Question about Audiovox XMCK10 Satellite Radio Receiver
No signal We recently had our XMCK10 reinstalled in a new vehicle. We got a signal for a few days but then kept getting a NO SIGNAL message (we didn't have this problem w/ the unit in our previous vehicle) . When we had XM send a refresh, it would work for a day or so and then went back to NO SIGNAL. The installer rechecked the connection and they said it was fine. Any ideas as to why we can't get or keep a signal?
    New Friend:
  • 168 Answers
It sound like the ant. is cut ( this happen to me) or the ant not pluged in all the way.
Posted on Mar 08, 2009
My Jimmy is having a hard time starting, sometimes it dosen't.
Sounds like your problem might be with the VATS anti theft system. Does your truck have the chip in the key? If so you might just need the ignition lock cylinder changed out. There are 2 very small wires that run from the lock cylinder down the column and plug in under the dash. After time the wires insulation will get brittle and crack. The wires read the resistance of the diode chip that is in the key and send the signal to the VATS computer witch tells the ECM weather to send the signal to the fuel pump or not. On a cold moist morning the resistance signal can be interrupted or the resistance lever raised enough for the computer to get an improper signal. Your vehicle is thinking that an improper key is being used to try and start the vehicle. A replacement lock cylinder can be purchased for around $80 at your local part store and you will need to take your current key and the new cylinder to a lock smith to have the pins in the new cylinder changed to fit your current key. This way all of your current keys will still work the vehicle instead of having to pay $40 for each new key. Anyway, after you have the new cylinder working with you old key simply take it in to have it changed out, shouldn't take any competent mechanic with the right tools more than an hour to change out.
Apr 24, 2013 | 1998 GMC Jimmy
Electrical Problems...
I just bought one myself, on a 97. When cops rip out their equipment they mess up a lot of things so a person has to repair them. Mine was to where no body could get in the truck and couldn't figure out "how" to open it. Some dash lights didn't work, windows didn't work, engine hesitated, etc but only had 123,000 miles on it. All problems fixed now and car is great within two weeks. Yours sounds like you will have to trace "all" your electrical harnasses. That's what I had to do and repair all the damages or buy a whole new harnass for the car front to back.
Sep 01, 2012 | 2001 Ford Crown Victoria
When i turn on my 2005 jeep chereokee the car turns off and a red circle comes on the dash on the right side. what is causing the car to turn off?
That red light has to do with the alarm system of the vehicle. This system uses a key with a small chip located in the key head. When you start the vehicle the alarm recieves a signal from the key. If the alarm is not seeing this signal it will cut off power to the engine and that red light will appear. While there are a few possible reasons this can occur I think the best place to start is with the key. Did you recently get new keys made?
Jul 04, 2011 | 2005 Jeep Grand Cherokee
I recently had a 2nd Motherboard put in my CPU because I kept getting the message that my Virtual Memory was low. After putting it in, however, I was able to use it for a couple of days and then I'd get...
YES! If he/she forced, banged, staticly-charged the mother board you could in fact have a short on the mother board. Now, because your virtual memory is low... Well, that is no reason to change out anything. That is all software controled and accesses the hard drive (clearning temp. memory durring disk clean up and such.)
Jul 12, 2010 | E-Machines Computers & Internet
No input signal
Check connections, Hertz rate, and settings (if you can read them). Otherwise, it may be time to whip out the cash and get a new monitor and/or computer.
Aug 17, 2008 | Computers & Internet
No Signal message displaying after screen goes black
Try loading drivers for the LCD monitor.Right click empty part of desktop>>Properties>> settings It should show monitor name instead of plug and play monitor on ---- Video board.Go to Advanced>monitor>driver on this screen.
May 06, 2008 | Acer AL2017 20" LCD Monitor
61" RCA Projection TV, no picture, "unusable signal" message
Read the suggestion of unplugging the TV for at least 4 hours to re-set to factory specs and that took care of it!
Apr 03, 2008 | RCA HD61LPW165 61" Projection HDTV
Losing GPS signals.
i also have the same problem my gps loses the signal i left the unit on power for two days and still no signal please help.
Nov 26, 2007 | Fine Digital FineDrive 400 GPS Receiver
Toner low signal
Try turning your copier off & back on. Allow the machine to cycle after turning it back on - until it comes to ready or displays add toner signal again. You can try this three or four times as it sometimes takes the machine a few trys to advance the new toner to the toner sensor. If after 4 attempts you are still getting the add toner message - you may have a dirty or faulty toner sensor. The toner sensor is located inside the developing unit that you are loading toner into. Toner sensor is usually located on the bottom of the developing assembly & is held in by 2 scews. It can be cleaned with a dry cotton rag & reinstalled. 90% of the time power cycling the copier a few times will solve this problem.
Apr 18, 2007 | Sharp AL-1000 Copier
Audiovox XMCK10 Satellite Radio Receiver Logo
138 people viewed this question
Top Audiovox Audio Players & Recorders Experts
Chinmay Joshi
Chinmay Joshi
Computer Links
Are you an Audiovox Audio Player and Recorder Expert? Answer questions, earn points and help others
