Question about Amana ARS2464B Side by Side Refrigerator
I have an Amana side by side frig and the freezer is not keeping ice cream cold. The refrigerator side seems fine. The freezer side is set to 7 but it no longer clicks like it used to when you turn the dial to lower numbers. It was working fine and the freezer kept things very cold and then all of a sudden things started to melt. However, some things in the freezer freeze, while other things like ice cream do not. Any possible solutions? The frig is about 8-9 years old. Thanks, David
  • 39 Answers
If you do not have guages (freon) and have a licens to proforme this type of work you will need to have someone qualified in this area to varify.You can call sears home repair @ 800 469-4663
Posted on Aug 07, 2010
Hi, I got no Ice in the freezer, and the Ice Cream is not hard
the higher the # the colder the frig should be . / if ice cream is not hard the freezer is not cold ennogh . so clean the coiles and ck the two fans . also look in back of freezer side for ice build up there should not be any frost on back wall . if so you've found the problem . which is a defros problem .. mm
Jul 08, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Amana SCD25tw side by side. Ice cream very soft, freezer blows semi cold air NOT ice cold. refigerator side seemes ok. I checked coil and it is NOT icy.
If the coil is not iced up then it is not a defrost problem but rather if the coils are not completely cold all over then the compressor is failing or the refrigerant has leaked out.
Sep 05, 2009 | GE GTS22KBP Top Freezer Refrigerator
Freezer is cold but not keeping icecream frozen.
If, the fresh food section is 34- 38 degrees, then the freezer should be cold enough to keep ice cream solid. All of the cooling capability comes from the freezer section. I, personally, would not waste time or money on a ten year old box. Ten years ago it cost $1000, so, the outlay is $100 per year. Dump the old refrigerator and get a new one.
Aug 27, 2009 | Refrigerators
Ice cream and bread don't freeze, food in frig DOES freeze
Not fixed but I do not want to spend MORE money to find out what's wrong with this AMANA piece of ****. Apparently, from research on the net, the compressor or motor is not strong enough in this unit to actually do the job...but if anyone has any suggestions, I'm happy to hear them...
May 16, 2009 | Amana ATB1832AR Top Freezer Refrigerator
Freezer way too cold - ice cream hard as a rock
The freezer may get as low as -18 degrees F or 0 F this is the point when life and bacteria stops growing.
Ice cream shouldn't be that cold unless it is whipped with air.
Feb 27, 2017 | Kenmore Refrigerators
GE GSS27RGMFWW Freezer Not Freezing..
Hello. I just now found your post here on fixya. Do you still need help with your frig?
Oct 16, 2008 | GE GSS22JFMWW Side by Side Refrigerator
Amana Side-by-Side refrigerator hot spot
hi tanks for the question there are heaters at the spots you said were hot and those heaters are there to prevent moist air from hitting cold surface and create warer droplets from forming on those surfaces i would remove the back of the fridge and vacuum it out that should solve your problem thanks the appliance doc
Sep 18, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Frig not cold but freezer is ice maker not making much ice either
Is your fan blowing in the freezer? Frost on the back wall of the freezer usually indicates a defrost problem... defrost themostate, heaters, take back panel off and check evap for frost build up and if your fan in working.
Aug 28, 2007 | Amana AFD2535DES French Door Refrigerator
Amana ARS2464B Side by Side Refrigerator Logo
268 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
