Question about Air Tools & Compressors
I need a schematic Break down of a cummins 2hp 13 gal 115v 15 amp 13 gal tank air compressor Model # TD-5050(1204) Serial # 0702 including price for the electric motor Thank You
I have a TD-5050 13 gallon air compresser that is a 5 Horse running motor. The mmotor will not start on it's own with out me turning the motor by hand to get it started. I have to let all the air out and than spinn the motor to get it started. If I do this it will run for a long time. I think i might have messed it up with using too light of electric cord.
Posted on Sep 14, 2012
  • Mark A Sep 19, 2012
    I would not use a supply cord with less than 20 amp rateing a #12 wire, check voltage, is it a 120v or 240v motor . if its a 240 volt motor check to make sure it has the proper voltage at the motor. might be the start capacitor is weak or out as that 'starts' the electric motor
I have a Craftsman (919.176820) 2HP, 12 gal. compressor. I starts fine the first time, it reaches full pressure and cuts off. When the pressure drops and it tries to start again, the motor lugs and trips...
Your tank check valve is stuck/broke. It's on the tank end of the line from the pump to the tank. It is supposed to close when the pump stops to keep air in the tank and let the system bleed pressure out of the pump so the motor can start when there is pressure in the tank. The part you need is CAC-437-2 and is available through searspartsdirect.com.
Feb 22, 2012 | Craftsman 33 gal Air Compressor 6 hp...
I need a manual for a clarke bronco 6 gal compressor (ac20008). When I use the unit, I am cutting the circuit breaker off.
I would try a different outlet ( which should be on a different breaker ) -- sounds like your breaker is either bad or to low of a amp rating to handle the load of the compressor.
c...
Dec 31, 2010 | Clarke Power Products Inc AC2001 2HP 4...
Air compressor starts fine,but trips the thermal reset ,motor seems hot. It does it in every receptacal I've tried.
With no air in the tank and amp meter connected to one leg of line, start compressor and note amp draw thru cycle. It should draw low amps at first then reach rated amp draw close to end of cycle(most likely 12-15 amps). If amp draw is normal then replace thermal breaker. Older compressors have thermal breaker incorporated within winding and may not be easily replaced (but not impossible). If amp draw is higher than rated, check capacitor for proper rating and make sure that the in-tank check valve is not leaking pressure back to pump. Good holidays
Dec 29, 2010 | Hitachi EC12 Portable Electric 2hp Air...
I have a C2150 4 gal compressor from Porter cable with 2hp peak and 1.2hp continous rated motor. The problem is that I can not run the compressor on a 15amp circuit with out tripping the breaker. It even...
Try to use a higher amperage extension cord.
This unit is rated for 15 amps. It should be able to run on a 20 amp circuit unless there is voltage drop due to small wiring. Try an air conditioner extension and let us know the result.
Gary
Dec 19, 2010 | Porter Cable C2002 150 Psi 6 Gal...
Turn it on it buzzes and trips the fuse
One thing mine does, If it is plugged into a 15 amp circuit , it will do the same thing. It needs a 20 amp circuit to run, the start up motor on those things draw 16+ amps, and then run on 13. If it is cold, full of air, it won't run, if it has a cord of any length, forget it, It needs a big cord, 20 amp circuit, or no air in the tank and be warm. In the winter time we all had our compressors in the bathroom with the heat on, I though it was for us to warm up in, but it was for the compressors. I thought mine was the only that did it.
Sep 21, 2010 | Hitachi EC12 Portable Electric 2hp Air...
I have a craftsman 1.5 hp/ 2 Gal. air compressor and everytime i go to turn it on it kicks out the breaker. model #921.152100 capacitor ????? plaese help aroberts616@aol.com
Hi there. Plug your compressor in as close to your circuit box as you can on a circuit that is dedicated to that outlet
What is happening is this. You have a 15 amp circuit and a 15 amp draw on your compressor. No wiggle room at all. If you need to get the air a long ways use air hose and never an extension cord. Joe
May 29, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
I am missing the screw in drain plug for a Model 95386 air comp.
this is normal item at parts house, anyway why do have a plug. i put a small ball valve much better i got at home depot
Jul 02, 2009 | Air Tools & Compressors
Air Tools & Compressors Logo
450 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
