Question about Samsung SyncMaster XL2370 23" wide TFT Screen (2ms)" 23 inch Monitor
How to made a custom vesa stand for Samsung XL2370 it; ns safe to drill in back box?
2 Suggested Answers
Fix ya Geek
  • 94 Answers
SOURCE: Can i mount my Samsung
you can get a bracket that goes outside the frame and holds it up that way,try ebay for the best price
Posted on Mar 07, 2011
I need a replacement tabletop base for 19 inch tv NS-LCD19...Is it available?
Unfortunately the stand for this TV is not longer available for purchase. What I would suggest would be searching for "Vesa stands" there are several stands that function like a vesa wallmount, but are a stand instead.
Sep 29, 2017 | Televison & Video
Can you tell me what size screws I need to mount my Toshiba Model 46G310U on a wall?
M6 or M8
http://support.toshiba.com/support/search?s_query=mounting+bolts
User Manual
Page 6
... stand. 3) Once you have removed all four screws holding the pedestal stand in place, remove the pedestal stand ..., level, stable surface that can support the weight of the surface. Four screws Hook Sturdy strap (as short as possible) 46 / 55" TV VESA Mounting Pattern 32" TV VESA Mounting Pattern Four screws Hook Sturdy strap (as short as possible) Four screws Hook Sturdy strap (as short as a quilt or blanket. Make ...) 200x200 mm 200x200 mm 400x200 mm 400x200 mm Screw Size M6 M6 M8 M8 (unit in mm) 40" TV VESA Mounting Pattern Removing the Pedestal Stand 1) Carefully lay the front ...
Toshiba 46G310U Mounting Screws
Sep 24, 2017 | Televison & Video
Fix pedestal for samsung 740BF
you can buy a wall mount for under 12 bucks. Or alternately you can buy an VESA 100 mm compatible stand for about 30 bucks
There're are out there lots of solutions for LCD, arms for mounting in desk, wall or poles.
Mar 22, 2014 | Samsung Computers & Internet
Need to remove monitor stand
should be four screws holding it on. Take them off and keep them safe. The monitor is made to take this off and mount to a VESA square block plate for wall-mount etc.. look and you will see them there.
Dec 29, 2013 | Envision EN7410 17" LCD Monitor
The left and right insert part of the stand on my Samsung Syncmaster 403T broke. Where can I get a replacement part. The part no. is BN61-00424 for left and right insert of the stands.
Those aren't easy to find (if at all). Your best bet would be to ditch the original stand and get a VESA compatible mount or stand kit. You can usually get them for cheap on monoprice.com
Oct 23, 2013 | Samsung SyncMaster 214T 21.3" LCD Monitor
Where can I buy a new base for the Samsung 24
The original Samsung stands will be very hard to find, only available from somebody that has wall mounted their monitor and no longer needs the stand. You can get a third party stand such as the one in the link below that will mount your monitor. All modern monitors have mounting holes in the back for VESA mounting, this is a standard configuration.
http://www.amazon.com/Adjustable-Tilting-Mount-Bracket-10~25inch/dp/B003L171KW/ref=sr_1_12?ie=UTF8&qid=1339684562&sr=8-12&keywords=monitor+stand
Jun 13, 2012 | Samsung 24" LCD Monitor 2494SW
What is the ''cover bottom'' plate for?
Dont know this exact model, but I own a Samsung and so does my father so this proably applies:
The cover plate is supplied for use when the TV is wall mounted using a VESA mount secured to the four holes on the back of the TV. When wall mounted, the normal stand is removed and this leaves a bit of an unsightly "hole" in the case at the bottom. The cover you mention is then secured in place of the stand to make the bottom of the TV nice and neat.
You may find there was a separate leaflet in the box the TV came in detailing this aspect, which is why it isnt mentioned in the manual.
Oct 01, 2009 | Televison & Video
Cannot find VESA holes...Samsung Syncmaster 970p
I have looked at the specification for this, and although it does show as being VESA compatible (This is a display standard) There is no mention of any "wall mounting" capabilities at all, which would lead me to believe that this is not designed to be put on a mount. also the "Magic Rotation" Technology which is part of this device may rely on it using the proprietory stand, it may well be possible to remove the stand however, but it would require some significant dissasembly as the power connector is on the signal box, and this would need to be seperated from the stand itself. The mounting bolts look to be hidden behind the round pivot cover on the back, and it may be possible to see if mounting is possible simply by removing this, however I would seek information from the manufacturer about this as removing any of the covers would most likely invalidate your warranty, it is possible that this was missold to you and you should be able to take it back as not being fit for purpose.
Sep 15, 2007 | Samsung SyncMaster 970P 19" LCD Monitor
Samsung SyncMaster XL2370 23" wide TFT Screen (2ms)" 23 inch Monitor Logo
466 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
