Question about Gateway LT2021u Netbook
My batteri is not charging at all, i can only use my laptop with direct power connection. Pls give me s slution.
    Sergeant:
    Champion:
  • 301 Answers
The conector AC into the LAP TOP probabily is broke, check this shake the cable and check the battery icon , if not chane the batery
Posted on Aug 05, 2010
It will not power with battery
the battery charger circuit is short circuit, therefore need to repair or test the battery is ok
Aug 13, 2017 | Toshiba Satellite P100 Notebook
I have an Acer 7736Z the battery isn't charging. The BIOS on the acer support website give me version 2.10 which doesn't seem to match the directions given from previous questions and solution
If your battery will not charge, you need to run a test on some components on the laptop. The battery, the charger and the laptop itself. Once you detect the faulty conponent then you replace it with a new one.
To test the battery:
1.Power off the laptop,
2.Take out the battery,
3.Insert it in another laptop,
4.Check of it will charge,
If the battery holds a charge there, then it means the problem is not from the battery, but if it does not hold a charge, then it means the battery is defective and need to be replaced with a new one.
To test the charger:
1.Unplug the charger from the present laptop,
2.Connect it to another laptop to see if it will charge.
If it charges the laptop, then it means the charger is alright, and if it does not charge the laptop, then it means the charger is bad and need to be replaced.
To test the laptop:
1.Turn off the laptop,
2.Disconnect your present charger,
3.Remove your present battery pack,
4.Insert a well tested battery into the laptop,
5.Connect a well tested charger to the laptop.
If it powers on, then it and charges, then it means the laptop is working fine, but if it does not charge, then it means the connection port of the laptop is bad.Hope this information was helpful.
http://www.chargerbuy.com/replacement-acer-aspire-7736-ac-adapter-19v-90watt.html
Nov 16, 2012 | Computers & Internet
Nokia 2330c hangs and cant be turned off with d power button.pls help fix it.
open and pull battery and check the contact of battery and phone if you see red or pink the phone got wet .
Sep 21, 2010 | Nokia Classic 2330 Cell Phone
Hi My Dell M1530 doesn't start up The battery is fully charged, the power cord is working good(the light is on) but the laptop doesn' give a sign that is connected to power
There could be a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective & needs to be replaced.
Nov 18, 2009 | Dell XPS M1530 Laptop
Hello sir i have gateway model md2614u .when i charge my battry and when it aharged full screen seen black but it shows power by red ight and it give no response.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective.
Oct 29, 2009 | Gateway MD2614u Notebook
Can't charge battery
Remove the battery and try if the PC turn on connecting to direct currrent.
If it turn on (whitout battery), the issue should be a connector problem or a damaged internal recargher.
Oct 19, 2009 | Toshiba Satellite A75-S2112: A75-S2112...
There is power in the laptop.
if you say that either the battery nor the adapter was tested and seemed working fine but not actually giving power to the laptop itself then the problem is the motherboard from your laptop i m afraid
sorry i have no idea about the service center in tamilnadu
Feb 04, 2009 | Toshiba Satellite A215-S7422 Notebook
Battery on Sony Walkman NWZ-E436F
ok, just tried something with maybe a solution....
I was connected via an usb hub to my laptop, then it said battery is full, it apparently didn't charge.
When i connect my usb cable directly to my laptop it started to charge again!!.
My usb hub is not connected to a adapter so all power comes from the USB port, this may be not strong enough to charge your walkman.
Try this (so directly connect to your desk / laptop) it may work!
regards
me
Jan 02, 2009 | Audio Players & Recorders
Dell Inspiron 5160 flashing orange / green power LED
If your Dell notebook battery flashes four orange one green, there might be a problem with your battery.The battery life is also shorten and doesn’t last longer than an hour.gets hot sometimes.
pls see this if it helps
http://www.wareprise.com/2007/07/05/dell-notebook-battery-flashes-four-orange-one-green/
This is directly from the User Manual:
If the computer is connected to an electrical outlet, the Battery light operates as follows:
• Solid green: The battery is charging.
• Flashing green: The battery is almost fully charged.
If the computer is running on a battery, the light operates as follows:
• Off: The battery is adequately charged (or the computer is turned off).
• Flashing orange: The battery charge is low.
• Solid orange: The battery charge is critically low.
pls do rate me FIXYA if i helped u
Nov 29, 2008 | Dell Inspiron 5160 Notebook
Laptop battery problem
I think that your battery is bad or you have a board connection issue.
This could be helping you also (related issues):
1.- Computer AC / DC cable is bad not allowing the computer battery to charge
Verify that the AC and or DC cable is not bad by testing the computer only with the power plug connected and the battery out of the laptop.
2.- Battery is bad
It is possible that if the power plug is good that the computer battery is bad. Leave the computer connected to the power with the battery connected in the computer for at least one hour; if the battery does not charge, consider having the battery and/or the laptop serviced or repaired.
If the computer and/or battery is not in warranty consider just replacing the battery as it is very likely that it is just a bad battery.
3.- Battery charger board is bad
If the battery has been replaced or an alternate battery from an alternate identical laptop does not work in the computer, it is likely that the power or charger board within the laptop is bad. It is recommended that the laptop be serviced or repaired.
Nov 19, 2008 | Compaq Presario 700 470024-192 Notebook
Gateway LT2021u Netbook Logo
85 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
