Question about Car Audio & Video
Head lights make the radio come on and , i have to unhook the cd player from the harness to cut off the parkinking and tail lights
On the back of the stereo (assuming it is an aftermarket unit) there are only 4 wires that deal with power.
Black- Ground
red- 12V+ turns on with the key
yellow- 12V+ always on
orange- illumination circuit,
the orange wire is most likely hooked up, it is intended to change the brightness of the radio when you turn on the headlights, however it always causes problems, best bet is to disconnect the orange wire, you do not need it, i am 99% sure it will not change the function on the lights on the deck.
dash lighting in cars runs on reverse polarity so a dimmer circuit can be used on a DC power system. the radio does not understand this and it causes strange issues like this one, give it a shot, please let us know how it goes.
thanks
JCC
Posted on Apr 26, 2008
No interior lights ,radio, or tail lights
may be a relay has gone bad, but with those issues it could be the wiring harness has a short in it. GM make some bravada and trailblazer vehicles with defective harnesses
Apr 17, 2013 | 2002 Oldsmobile Bravada
2001 dodge durango /tail light troubleshooting
Open the rear door, locate the two screws next to the tail light. They will be philips head. Take them out, pop off tail light, unhook light harness. Reinstall is opposite of removal.
Sep 01, 2012 | 2001 Dodge Durango
What is the wiring diagram on a kenwood cd player? i unhooked stock stereo in 93 pontiac sunbird cut all the wiring and cant figure the wires out on cd player
Scroll down to page 15 on this link i gave you. If you removed the factory stereo, don't throw away the connector that plugs in to the back of the factory radio. Go to wal mart or any car audio install shop and buy yourself the wiring harness for your particular model car and year, it will definitely save you a headache due to the fact that some car wiring systems are wired differently and are somewhat complicated at times. http://manual.kenwood.com/files/B64-3691-00_00.pdf
Jul 02, 2011 | Kenwood KDC-135 CD Player
We are tring to install this model CD player into my 1999 Honda Accord. All wires are accounted for except for one remaining orange and white wire for "illumination". Where does this wire go?
you do not need it. It will only make the display on the radio dim when you turn head lights on.
If you used a harness adapter, it would connect this correctly so it will work. If you cut the harness, that was a bad move.
Just make sure you tape up the end of the wire so it doesn't short.
Oct 10, 2010 | Radio Communications
I installed a cd player in my car about 2 months ago. It wasnt the greatest installation, as I had an extra wire not going to anything, and the cd player would occasionally short out, and i would have to...
Sounds like you wired the cd player to the tail light fuse and the power wire touched ground. Go to the fuse panel inside the car and check the fuses. The tail lamp one and possibly also the dash light fuses will be blown, replace them after disconnecting the cd player power wires and taping off where they were connected. If you have the factory harness for the original radio still in the dash you can get a wiring harness to directly plug into it from walmart. If you don't have the original harness , the easiest way to power the cd is to tap the cigarette lighter wire.
Mar 11, 2010 | Honda Accord Cars & Trucks
My radio harness was cut and tring to install cd
okay you will need to hard wire it in the vehicle. so i will need to know what year make and model car you have?
Jan 31, 2010 | Clarion DXZ645MP CD Player
Wiring for radio 1993 toyota corolla
You likely blew a fuse for your lights. Here is a wiring diagram for the original radio.
Mar 19, 2009 | 1991 Toyota Corolla
Tail and dashboard fuse keeps blowning
unhook black wire from harness and the ground from pioneer unit install the ground wire from pioneer unit to frame of car (you may need extra wire to do this) make sure the black wire from pioneer unit is bolted to frame of car not to the harness black wire........fuses will no longer blow and you will have your lights.
hope this helped
Mar 04, 2009 | Pioneer DEH-P6400 CD Player
Car radio
That wire is an unused spare
Jan 07, 2008 | Jensen CD4610 CD Player
Car Audio & Video Logo
76 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
