I have recently installed a new printer, HP C4280. it has, apparently moved all my photos into a libary, but I cannot open the libary to choose photos for printing. Please advise the best thing to do, thanks
    Genius:
  • 3,587 Answers
Hmmm..that's unusual..
I'd get this application, and let that sort out my photos..
Posted on Apr 26, 2008
Is there any way to install my hp photosmart C4280 without the disk? I recently moved and can't find it. The conncetion point on the actual printer is damaged as well, so I can't simply connect it...
hello Jessica
kindly send me 4 thumbs up
you simply go to this site , select the OS you use and download the drivers for the printer, save on your desktop. make sure the printer is disconnected from your computer . install the drivers after they are downloaded and follow instructions-- very qick and easy
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=ca&dlc=en&lang=en&lc=en&product=3192753&
Aug 15, 2011 | HP PhotoSmart C4280 Laser Printer
HOW DO I INSTALL THE INK CARTRIDGE IN PHOTOSMART C4280
Turn on power to printer, then lift the top half of Printer lid, the cart holder will move to centre, place printer cart in the holder rack, press firmly in place.
Jun 07, 2010 | HP PhotoSmart C4280 Laser Printer
I have a c4280 all in one printer/scanner. The print feature works okay but when the scanner button is pressed, pop up indicates that the USB cable is not connected? How can I correct the scanner problem?
Apparently, the C4280 driver on your CD is incorrect. So, reinstall your C4280 driver from here:
www.hp.com and on the left side you will see a grey menu that says software and driver downloads. Click on it and type your product. The version right now is 9.7.1
DO NOT INSTALL THE HP INSTALLER FILE - it is the same as on your CD.
Hope this helps.
Sep 03, 2009 | Office Equipment & Supplies
Install new color caridge on C4280 HP printer
open your printer cover and you can easily install your caridges
Aug 30, 2009 | HP Photosmart C4280 Aio Printer
I have already the HP Photosmart C4280 All-in-One: Printer, Scanner, Copier but I can not install it to my Loptap (acer)which has no CD drive to install the same... So I need to download a free...
your driver is available for free download here http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3192753&lc=en&cc=us&dlc=en&lang=en&cc=us&submit=Go%20
you will need to chose your operating system on the first page.
the second page has the drivers. personally i always download the full software and drivers together (they include the extra software to edit photos and stuff)
download them to your desktop (so you can find them) double click on the icon it creates to start the install, follow the prompts, restart the computer when asked..
Regards..
May 26, 2009 | HP Photosmart C4280 All-in-One InkJet...
How do I install ink cartridge for hp photosmart C4280
To replace the print cartridges
1. Make sure the HP All-in-One is on.
CAUTION: If the HP All-in-One is off when you open the print cartridge door to
access the print cartridges, the HP All-in-One will not release the cartridges for
changing. You might damage the HP All-in-One if the print cartridges are not
docked safely when you try to remove them.
2. Make sure you have letter or A4 unused plain white paper loaded in the input tray.
3. Open the print cartridge door.
The print carriage moves to the far right side of the HP All-in-One.
4. Wait until the print carriage is idle and silent, and then lightly press down on a print
cartridge to release it.
If you are replacing the tri-color print cartridge, remove the print cartridge from the
slot on the left.
If you are replacing the black or photo print cartridge, remove the print cartridge from
the slot on the right.
1 Print cartridge slot for the tri-color print cartridge
2 Print cartridge slot for the black and photo print cartridges
5. Pull the print cartridge toward you out of its slot.
6. If you are removing the black print cartridge in order to install the photo print cartridge,store the black print cartridge in the print cartridge protector or an airtight plastic container.
7. Remove the new print cartridge from its packaging and, being careful to touch only
the black plastic, gently remove the plastic tape by using the pink pull tab.
1 Copper-colored contacts
2 Plastic tape with pink pull tab (must be removed before installing)
3 Ink nozzles under tape
CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching
these parts can result in clogs, ink failure, and bad electrical connections.
8. Slide the new print cartridge forward into the empty slot. Then gently push the upper
part of the print cartridge forward until it clicks into the socket.
If you are installing the tri-color print cartridge, slide it into the left slot.
If you are installing a black or photo print cartridge, slide it into the right slot.
Work with print cartridges 69
Maintain the HP All-in-One
9. Close the print cartridge door.
If you installed a new print cartridge, the HP All-in-One prints a print cartridge
alignment page.
10. When prompted, ensure plain white paper is loaded in the input tray, then press the
button next to OK.
NOTE: If you have colored paper loaded in the input tray when you align the print
cartridges, the alignment will fail. Load unused plain white paper into the input
tray, and then try the alignment again.
11. Place the page print side down on the scanner glass and then press the button next
to OK to scan the page.
When the On
Please Don't forget to rate this solution. Thanks.
Feb 17, 2009 | HP Photosmart C4280 Aio Printer
I have recently install a new printer. Apparently all my photos have been moved nto a libarybut I cannot open this to choose a photo
that can happen during set up..you may wish to consult with your users manual, or consider getting this application to handle your photo library needs.
Apr 26, 2008 | Office Equipment & Supplies
C4280 printer photo cartridge instalation help
The extra cartridge you bought was probably the number 99 cartridge, if I'm not mistaken.
The cartridge actually replaces your black cartridge. Inside of the cartridge has black ink as well as the special photo ink.
I hope this helps
-Ernest
Mar 07, 2008 | HP PhotoSmart C4280 Laser Printer
Installation Problems, Please help!
try downloading the software from the HP website and then reinstall the printer. But also try to uninstall it using control panel add/remove programs, restart your computer, and then reinstall using the downloaded driver.
Jan 27, 2008 | HP Photosmart C4280 Aio Printer
22 people viewed this question
jasbo
jasbo
