Question about Clarion APX200.2M 2/1 CHANNEL POWER AMPLIFIER Car Audio Amplifier
APX200.2 Marine Power amplifier. Problem: No audio, No power light on amp. 12V to amp is good, fuse not blown. Head unit works.
  • 733 Answers
Is the remote power good? also, make sure you have good ground(grind the connection clean if connected to chasis). If that don't work and the fuses on the amp are good, then the amp is blown.
Posted on Aug 05, 2010
I have good power and ground connections but the amp will not turn on.
Make sure the fuses aren't blown. There should be fuses on the amp itself and an in-line fuse in the live power wire near the car battery. If the fuses aren't blown, make sure the remote wire is connected from the head unit. Then re-check your power and ground connections. The ground should be solidly connected to the vehicle chassis in a paint-free location.
Feb 23, 2011 | Visonik VB212PKG Car Audio Amplifier
When I connected my 12V and GND wires and the power light did not turn on. What should I do to give the amp power and make it work?
When I installed mine I had the same problem because my Remote Power wire didn't have a good connection to my head unit, I would just double check that along with making sure your GND wire has a solid connection to metal (make sure you remove paint if there's any on the metal). Make sure none of your fuses are blown of course and that you have a solid connection to your battery as well. I only ever installed one setup (my own) but I hope this helps some.
Feb 08, 2011 | Kenwood KAC-5204 350 Watt Max Power Stereo...
I have a jl 500/1 . The distribution block is lit showing 12v plus. no green power light on the amp? I disconnected pwr and ground and reconnected. the green light came on for 10 seconds and shut off. all...
The amplifier will not power on unless/until it recieves the turn-on signal from the head unit.
It seems the issue is with the head unit in this case.
Check the fuses and verify constant and switched power with a multimeter.
Once the Head unit powers on - the amplifier should also.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 18, 2010 | Jl Audio 500/1 Car Audio Amplifier
Subs and amp dont work
His amp probably blew your fuse. Check that you have 12V at the power connections. If you don't, then find the fuse in your positive wiring to the amp. If you do have 12V to the amp, check your remote power up also has 12V between that and the negative line when your head unit is on. If it doesn't, then it's probably an internal fuse in your remote switch on line inside your head unit caused by a fault in your friends amp. This is normally accessible at the back of the head unit.
Oct 06, 2009 | Legacy Audio LA370 Car Audio Amplifier
Amp not working to power sub woofer
remote wire/ fuse possible? have you checked?
traced all voltage?take and disconnect remote wire from amp and make short wire from remote to 12v if green light works then u may have bad remote wire or blown fuse.
Oct 05, 2009 | Kicker ZX10001 Car Audio Amplifier
Rockford Fosgate Punch 301X not runing
You should verify some other way (with a multimeter or another amp/device) that your 12V is working at the amp. Then to troubleshoot the Remote wire, take a short lead of scrap wire and run it from the 12V power input of the amp over to the Remote input like a jumper. If the amp still doesn't power up, then look for and check the fuse on the amp. If there's good power at the amp, the remote input has good power, and the amp doesn't turn on, and the fuse isn't blown, then the amp is probably toast. Good luck!
Jun 17, 2009 | Rockford Fosgate Punch 301X Car Audio...
No power to my pioneer gm5300t
arcanum,
good day bro, from your Pioneer amp supply line do you also see a terminal marked as " System controller" ? did you also supply 12V DC to this terminal?
the standard power configuration for Pioneer Car amps would be:
12V Dc (+) supply / ( - ) supply ground / System Controller ( supplied by +12V DC)
12V ( + ) supply and The ( - ) supply ground is for stand by power, once you connect the supply through this terminal you will now have the stand by power but will not power on the unit even the LED power indicator.
System controller terminal, this should be supplied by ( + ) 12V line to power up the amp. this serves as the ON/OFF switch for the amp.
cheers,
mark
Jan 25, 2009 | Pioneer GM-5300T Car Audio Amplifier
Amp will not power on.
the amp will not turn on if any of those fuses on the side of the amp is blown
make sure you have positive to battery
ground to car body (or negative on battery)
and remote wire to the back of the head unit
Jun 29, 2008 | Pioneer Car Amplifier GM-5100T - 2CH 760...
Trouble shooting XM-1652Z Amp
Grab yourself a test light and make sure that not only the 12v red power wire is putting out power but the thin blue or 12 volt turn on wire is also showing power. Then test the ground terminal and make sure u have a good ground. If that doesnt work try checking the amps fuses and check the fuse and connection on the battery. If everything checks out ok and the problem persists then put a small test speaker to the channel outputs and make sure that u are getting noise from those channels if you dont get any noise then u most likely have bad outputs and blown channels, you will need a new amp. Good luck, hope i was good help.
Jan 26, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
No Power
Hello jasper100, Have you opened the unit to take a look inside? Since you dont have a blown fuse we cans assue the a short has not occured. Now I would chect to see if the voltage regulator in the amp has voltage coming from it. It may not in that case you may have to remover the old regulator and put in a new one just to get to the point of properly troubleshooting this amp. I would suggest that you get a schematic for this unit and use a multimeter to look at the voltages in the power supply section and see which sections have no rail voltage (12v supply voltage). I would also advise checking the remote to for regulator failure.
Sep 10, 2007 | Legacy Audio Blue Diamond LA580 Car Audio...
Car Audio & Video Logo
132 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
