Question about Samsung Heating & Cooling
My casset type 24kbtu allow the outdoor to run only for 2 or 3 min then goes off.
  • 909 Answers
Clean the condenser properly and check the fans
Posted on Aug 05, 2010
How to change A4 display to LTR display
Go to Printers and Faxes, right click on the printer icon and select Printer Properties.
then select the paper type as LTR.
If in case you do not get the option, re-install the printer drivers.
Sep 08, 2014 | Canon iR5000-6000-L1 PS Ver 1.0
0NLY AUDIO,CAN'T SEE IMAGE
good day Angel i am Falco the problem you have might be due to dirty heads on the Drum unit, I would first try a head cleaning tape, there are 2 types of head cleaning tapes one looks like a typical video casset type tape and the other is like a wight frizzy type tape that you apply a cleaning liquid to for a deep cleaning the first one is used for preventative maintenance, try the 2nd type first, it may take several times to restore your video note allow time for the liquid to dry up before trying a tape at least several min`+ , if after this procedure the problem has not gotten better than you might have an electronic fault and might not be worth perusing further, If however this made some improvement than you are on the right track and might require a better cleaning procedures, if so contact me further and i will step you through the procedure.
best of luck and regards Falco
Oct 15, 2013 | Aiwa HV-MX1 VHS VCR
Hi I am having a LG VCR GC980W 6 heads HiFi model. There is a bad picture and sound in some cassetes while playing while in another video the same cassetes works fine. I wonder whether it can be belt...
This is adirect drive type and the poor picture quality has nothing to do with the belt.
The fault can be due to
1. fault head- since this is a Hi-Fi type , it is 6 head type. try cleaning the head to confirm, use a clean cassette.
2. Problems in the head amplifier circuit.
3. Check the RF connection to TV.
4. Clean the audio head and use a ordinary cassette to confirm the sound. Also try with a Hi Fi cassette.
If not the head is a suspect.
Sep 13, 2011 | Televison & Video
MY AC UNIT WILL RUN COLD AIR FOR 2 MIN THEN IT WILL KICK OUT WITH ONLY THE FAN RUNNING. wAIT 3 MIN IT WILL KICK BACK ON FOR 2 MIN THEN STOPS AGAIN. WHAT DO I DO TO FIX THIS PROBLEM?
Clean the outdoor coil, slide the unit out of the case, take a garden hose and nozzle to it use a solid stream of water, and watch the fins that you do not damage them with the water. Clean the indoor coils as well, and check to see if the motor is oilable. Keep the water out of the other components.
Jul 08, 2011 | Fedders X Chassis A6X05F2B Air Conditioner
Cassete not getting inserted.[message comes as remove cassete]
Does this happen with all cassets???
If So then....
1. try using a head cleaner casset.
2. connect the cam to your p.c. and check it for viruses.
Nov 06, 2010 | Canon ZR85 Mini DV Digital Camcorder
The Casset is rejecting back
I got the solution from your net only.Thanks it is wotking presently.you have to do simply take out the cassete and keepp the cassete door open.And then take both the battery out i,e one main battery and another small battery and leave camera in this psoition for two hrs and tehn place back battery in its position and then load cassete .It will work.I have tested it.Thanks a lot.
BK PRASAD
Apr 19, 2009 | Sharp Viewcam VL-Z1 Mini DV Digital...
Heats for 15 - 20 mins then blows cool air
If the outdoor unit is in defrost mode the compressor will be running but the outdoor fan will not. You may even see some steam rising from the coils. This mode is to prevent frost or ice build up on the outdoor coil. Essentially it goes into cooling mode w/o the outdoor fan running.
Mar 05, 2009 | Goodman GPC1342H21A Air Conditioner
Kelvinator Highwall Split Model KSE70CRA
The unit is tripping when the outdoor unit tries to come on. This could be two things, first change the capacitor on the outdoor unit by removing the top cover of the outdoor unit. If this does not solve the problem, your compressor could be faulty
Jan 30, 2009 | Heating & Cooling
Our toshiba ras13 skv a heat pump keeps going to pre def mode and not heating the house
this happens when the outside temp is low, asthe outdoor unit blows cold when in heating (reverse) then the unit goes to pre def to avoid it freezing. You should hear a whoosh this is the heat being blasted to the outdoor unit to defrost it, then the heat has to build up again before the indoor unit fan runs up again and blows heat. Mine does the same every 20 mins or so (its -2 outside) brrrr
Leigh
Jun 18, 2008 | Heating & Cooling
Heating & Cooling Logo
46 people viewed this question
Top Samsung Heating & Cooling Experts
gbob59
billconfused
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
