Question about HP DeskJet 970cxi InkJet Printer
Making a grinding noise. It sounds like to printer head is hitting the sides of the printer
What you may find is that there is a large buildup of dried ink in an area on the right side of the printer that's jamming the head and making it sound like that. Open the top cover and look underneath where the pushbuttons are on the right side to find it.
It is the result of years of cartridge self-cleaning into a little sponge there - I used a pair of needle nosed pliers to get rid of it and my printer's back in action.
Posted on Aug 22, 2010
Why is my printer making a funny noise when I hit the print button?
that sound come while printing that sound is formed while cartridge or ink
if you want to clear that sound you should keep some oil to move free edges or you can clean
Feb 09, 2015 | Office Equipment & Supplies
Noise on front driver side and i replaces rotors and brakes
may be the backing plate is hitting. or it may be the wheel bearing is bad. check by making turns and see if the noise goes away or starts grinding like a washing machine. IF grinding is worse replace wheel bearring.
Apr 16, 2013 | 2005 Pontiac Montana SV6
Have a 04 dodge with a driver side grinding noise that comes and goes. It started after I got my truck stuck in the snow. I thawed out the front end last night, and now its worse. It comes and goes while...
C V Joints can make a lot of noises. Sounds to me like you either bent the inner fender or if it is plastic you may have pulled it loose and it looks normal but it is just sitting in place with the push pins out of their intended holes. When you turn and or hit a high speed it hits the wheel/tire. Try putting on some gloves and then pulling medium strength on the fender well and surrounding areas to see if that is the problem -
Feb 03, 2010 | Dodge Ram 1500 Cars & Trucks
Rubbing/grinding noise
Usually the strut bearing will make this noise upon turning a corner and hitting a rut or pot hole when turning. A wheel bearing will make a low pitched whinning sound constantly
Jan 16, 2010 | 1998 Ford Ranger SuperCab
Hp 430 plotter
does the belt look ok? sounds like you have some rubber stuck in the motor gear.
Oct 22, 2009 | Office Equipment & Supplies
Printer makes grinding noise and not printing
sounds like the rubber band in side the printer has jumped a tooth which is why it is grinding bud have it repaired or get another
Jul 26, 2009 | Lexmark X5470 All-In-One InkJet Printer
Printer is grinding
sounds Like a paper jam , Plus your paper feed rollers are dirty, clear any paper inside the printer, the using a cloth rag and some 409 cleaner , wipe feed rollers to remove white paper dust on rollers, and let dry, then add paper to printer and it should print.
Jul 21, 2009 | Office Equipment & Supplies
HP Deskjet 1320 printer makes grinding noise and stalls before it prints
I think the noise is normal for hp deskjet. When starting up, the printer read the head existence, and do cleaning. is it the first replacement cartridge? Disable ink status monitor.
May 29, 2009 | HP Office Equipment & Supplies
Printer makes noise while cleaning heads
Grinding noise is most likely caused by the carriage lock getting stuck and holding the print head at the home position. The noise is caused by the toothed belt that pulls the head back and forth, skipping over the splines on the motor drive wheel. If you have been able to print since the problem occurred, chances are that it has freed itself up and will be fine. Regarding the loss of cyan & magenta output, follow the solution given in my previous posts to complete a manual under-head cleaning cycle. This should get you going. Check this previous post for cleaning info: http://www.fixya.com/support/t137335-problem_print_outs_from_printer
Jul 05, 2007 | Epson 1000 ICS All-In-One InkJet Printer
Paper feed
sounds like print head is not engaging home switch or sensor. open the printer and look for any such switch to sense print head at home position.
Jun 01, 2007 | HP PSC 2210 All-In-One InkJet Printer
HP DeskJet 970cxi InkJet Printer Logo
107 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
