Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
On my sony tv stand by/timer flash 4 times what can i do to fix it
Phantomgreen
  • 128 Answers
SOURCE: my tv won't turn on!
My tv did the same,this means your tv needs serviced.Mora than likely it is the bulb gone out in it.These are expensive but east to replace yourself.Just make sure to dispose of the old one properly.You can look in your manual how to change the bulb,that way you can pull it out and check it,see if theres any discolorations or broken pieces in it.You might only need a Phillips head and a small flat screw driver. head to get it out.
Posted on Apr 08, 2010
SOURCE: sony tv timer light flashes wont turn on
Same exact thing happened to my 27" Trinitron purchased in 1998. I tried all the rudamentary stuff that Sony had on their esupport page, but nothing worked. In our case, it went out while my daughter was watching it. I think the time has come to scrap it, and consider a different television, and I don't think I'll go with Sony this time. I hope the rest of you have better luck.
Posted on Feb 17, 2008
  • 4234 Answers
SOURCE: Sony Trinitron Color TV KV-35V65 - No Picture, red light stand/by timer flashing
A reset won't fix this. The standby light should be blinking a repeated count with a 3 second pause inbetween. Post that count here. That will indicate the circuit/condition that is preventing the set from turning on.
Thanks,
Dan
Posted on Jul 18, 2008
  • 2336 Answers
SOURCE: Sony WEGA Fails to Turn On Stand-by Timer Flashes 7 Times
Follow the instructions from the image provide and see if that works, if it does not work; you have a hardware failure in your TV. The hardware failure could be the HOT or flyback transformer.
Let me know if you need further assistance.
Posted on Aug 23, 2008
rulds2008
  • 3866 Answers
SOURCE: tv turns on then off, stand by timer light blinks 4 times
You need to replace the power supply unit on this as it has malfuctioned there about $90 bucks plus labor on that.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on May 25, 2009
Our Trinitron KD-27FS170 Tv will not turn on. It sounds like it is turning on/off but no picture or sound. The Stand-by/Timer red light is flashing 4 times, pause, then 4 times, etc.
This typically means you have a bad capacitor, you can inspect for any swollen or bulging capacitors however unless familiar with desoldering boards best leave it to a repair technician.
Jan 13, 2015 | Sony FD Trinitron WEGA KD-27FS170 TV
Won't turn on.stand-by light flashes.timers are
my Sony trinitron kv-g21s2 TV not working . conned to the power blink in TV power indicator led
May 29, 2011 | Sony FD Trinitron WEGA KV-13FS100 13" TV
Tv wont turn on. red timer light blinking. i think our baby hit some magic button.
I have a Sony Trinitron KV-35S66 36" TV my Stand by/Timer Light keeps flashing, I have tried all fixes, it's 9 1/2 years old is is worth fixing/cost.......no money!!!!
Jan 02, 2011 | Sony FD Trinitron WEGA KD-36FS130 36" TV
TV does not turn on. Stand By LED blinks 4 times and pauses and blinks 4 times again Tv will not turn on...when plugged in the red stand by light flashes 4 times...you can hear the tv turn on but a black...
On older Sony, sometimes a power surge causes the set to be in shut down mode. Try unplugging for 5 minutes and then plug in and try. This many times will fix.
May 31, 2009 | Sony KV-27S42 27" TV
Need help
try to press the timer button repeatedly untill u see time 00 is desplayed may be u solve your problem if it is in sleep timer mode and if u managed to rset timer to 00 and the problem persist your tv has a high voltge problem it delay to charge the tube.
Sep 08, 2008 | Sony Grand WEGA KDP-65WS550 65" Rear...
Thanks,
Dan
Jul 18, 2008 | Sony KV-35V65 TV
Timer Standby light flashing No pitcher
Sony
Model # KP-53HS10
Serial # 9718217
MFG 2000
Plugged in TV. Timer Standby Light just flashes continusly. No Picture and No Sound.
Apr 02, 2008 | Sony KP-51WS500 51" Rear Projection...
Stand By/Timer Flashing 4 Times
It means that there is a horizontal sweep or High voltage circuit falure. It is a high voltage circuit and only a trained tech should attempt to repair these sets. A TV set is not a place to be experimenting inside of.
Sep 26, 2006 | Sony KP-53V85 53" Rear Projection...
Timer / Stand by light flashes
could be high voltage problem. time for your local repair shop.
May 27, 2006 | Sony KP-53HS10 TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
265 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
