Question about Nokia 6300 Cellular Phone
My headset is activated even i haven't attach it to my phone
    Sergeant:
  • 129 Answers
Hi :) N6300 always have this pro,cause the headset port easy dirty or water damage,made it keep activated in headset mode. u may use a teeth brush and some alcohol brush clean the port. if no use,u need send to nearby mobile shop ask technician replace new port.
please voted me if my solution useful.thank.
Posted on Aug 05, 2010
How to pair it with galaxy tab 4
This is for the 1900, but should be the same. Go to Bluetooth settings on your Galaxy.
Samsung HM 1900 User Manual
Aha, I found this for the 1500
4 Enter the Bluetooth PIN (0000, 4 zeros) to pair and connect the headset to your phone. Your headset supports the Simple Pairing feature which allows the headset to be paired with a phone without requesting a PIN. This feature is available for phones that are compliant with Bluetooth version 2. The headset also can be paired via the Active pairing feature, see page 14. Connecting with two Bluetooth phones
With the Multi-point feature activated, your headset can be connected with two Bluetooth phones at the same time. 1 After connecting with the first Bluetooth phone, press and hold the Talk button until the blue indicator light stays lit. 2 Press and hold the Volume up button to activate the Multi-point feature. 3 Activate the Bluetooth feature on the second Bluetooth phone and search for the headset (see your phone???s user manual). 12
4 Select the headset (HM1500) from the list of devices found by the second Bluetooth phone. 5 Enter the Bluetooth PIN (0000, 4 zeros) to connect the headset to the phone. ??¢??¢ You can set the headset automatically to reconnect to the recently connected phones each time you turn it on. -- To reconnect to the two most recently connected phones, activate the Multi-point feature. Press and hold the Volume up button in Pairing mode until the blue indicator light flashes twice. -- To reconnect to only the most recently connected phone, deactivate the Multi-point feature. Press and hold the Volume down button in Pairing mode until the red indicator light flashes twice. ??¢??¢ When the headset connects to two Bluetooth phones, some phones may not connect to the headset as the second Bluetooth phone. English
Disconnecting the headset
To disconnect the headset from your phone, ??¢??¢ Turn off the headset. 13
Reconnecting the headset
When the headset is paired with a phone, it will attempt to automatically reconnect each time you turn it on. If the headset does not automatically attempt to reconnect, ??¢??¢ Press the Talk button. Pairing via the Active pairing feature
With the Active pairing feature, your headset can automatically search for a Bluetooth phone and try to make a connection with it. 14
3 Press and hold the Talk button until the violet indicator light turns on. The headset will switch to Active Pairing mode, search a Bluetooth phone within range, and attempt to pair with it. [. . . ] ??¢??¢ To switch between the current call and the held call, press and hold the Talk button. 19
http://lastmanuals.com/manual/SAMSUNG/AURICULAR-MONO-BLUETOOTH-HM1500
Oct 30, 2015 | Samsung HM1500 Bluetooth Headset
No voice is heard even though it is connected
If you cannot hear the voice eventhough it is connected, do as follows:
• Ensure that the headset is charged, switched on, and paired with and
connected to your phone.
• Ensure that the Bluetooth feature is activated on your phone.
• Check that the headset is within 10 meters (30 feet) of your phone and
that there are no obstructions between the headset and the phone,
such as walls or other electronic devices.
• To reset the headset if it stops functioning, although it is charged, plug
the headset into a charger, and briefly press the power key and the
middle of the volume key. This reset does not clear your settings (for
example, pairing settings).
please dont forget to rate me.....
Good luck....
Apr 08, 2010 | Nokia Bluetooth Headset Headset
Headset connection
your headset jack is fauilty chang it
Jul 30, 2009 | Nokia 6300 Cellular Phone
My nokia 3650 does'nt have a sound
please gothrough the service centre and change your charging soket.
thanks
Rgrds: Rajiv kumar 09811461147
Jun 22, 2009 | Nokia 3650
GPRS / MMS activation
If your phone says "Network Not Available", you should:
- restart your phone.......if you configure the GPRS/MMS
for the first time you have to restart your phone so that the
settings configure your phone properly
- even if restarting your phone doesn't work, then check your
settings or install the settings again, sometimes the settings
you installed get corrupted or your phone cannot detect them
so install them again or take it to the service provider
if here is any further question, then feel free to ask!
Jan 16, 2008 | Motorola Mobility RAZR V3i SLVR L7 L8 OEM...
Lg k800 cellular phone - headset not working
It should activate automaticaly. on my phone as soon as i connect it, it is detected right away. it might be the headset then since the only real options for the head set are what you said before the proiles. hope it helps some what
Aug 03, 2007 | LG KG800 Cellular Phone
Nokia 6260
try a master reset on your phone, this will be located somewhere in the settings
May 15, 2006 | Nokia 5100/6100/6300/7100 Series Black...
Nokia 6300 Cellular Phone Logo
Top Nokia Cell Phones Experts
270rexton
270rexton
