Question about Coolmax HD-211-eSATA Hard Drive
Hi I have a 'COOLMAX 3.5" enclosure 500gb external hard drive and its not working when i plug it into my desk top. Do you have any idea what might be wrong? very much appreciated thank you
I had problems with mine after a few years, it wouldn't show up in windows. I took it apart and the hard drive had moved away from the front panel and unplugged itself. there are 4 screws on the bottom that hold the hard drive in place, they must have loosened allowing the drive to move back unplugging itself from the panel. thought I had lost a few years worth of backed up pictures, glad it was that simple.
Posted on Oct 29, 2010
Hi , i have a 500gb hardrive i bought a few months ago, full of family memorys and although it powers up the computer has stopped or failed to regonise the hard drive , pleaser can you help .im desperate
Replace the cable you are currently using with your printer cable and see if it is the cable if that is not the case I would open the case, and check your connections on the hard drive, there is a chance it might have come loose.
Jun 23, 2011 | Genica 2.5 USB 2.0/eSATA Aluminum External...
This was bought from a friend who no longer has the manual and I am still not quite sure what it is or what it does.
This is a case for 3.5" HDD that make any 3.5" HDD become external Drive. Here's the product description from Amazon :
The CoolMax HD-360-U2 USB 2.0 3.5" External Hard Drive Enclosure is portable size and excellent quality. The 3.5-inch hard drive aluminum external enclosure is specially designed for high capacity hard drives. And its aluminum material design is great for heat dissipation, so you don't need to worry about your hard drive overheating anymore. The HD-360-U2 Series gives you the freedom to work anywhere, no matter if you're in the office, at home or on the plane. This portable 3.5" HDD external enclosure provides maximum durability, flexibility and portability with various interfaces. Once you download your information to the HD-360-U2 series, you can connect it to any system and gain access to your programs and data files anywhere. With built-in hot swap technology, you can connect and disconnect the drive any time.
Features
  • Supports high speed data transfer rates up to 480/400 Mbps
  • Fully compatible with 3.5" IDE 133 HDD
  • Soft-start for slow turn-on feature prevents high inrush currents when initially powering capacitate loads
  • Anti-shock design, protect the hard disk from damage when moving it
  • Insulating designed PCB
  • Aluminum case transmits the heat quickly
  • Powered by a DC 12V-2.0 A transformer
You can visit the website : http://www.coolmaxusa.com/extenclosure.asp?item=3.5 for more details
Feb 07, 2011 | Coolmax HD-360B-U2 USB 2.0 External Drive...
Hi I Have a 500GB External desktop dtive and can not get it to work, i have try it with two computers and it do not pick it up the Green light on the box is just flashing and not on all the time regards ...
Try connecting it to a different USB port on your computer.
Try connecting it to a different computer.
If the problem persists, either:
* the USB cable is damaged,
* inside the enclosure, the disk-drive is not functioning
(although the lamp indicates that it is getting electrical power)
* inside the enclosure, the USB-to-disk-drive adapter has failed.
If the warranty is still valid, Seagate will replace it, at no cost to you.
Or, open the enclosure, and remove the disk-drive, and temporarily connect it as a "slave" disk-drive in a desktop computer, to see if it is working at all.
Or, buy a new, compatible, disk-drive, and mount it into the enclosure, to make a "new" external disk-drive.
Oct 29, 2010 | Seagate 500GB Desktop External Drive ...
Plug it in, It's just sitting there clicking, no action
Do you have the AC adapter plugged into power, and plugged into the Coolmax?
(Plus the USB cable plugged into the computer, and to the Coolmax?)
Is your Coolmax an XtremeFiles F1-B?
The link below is to a review of the F1-B, and also details out how to set it up, and install it. This should also work for your external backup harddrive, if it is not an F1-B.
http://www.extremeoverclocking.com/reviews/storage/Coolmax_F1-B_1.html
Sep 05, 2009 | Coolmax (15419) 80 GB Hard Drive
Install a seagate 7200.7 in a cool max enclosure
They sure are !
You need an IDE or EIDE enclosure.
If you bought the enclosure very recently you may want to try taking it back and swapping it for another one
If its a big box store you might want to try the "it just doesn't work and I am clueless" routine
Seen that work quite a bit much to my dismay. Then the people usually get money back and go to another store to get the correct item.
NOTE I dont condone that method !
Aug 20, 2009 | Seagate Barracuda 7200.7 (ST360014A-20PK)...
WD 500gb external HD shuts down when plugged into USB port
Try a replacement USB cable first. If that does not fix the problem, then the USB to SATA adapter board is faulty, in that case you will need to take out the internal disk to replace the external enclosure.
see
YouTube - How To: Take Apart A Western Digital My Book Enclosure
If unit is under warranty see : WD Support > Warranty Services > End User > Warranty Policy.
Note any SATA external enclosure willl work wthe same with the internal WD HD.
Apr 17, 2009 | Western Digital My Book Home Edition 500...
Nexstar.3 Sata external drive woun't start
I also have the same problem. I bought a 500gb WD HDD and it worked great via USB for about 4 days, not the computer does not have it. i am running windows xp home. i can also hear the drive working and the blue light comes on, but it is delayed. When it was working correctly it came on instantly and the computer found it instantly.
May 19, 2008 | Vantec NexStar-3 External 3.5inch...
Problem with Hard Drive
The easiest way to do that is to purchase an external enclosure for your type of desktop hard drive. They come with usb, firewire or both types of connections. It is a simple matter to remove the hard drive from the desktop and install in the enclosure. Plug it in and connect to your notebook. The enclosure will be seen as another hard drive and you can then copy what you need from the desktop hard drive to the notebook. Once on the notebook you can burn to dvd's if you like. This will not work for copying programs. They may still work, navigate to the program folder on the hard drive, find the application folder, open it and find the starting icon, right click on it and send to desktop.
All this is moot if the drive itself is too damaged to spin.
May 12, 2008 | Lenovo ThinkPad X60 Tablet PC
Software for 500GB
I don't think BYTECC sells complete external hard drives. But they do sell the enclosures. People buy the enclosures and install a hard drive in them and, now you have a working external hard drive. I have don't this before, but I have never used BYTECC before. You can download the drivers for there enclosures at there website:
http://www.byteccusa.com/
They have several different versions, Just pick the correct one, hopefully the enclosure has some markings or a sticker identifying the model.
Nov 17, 2007 | BYTECC 1 Bay ME-350U2 USB 2.0 External...
Coolmax HD-211-eSATA Hard Drive Logo
436 people viewed this question
Top Coolmax Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Coolmax Computer and Internet Expert? Answer questions, earn points and help others
