Question about Russell Hobbs 14071 VariableSpeed Blender
LOOKING FOR A NEW GLASS BLENDER JUG MODEL RHB314
I require replacement blade and glass blender jug for model 14071
Presumably a Russell Hobbs though you did not say; the blender is obsolete and parts hard to source,furthermore given the price of comparable parts it would be cheaper to buy a new blender. I hate it when that happens.
Jul 12, 2014 | Blenders
Glass Jug replacement for National Blender
I have that exact same blender, and I'm missing the lid. Are you still interested in the jug?
May 14, 2014 | Sanyo 5 Piece Cord Free Collection...
Broken plastic base for CBL25
FIXYA does not know who might have a broken JUG .
Dec 03, 2017 | Breville CBL25 Moda Bar Work Top Blender
Blender jar leaks
Check the blade assembly if it is loose tighten it up. If it is worn out or cannot be tightened up then buy another jug complete with blade. If it is the glass jug model then the blade assembly is available without the jug and they also have a replaceable seal at the base.
Aug 11, 2013 | KitchenAid KSB580CR - 5 Speed Blender...
Were can i get a glass jug for my onn blender
What make and model is the blender? If you search for the make and model online then you should be able to find replacement parts for the blender.
Feb 22, 2013 | Blenders
Broken glass jug - Sunbeam blender PB7600
I have one, marlene 0409465707
Aug 26, 2009 | Blenders
Broken glass jug on kitchenaid blender model 5ksb2aer4
Look at the underside of the blade shaft. The metal wing nut on the end of the shaft secures the blade assembly to cream coloured plastic blade base. The wing nut also transmits the drive from the rubber coupling on your blender to the blade shaft. The wing nut has a LEFT HAND thread.
The left hand thread ensures the blade assembly does not unscrew during normal blender use.
Firstly disassemble the blender blade assembly. Place a folded tea towel over the blades and hold the blades firmly. If you do not use a tea towel you may cut yourself.
Grip the wing nut with your other hand and unscrew it CLOCKWISE.
Remove the wing nut. You can now remove the blade from the plastic base.
Put the blade assembly in the new jug and offer up the plastic base from under the jug so that the blade shaft protudes enough for you to install the wing nut.
Screw the wing nut ANTI-CLOCKWISE to secure the blades to the plastic base.
Do not over tighten the wing nut; you may have to replace your jug again at some point.
Jun 06, 2009 | KitchenAid KHB300 Handheld Blender
REPLACEMENT GLASS JUG FOR KF 1850M DELONGHI BLENDER
I want to replace plastic jug of my blender, It leaks
Dec 09, 2007 | Bosch MMB2000 Work Top Blender
Replacement glass jug?
I will buy the blade set from you? I will return....
Nov 14, 2007 | Bosch MMB2000 Work Top Blender
Russell Hobbs 14071 VariableSpeed Blender Logo
159 people viewed this question
Top Russell Hobbs Blenders Experts
eyecam
Marvin
Marvin
Are you a Russell Hobbs Blender Expert? Answer questions, earn points and help others
