Question about Dell 9-Cell Battery XPS m1530 laptop. TUXEDO BLACK. 15.4" Widescreen Thin, slim, & light notebook c...
The screen suddenly became blank....and it turned off...its not starting again
  • Dell Master
  • 11,800 Answers
Major hardware fault. the laptop must be opened and tested - if you're lucky it's only a failed memory module. If it's , as usual on this models, the mainboard then it will be very expensive to replace.
Posted on Aug 05, 2010
It was working good all of sudden screen became black and the PXE E61
It seems to have lost communication with the hard drive. Check physically (pop out and then back in) and in BIOS. Make sure its the 1st boot option.
Also disable PXE boot in BIOS or remove from 1st boot option. This is a LAN (network) boot option.
Sep 30, 2012 | Acer Computers & Internet
My HP laptop screen will not do anything. The first time this happened, I was in the middle of something and the screen suddenly became a bunch of black and white random-ness. I shut it down, and tried...
Perform the following:
1. Disconnect the AC Adapter.
2. Remove the Battery.
3. Hold the Power button down for 30 seconds to 1 minute.
4. Reconnect the AC adapter and do NOT connect the battery now.
5. Turn on the Notebook power.
If turned on, shut down the Notebook, insert the Battery and turn it on again. That's it.
Cause:
With an extensive use of the notebook, some times notebook would store some static charges which indeed will stop the notebook from powering up or charging the battery.
Performing above procedure will not effect any personal data or delete any pictures from the hard drive on your notebook.
Aug 22, 2010 | Computers & Internet
Nokia N95 8Gb fell,screen is white.
The screen cable may have become loose or dislodged. You can find out how to replace the screen and also to check the cable here - http://spyda.vox.comlibraryphoto6a00d09e7ac027be2b00d41442e37f685e.html.
You can pick screens up on ebay too.
Apr 05, 2009 | Nokia N95 Cellular Phone
Dwq 58a not recognizing blank media
your DVD ROM lens has became weak.
and it cannot be repaired.
But if you manage to open the DVD ROM clean the dust in it & it will start working again but be careful remember that no power should be attached to ROM.
or you can buy a lens cleaner from market and try that.
pls rate my solution
thankyou
Feb 16, 2009 | Sony DWQ 58A 8x8x4 Slim DVD RW w/ NTI DVD...
Phone does not turn on all shown on screen is a still hour
Pull the battery and reinsert, you didn't lose anything. ;)
Jan 19, 2009 | AT&T Blackberry Curve 8300 Smartphone
My toshiba m35x-s111 laptop screen goes blank
According to the description of the fault and the symptoms that your equipment presents, you must replace the FL inverter, that is the one that gives the turn on of the screen of your equipment, if your you replace this piece that one finds behind of the mask of the screen in the low part and that is similar to a pen I assure you that your equipment it was working in perfect conditions
Dec 23, 2008 | Toshiba Satellite M35X-S111 Notebook
No display, screen is blank even compuer is running
Can I assume (?) you re-tried firmly checking each cable connection and the power supply is soundly in place including checking the fuse in the plug That's all I can suggest as the things I would do if in your shoes.
Aug 05, 2017 | BenQ FP72G (Black, Silver) 17 inch LCD...
Screen became blank- N72
this happens with me sometimes when my phone battery is empty and i connect it to the charge what i do is just remove the battery from the phone then put it again and it should work normally
Oct 24, 2008 | Nokia N72 Cellular Phone
Freezing then blank screen
you have a loose connection, good luck....
Jan 08, 2008 | Samsung X15 Notebook
Dell 9-Cell Battery  XPS m1530 laptop. TUXEDO BLACK. 15.4" Widescreen Thin, slim, & light notebook c...  Logo
50 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
