Question about Dehumidifiers
I need a manual for my humidifier please. It's 'Rollex by Woods' Model RW20
Humidifier does not turn on
if your saying that the voltage drops to around 4 volts at the supply transformer at anytime , then id say the load (device connected) is too much for the transformer to supply this most likely is caused by an internal fault in the load (humidifier) also since its a water appliance id say a water leak might be a factor in that as well , taking a look under the cover of the humidifier 4 signs of a water leak (or past one) would be where id start
Nov 11, 2015 | Aprilaire Model 700 Automatic Whole-house...
Unit forms ice on back coil. Please advise
The freon in the unit is low. You probably have a leak.
Jul 13, 2014 | Friedrich D40 Dehumidifier
The float switch will not shut off so the container over flows. I have been trying to replace the CHERRY Snap Action Switch, P/N KWJE0001, but can't find any one to sell me just one switch. Can...
I have the exact same problem. Does anyone know where to buy a replacement KWJE 0001 switch? It's crazy to throw away a $200 humidifier because of a broken $2 switch!
Thanks,
Paul
Jul 07, 2011 | Woods WMD55W Dehumidifier
I need an owner's maunal for a Sunbeam SWM5251 humidifier
Hi, you can purchase a PDF copy of the Sunbeam manual from TradeBit.com here for $9.99:
http://www.tradebit.com/filedetail.php/58045622-sunbeam-swm5251-um-owners-manual
Unfortunately, Sunbeam doesn't offer free downloads of their manuals online.
Dec 27, 2010 | Sunbeam Warm Mist Humidifier Dehumidifier
Manual ed50
Hi. Not sure if you were ever able to obtain a manual, but I found one online as I am trying frantically to find a new blower motor for my Wood's Frostguard ED50. The link I found the manual at is www.woods.se The dehumidifiers are apparently from Canada.
Jul 13, 2010 | Woods WD25G Dehumidifier
I have a GE Dehumidifier Model AHW50LMG1. Am trying to find out how to clean the container that the water is collected into. After use the container contains residue from collected water that I am...
Vinegar is the proper way to clean all parts of a humidifier. It stops scale and kills bacteria and fungus. It can be processed through the heating element without any adverse effects.
Thank you,
James.
-------Please vote 4 thumbs up 4 me!!!----------
Apr 24, 2010 | GE Dehumidifiers
How to clean it
check the manual, it will be described there. if you don´t have one, ask here: http://manualfox.com/link/sunbeam.htm
May 19, 2009 | Sunbeam Warm Mist Humidifier Dehumidifier
Adjusting dehumidifier on furnace
This model furnace does not come with a built in humidifier. Humidifiers are normally an optional add on. If you have a by-pass type humidifier it is none adjustable. Water level is normally float controlled and operation is control by blower circuit. When ever the blower runs the humidifier operates when in the heating mode.
Jan 24, 2008 | Dehumidifiers
Dehumidifiers Logo
320 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
