Question about Hansgrohe 28110001 Chrome Raindance Raindance Three Function Hand Shower wi
Hansgrohe Raindance allrounder shower has suddenly no water pressure whilst using shower and can it be thermostate or blockage
3 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: loss of pressure in Hansgrohe shower panel
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 05, 2010
HANSGROHE US
  • 7 Answers
SOURCE: I replaced a broken Hansgrohe hand shower with a
Hi Christieb942,
When you get a new hand shower you can sometimes get sediment on the federally mandated FLOW RESTRICTOR. Not screaming, that is ****** in cheek. To CHECK the Flow Restrictor for debris, look at the hose connection end of the hand shower. You will see an INSERTED part that is green, yellow, or white. We have to push that in there to satisfy the EPA requirement for flow. You can pull it OUT and rinse it off. Then connect your handshower and try it and see if it is improved. You will not void the warranty in any way by doing this. I hope you understand what I am telling you, but if not you can call me 800-334-0455. I wish I could answer more directly, but Big Brother has eyes.
Posted on Sep 20, 2011
How do i install showerhead
REmove old showerhead using two wrenches, one to hold the stem from the wall steady, then twist the head counterclockwise. Use the same wrenches to install the new one, twisting the head clockwise to tighten. But before you put it on, clean the threads on the stem with a rag and wrap teflon plumber's tape around the threads clockwise 4-5 turns. That keeps it from leaking and makes it easy to remove in the future.
May 26, 2014 | Hansgrohe Shower 27495 Raindance S 150 Air...
Shower head stuck in middle selector
sounds like the link between the selector lever and the internal control surface is broken or stripped. if the unit can be disassembled without damaging any parts, then looking in side will likely allow identification of the problem.
Mar 19, 2014 | Hansgrohe Raindance 27483001 Chrome 6"...
Air rain shower head leaking
The most common issue with this type of head is water deposits building up in the spray face. This will cause the unit to express water from the venturi in the center of the spray face as well as other places. If this is the case the best solution is to remove the unit and soak it in CLR for about ten minutes. Then rinse it well and reconnect to the water source. Run water throught the shower head and while running rub the rubber water channels to further break up and clear out the deposits. Then repeat the process at least two more times or until the deposits are cleared out. If you need further help feel free to contact Hansgrohe Technical at 1-800-334-0455.
Jan 22, 2013 | Hansgrohe Raindance 240 AIR Showerhead ...
Slow flowing hansgrohe shower head
First thing to check is the filter screen at the hose connection on the hand shower. If this screen is clean and there is no debris in the flow restriction device inside the handle end you will most likely need to clean the hand shower spray face. You can remove the unit from the hose and soak the spray face in CLR. Follow the instructions on the container for use and dilution. Soak for no more than 10 minutes at a time. After soaking, rinse the unit well and reconnect to the water source. Run water through it and while running rub the rubber spray channels to further clear up any deposits. Repeat the soaking and cleaning process at least two more times to clear out all deposits that may be limiting your performance. If you need more help feel free to contact me at Hansgrohe. 1-800-334-0455. Press 2 for tech and ask for David Scarborough. I'd be happy to help.
Oct 29, 2012 | Hansgrohe Shower 28504 Raindance S 100 Air...
We've installed a Hansgrohe ibox rough-in part #01850181 with a single control valve Solaris E part #04228820, (although the # on the valve is 3072474) and a handheld shower part #28518821 Raindance E 150...
It could be misplumbed behind the wall. In other words someone may have accidentally attached a "T" connection in the wrong place. It happens....
Feb 08, 2011 | Home
Hansgrohe 06358620 shower not hot enough
Remove the handle by loosening the screw near the bottom. You should see a plastic ring, probably green, that is the hot water safety. Adjust it so that the handle will turn further for more hot water. It most likely pulls out, then turn it left, reinsert and reattach the handle.
Apr 26, 2010 | Hansgrohe 06358620 Pressure Balance Valve...
Hansgrohe shower
it's possible sometimes you can get brand new junk. one question is the thermo coupler in the right postion? i would check to make sure that it is indeed picking up the temp like it should.
Sep 02, 2008 | Home
Hansgrohe 28110001 Chrome Raindance Raindance Three Function Hand Shower wi Logo
104 people viewed this question
Top Hansgrohe Home Experts
ray gallant
Daryl Gleaton
Are you a Hansgrohe Home Expert? Answer questions, earn points and help others
