Question about Simplicity Quilter's Classic SW240 Mechanical Sewing Machine
Simplicity quilters classic model sw240 The dial that changes the stitches fell off, like it stripped out. What can I do to fix it?Is it the gear inside? I tried to pop it back on and that did not work.
3 Suggested Answers
Tally Girl
  • 1133 Answers
SOURCE: I have a simplicity quilters
Is the needle bent, burred or blunt, did it strike a pin or the sewing machine foot during the jam up?
Hand wind the machine through the stitch formation and listen for any squeaking or popping sound as the needle enters the fabric. Or just change the needle anyway and see if it helps. A needle is good for 4-6 hours of sewing only so they do need changing for each new project.
If the stitching is looking uneven and tension is bad check your thread path and make sure the top thread is between the tension discs correctly and under tension, the tension dial is set to the mid range 5 or so and that the bobbin thread is correctly held by the tension spring and is in the right way and rotating in the correct direction.
If looping on the underneath, then your top tension is off, and visa versa.
Posted on Apr 05, 2011
  • 293 Answers
SOURCE: Does the simplicity classic model S02 do a hem stitch? Does it come with the hemming foot? Can you please show a hemming foot for it so I can compare it to the feet my machine has? Thanks
No the Simplicity Classic Model S02 doesn't come with a hemming foot. It is too simple a sewing machine. It does have the capability of doing edging and some basic stitches that can be used for hemming, but there is no specialty setting. See the linked pdf quick start guide for more information. http://www.mastersewusa.com/video/S02LetsGetStarted.pdf
Posted on Jan 28, 2015
Looking for a free manual for simplicity quilters classic model sw240
Search the internet for:
Manufacturer + Model + the word "Manual"
Sometimes you can find downloads from the manufacturer's web site.
Oct 05, 2015 | Simplicity Quilter's Classic SW240...
How can I fix my simplicity quilters classic sewing machine that the to thread seems to get hung up in the bobbin case and the machine freezes up and will not sew?
Is it really threaded correctly? Is the needle, old, blunt,or slightly bent? Are the thread and needle compatible with the material? :)
Jul 08, 2014 | Simplicity Quilter's Classic SW240...
Machine skips stitches on bulky items
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
Aug 19, 2013 | Simplicity Quilter's Classic SW240...
Use 1 step automatic buttonhole on simplicity quilters choice
if your sewing machine has a button hole lever, then the button hole
function will not work until the lever is pulled down.
it to the right of needle
I'm including a link for a manual hard copy or download, they cost
different prices
http://www.sewingpartsonline.com/instruction-manual-simplicity-sw240.aspx
http://www.sewingpartsonline.com/instruction-manual-simplicity-quilter-s-classic-sw240-download.aspx
Sep 07, 2012 | Simplicity Quilter's Classic SW240...
I have a simplicity quilters classic SW240. It got jammed and now that I got that fixed the tension is off. The machine will sew about 8-10 good stitches and then skip a couple and then sew again. I can...
Apr 05, 2011 | Sewing Machines
Simplicity Quilter's Classic SW240 Mechanical Sewing Machine Logo
65 people viewed this question
Top Simplicity Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
doylesouders
Level 1 Expert
Are you a Simplicity Sewing Machine Expert? Answer questions, earn points and help others
