On a hp dv6700 i have to take the cmos battery out for a while every time i start the laptop or it will just power on for 2 secs and then turn off and continue in that cycle. whats wrong with it?
    Genius:
  • 1,354 Answers
Hi
go to following link you will have your solution
http://www.insidemylaptop.com/disassemble-hp-pavilion-dv6500-dv6600-dv6700-dv6800-notebooks/
Posted on Aug 05, 2010
  • 1,606 Answers
How fresh is the cmos battery? Might as well replace it with a new one. Thats about 75 cents for a good one. It should be a CR3022 but the battery you have should be marked. Just take it with you to almost any battery shop or place that sells watches or electronics. When you get the battery but before you buy check the date stamped on the package. get as fresh as you can.
If taking out the battery allows it to boot then it sounds like your cmos may be corrupted which is usually caused by a bad battery. If it isn't saving the settings or you notice that it keeps looking for new hardware when starting then its likely the cause. This is much more common on desktops but some laptop models run hot enough to cook the backup battery within a year or so.
HP Pavillion dv6700 - won't power up
Hello.The most common reasons for power issues are the battery, power jack and power adapter/cord.Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.If you move/wiggle the hp pavilion dv6700 power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.If no change, the power adapter is probably faulty and needs replacement.Hope this helps.
Feb 16, 2013 | HP Pavilion Computers & Internet
Hp EliteBook discontinued from workplace, need bios administrator master password. Model 6930p s/n: 2CE910FDBF SERVICE TAG: E6930pUP8400W4X12MINNNN20QeS
hi!
this is how to bypass CMOS SETUP password
*open the cover of you laptop,
*remove the cmos 3v baterry.
*remove the main battery
*push the power button for 10 sec.
*wait for 5 to 15 minutes
*put back the cmos battery and connect the main battery
turn on your computer and enter to cmos setup
Jul 08, 2011 | HP Computers & Internet
My hppavilion dv6700 does not turn on. I try to start it, all the lights go on for about 2 seconds and it shuts off at once. This happens anytime i try to turn on the notebook. what colud be the problem?
Your battery is at too low a charge.
here is a game plan:
Unplug the computer from power
take the battery out of your laptop,disconnect the battery
connect the power to your laptop see if it comes up
If it does come up, your battery has one or two bad cells in it
You can prove it is the battery by using a battery from a known good computer that uses a similar battery.
you can stop wasting time by ording a new battery on E-Bay. Your computer will work fine untill you have the money to by a new battery
Nov 24, 2010 | HP Pavilion dv7-1132nr Notebook PC
HP DV6700, power keeps switching off after 2-3mins from switch on. Fan does not come on and core temp rises above 90 deg. celcius prior to shutdown. Tried unplugging battery and power then holding power...
I have the exact same problem...only started 2 days ago...let me know if you find a solution. I wanted to clean it from the inside but you have to take the whole thing apart,and I am not comfortable doing that
Nov 15, 2010 | HP 6700
My HP dv6700 sometimes turns on and off by itself
What you're describing sounds like a hardware problem, not a software one, if the resetting occurs long before Windows loads.
As it's a notebook, my first suggestion would be to
make sure there's nothing wrong with the power point you're running it from, or the power cable. If you plug a desklamp into the same circuit (old-style incandescent globe, not fluoro) does it flicker? Is the power cable firmly plugged in? Has it been chewed by a pet?
Next run it without the battery and see if it still plays up. If it does still misbehave, you have a problem in the power adaptor or the internal circuitry of the notebook. If it works without the battery, the battery is on the way out and should be replaced.
Apr 11, 2010 | HP Pavilion DV6700T Notebook
HP Pavilion dv6700 Entertainment wont boot
1. Power on (NO Disc.)
2. Press Pause
3. Enter 314159(with remote)
Display will show "FF"
4. Quickly press "0" (for all region)
5. Press pause
6. Power off and powere on after 20 secs.
Dec 09, 2009 | HP Pavilion DV6700T Notebook
HP Pavillion dv6700 - black screen
Do the following without the battery inserted.
Let the computer sit with no battery for 24 hours. Do not put the battery in at all. Try using your original memory stick ONLY, with no hard drive and see if it will POST. If it does, insert the hard drive and try again. Could be the new memory...
Another thing you can try is reseating the processor. Turn the ZIF screw, take the processor out (WATCH THE PINS!!) and put back in GENTLY. Leave the memory in the computer, hard drive removed, try to power on.
These models have been known for bad motherboards. Contact HP and arrange to send it in. If you do enough digging on HPs website, you'll find the service advisory.
-Dell & HP Certified Technician
Oct 29, 2009 | HP Pavilion DV6700T Notebook PC
Hp compaq 6910p BIOS Bypass
I removed the keyboard, unplugged the bios battery, holded down the power button about 30 secs, plugged back the bios battery, assembled the computer, didn't plug the battery and instead of that just plugged the ac adaptor and the bios passwd was gone =)
Oct 29, 2008 | HP Compaq Business Notebook 6910p - Core 2...
Startup password forgotten
Did you remove all other power supplies from the computer, like the battery and AC adaptor. try this again, only leave the CMOS Battery out for 2-3 Minutes, with no other power supplies attached.
Jan 11, 2008 | HP Compaq Evo Notebook N600c
Computers & Internet Logo
365 people viewed this question
Alun Cox
David Payne
David Payne
