Now re-install the latest Yahoo Messenger and the problem is gone. I have done this several times for clients and this fixes it 100% of the time. Cheers!
Apr 23, 2010 | Yahoo Messenger
I just came up to download yahoo messenger version 10.0 beta but it wont work out . Ofcourse I do have uninstalled my old yahoo messenger version 8, After several of trials signing in on the yahoo...
well..this problem occurs sometimes with yahoo messenger 10. so you need to know how can you sign in,
when you try to sign in on yahoo messenger 10, please go to messenger settings and then in the connection settings tab, please select your network type, i mean if your network connection is broadband, select broadband..if you are using dial up modem, select it or if you are using lan..select it...then try to login again..
i think your problem has been solved.
thaks for using fixya
Feb 28, 2010 | Yahoo Messenger
An error occured while trying to access the social view plug in
If you cannot sign in and access your plug-in manager - I suggest you reinstall
I recommend a clean uninstall and reinstall
Close all other programs while uninstalling, downloading and uploading
You will lose your Archive messages
Download Revo - double click on Yahoo Messenger - Use the 'Advanced' mode - Revo will make a Restore Point and then uninstall Messenger using the Messenger uninstall software.
It will then scan your C drive and Registry for all fragments and files that failed to uninstall.
http://www.revouninstaller.com/revo_uninstaller_free_download.html
Download 'ccleaner' and run it through a couple of times,using the factory settings and the 'Run Cleaner' control until 0 byts have been seen to be cleaned following a scan
Run the 'Registry' from the left hand toolbar but 'Save' any changes before repairing
http://www.filehippo.com/download_ccleaner/
Re-start your computer
Download Yahoo Messenger from here.
http://www.filehippo.com/download_yahoo_messenger/
Dec 13, 2009 | Yahoo Messenger
I cant log in ? what should i do?
Re-install Yahoo Messenger.
Oct 21, 2009 | Yahoo Messenger
Yahoo messenger closes automatically evrytime i logged-in
Delete or Uninstall it and then install it from net,your problem will be solved 100%...........
Sep 21, 2009 | Microsoft Windows XP Home Edition
Computers & Internet Logo
117 people viewed this question
Alun Cox
David Payne
David Payne
