Kyocera FS-1500 printer shows E4:171911 fault?
  • 2 more comments
  • phh3 Apr 26, 2008
    Thank you - do have manual and have RTFM, and it does not cover this. I have also Googled for the fault number, and that shows nothing either.
  • phh3 Apr 26, 2008
    Have read all through manual and it is not covered. There must be a list somewhere of fault numbers and the associated diagnosis and hopefully cure. We do have two of these and the other one works fine. The failure was just on re-switching on after self-test. No smoke or flames!
  • phh3 Apr 26, 2008
    That sounds feasible - it didn't seem as hot as usually. I will try it again and see.
  • phh3 Apr 26, 2008
    Yes indeed - spot on, thank you very much.
  • 19,396 Answers
Sure is nost covered, Kyocera only hint for E4 is call a service man. In reality E4 meansFuser error. Generally you solve this replacinfg fuser lamp. Sometimes fuser error maty be caused by Drum kit fault.
Disconnect printer from poer cable, remove drum kit and put it back to verify this.
Posted on Apr 26, 2008
    Genius:
  • 1,447 Answers
Try to check this site though
http://www.castleink.com/_a-kyocera.html
That is a fuser heater error, cant really troubleshoot it honestly since parts need to be change or serviced.
  • 790 Answers
Hello ,
Its a fuser heater error ...
  • Kanth raj
    Kanth raj Apr 26, 2008
    Ya please check out and reply
  • Kanth raj
    thanks for using fixya !
  • 655 Answers
Do you have manual, try to see troubleshooting section there it might be described.
  • Iqbal Husain
    Iqbal Husain Apr 26, 2008
    Friend have a look on the following pic. This is from your printer manual.(page 4-10).
    It says its mechanical error.(If error code is started by E).
    So, in your case as per your manual you need to call a service person.
    I think this will help you. and if you are agree with me you should rate my solution fixya.
    Thanks
    Iqbal
FS 3900 "Unknow toner istall" shows in display?
The message is indicating that you do not havea real Kyocera toner installed in the machine.
Apr 04, 2011 | Kyocera Mita KYOCERA/MITA - FS-3900DN Mono...
How do I install driver for Kyocera CS 5035 on MAC
Kyocera and Copystar models are the same just replace KM with CS.
The following instructions should help you. TO download the current driver use this link to th emanufacture website; http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?rid=18657.
Kyocera Printer Drivers and Mac OS® X 10.5 Leopard FAQ:
Is the installation for Mac OS X 10.5 the same as for Mac OS X 10.4 and earlier? Mac OS X 10.5 introduced a new printing architecture that requires changes to the installer and installation process. For this reason, Mac OS X 10.5 requires a new printer driver installer.
I cannot see my Kyocera AppleTalk® printer. How can I make it visible to OS X 10.5? AppleTalk is disabled by default in Mac OS X 10.5. Enable AppleTalk to discover your Kyocera printer.If you use the Kyocera installer, a message will appear, asking you to enable AppleTalk. Click Yes to continue the installation.
I cannot find Printer Setup Utility on Mac OS X 10.5. Is it still supported? Apple has removed Printer Setup Utility from Mac OS X 10.5. To install a printer, open System Preferences and click Print & Fax.
When I manually install a printer, multiple PPD files are listed for the same Kyocera model. Which should I choose? When manually installing a printer or changing a PPD for a installed printer, both Linux and Mac OS X PPDs are listed for some older Kyocera models due to a change in PPD handling in Mac OS X 10.5. Linux PPDs can be identified by the word Gutenprint in the PPD filenames.
Supported Multifunction Printers: KM-1650, KM-1815, KM-1820, KM-2050 ,KM-2530 ,KM-2550, KM-3035, KM-3050, KM-3530, KM-4030, KM-4035, KM-4050, KM-4530, KM-5035, KM-5050, KM-5530, KM-6030, KM-6330, KM-7530, KM-8030, KM-C830, KM-C830D, KM-C850, KM-C850D, KM-C2520, KMC2525E, KM-C2630, KM-C3225, KM-C3225E, KM-C3232, KM-C3232E, KM-C4008, KM-C4035E, CS-1650, CS-1815, CS-1820, CS-2050,CS-C2525E, CS-2550, CS-6030, or newer. Supported Printers: FS-820, FS-920, FS-1018MFP, FS-1020D, FS-1030, FS-1100, FS-1118MFP, FS-1300D, FS-1800, FS-1800+, FS-1900, FS-1920, FS-3800, FS-3820N, FS-3830N, FS-6020, FS-6026, FS-9100DN, FS-9120DN, FS-9500DN, FS-9520DN, FS-C5016N, FS-C5020N, FS-C5030N, FS-C8008N, FS-C8026N, FS-C8100DN, or newer.
I hope this is helpful,
Shawn
Mar 08, 2011 | Kyocera Copystar CS-5035 Copier
Hi, I have a problem with my Kyocera FS-3900DN. The display shows the fault 7410:0043899. How can I fix it? Thanks
Will just reflashing the firmware fix this?
I have replaced the EEPROM (as per my post near the top) on a few of these, so that the printer will come to ready and then flashed the EEPROM via parallel port with upto firmware.
skyp techbelkin
Dec 19, 2010 | Kyocera Mita KYOCERA/MITA - FS-3900DN Mono...
I have a kyocera FS-2000D with error code: Call for service 0150:0000049. Help...thanks in advance
Error code 0150 is an engine EEPROM communication error. The engine board might need to be replaced. I have heard that sometimes a defective developer unit could cause this same error code. I would try swaping a develper from a working FS-2000D first.
May 20, 2010 | Kyocera FS-2000D Laser Printer
Kyocera fs-2000d printer
A KYOCERA-MITA technician has to upgrade the firmware.
Jan 31, 2009 | Kyocera FS-2000D Laser Printer
Printer wants toner but toner hopper is full
Did you remember to take the tape off of the cartridge when you installed it?
Jan 18, 2009 | Kyocera FS-2000D Laser Printer
Kyocera Ecosys FS-3900DN in HP emulation mode
Right click on the printer icon and choose properties. Your emulations are listed there.
Jan 14, 2009 | Kyocera FS-3900DN Laser Printer
Kyocera fs-3900DN
Very weird message! Pull down the by-pass tray in the front of the printer and insert a sheet of paper , then print.
Printer not printing - showing 'processing' but nothing happening
Reinstall the driver again, if it doesnot work, you have to update the firm ware of the machine, you can find this on kyocera website.
Nov 25, 2008 | Kyocera Mita KYOCERA/MITA - FS-2000D Mono...
Kyocera fs 1750
First check the neck of the bottle and clean it if dirty
secondly if this does not cure the fault then the sensor in the drum assembly is probably dirty. You will ether have to strip off the end of the drum and clean the led and photo sensor or replace the drum unit.
Aug 25, 2008 | Kyocera FS-720 Laser Printer
138 people viewed this question
k24674
jasbo
jasbo
