Mitsubishi cs-35401. horizontal line only. ic 401 is charred. assume this is for vertical. need part no. for ic-401.
  • adam_2513 Sep 01, 2008
    line across screen
2 Suggested Answers
Slinteriors
  • 8617 Answers
SOURCE: Mitsubishi WT42311 Convergence IC replacements didn't work
the pico fuses will usually need replacement when the Ics go out they take out the two 5amp pico fuses.You can get replacement picos at the following link.
http://servicemanuals.vstore.ca/
Posted on Oct 11, 2008
SD Tech
  • 14553 Answers
SOURCE: Mitsubishi WS-65809 convergence problem
I know these sets very well and have posted instructions here for the chip replacement many times.
If you really need help I am in California and will be online noon until 11 pm tomorrow- (Pacific time) if you really want help post a question in the Premium section here attention SD TECH and I will help you more.
SD TECH
Posted on Jan 29, 2010
Mitsubishi cs-27tx1. Only has a thin horizontal line thru middle of screen
Hello
Total Vertical Sweep failure had occured in your TV. That is there is only horizontal sweep there, and the whole picture sweeps horizontally and you see a horizontal nice line across the screen, at the middle of it. In this case, all other buttons will work, and sound output will be Ok.
This fault is normally due to Vertical Sweep Out Ic trouble. You have to open the back cover of your TV, and have to pull the main board out. Locate the Vertical Output Ic. It is easy to locate it. There will be four wires going to the deflection yoke assembly [the coil fitted alongwith the picture tubes' neck]. Amoung them, two will be thick, and is carrying horizontal sweep signals. The other two wire are comming from vertical sweep section. Follow the wires and find out from where it comes from the main board. Somewhere near it orginates from the main board, you will see an Ic usually screwed into a heat sink [ a metal plate or so]; and it is vertical output Ic.
Check first, whether there is input voltage [working voltage] come to it or not. Sometimes an open resistor problem may occur to show this fault. Normally vertical section will have a voltage rating between 18 to 35VDC. If that voltage is there, surely the Ic said above is damaged. Screw it out and desolder it from the mainboard, and go for an identical type and number, replacing it will solve your problem.
Take all precautions when we works with an elctrical equipment. Keep away children and never allow even stand beside you while you are working, and let an adult beside you as a precaution. Never use metal chair. Do wear a plastic of rubber shoes. If can, keep matted the floor also with carpet. Ok
Wish you success.
Gopakumar G.
Oct 25, 2010 | Mitsubishi CS-13104 TV
Mitsubishi #35401 has only a white horizontal line across the middle of a dark screen. Please tell me the likeliest few parts to suspect. Thanks, RenThelp@aol.com, or 1 800 662 6231
Sounds like Vertical collaspe, Problem is in your Verical circuit
I need you to look on back of TV for correct Model number WD?
Thank You.
Feb 17, 2010 | Mitsubishi Televison & Video
I have a Mitsubishi CS-3125R that displays a horizontal line with sound. I suspect the horizontal transistor is out and cannot find one. Any ideas?
You are misleading yourself. When you have a horizontal line across the screen it means that the vertical circuit is not working. You see, the vertical circuit moves the beam up and down which is not happening. The horizontal circuit moves the beam left and right and it is working. Your set probably needs a new vertical output IC and some electrolytic capacitors that work with it. The caps dry up with time and harm the output IC.
Jun 04, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Tv problem
The vertical deflection circuit has a fault.
Try hitting (not to hard). If it comes back, even for a short time, it is a cracked circuit or solder joint.
No results, there is an IC responsible for the picture to become whole again
Jun 02, 2009 | Mitsubishi CS-35207 35" TV
Horizontal line across my tv
This is a problem with the vertical circuit and is relatively common. If you can solder you can fix this yourself. First try resoldering the pins on the vertical IC. If that fails to resolve the problem, replace the IC. This IC is a small flat IC attached to a heatsink having about 11 pins or so. Is will be marked LA7837 or something similar. Post the marking here and I'll confirm the part.
Keep us posted.
Dan
Aug 19, 2008 | Mitsubishi CS-26201 TV
Single Horizontal line
The vertical IC has failed. Open up the back and look for a small flat IC attached to a heatsink. It should have about 11 pins or so and be marled LA3847 or something similar. First try resoldering the pins as it is common for the connections here to go bad. If that fails to resolve the problem, replace the IC.
Keep us posted.
Dan
Aug 18, 2008 | Mitsubishi CS-36609 36" TV
TV problem
Hello Barbara76,
Is this a Horizontal line (inch or two) across the screen, if so
the fault could be either a faulty Vertical IC,Faulty Electrolytic
capacitors or just simple dry joints.
Regards
Patrick
P-Tronics
Feb 03, 2008 | Mitsubishi CS-27205 TV
Mitsubishi cs-35401television
HORIZONTAL FAILURE AND LINE DOWN THE SCREEN. REPLACE T5A1 LOCATED ON PCC-3-PCB. PT#349P145030(FOR CS-35401,CK-35402 ONLY) Hope this helps! Troy
Sep 11, 2007 | Televison & Video
Vertical Sweep
If the quality of the picture was good before it failed it is worth repairing,replacing the vertical Ic should take care of your problem and for a service technician is a fairly easy repair and they usually dont charge too much,maybe 100.00 to 150.00,if you take the set to someone is less the charge but I know is heavy and it might not be an option,shop around for the price of an estimate in your house.
Sep 30, 2006 | Mitsubishi CS-35505 35" TV
Televison & Video Logo
279 people viewed this question
Top Televison & Video Experts
Electro Med Services...
