HOW TO INSTALL CANON MF 4100 PRINER DRIVER - Computers & Internet
    Genius:
  • 1,354 Answers
Hi
just follow the step
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} · step 1 Place the computer and printer next to each other and make sure that all the wires are connected to both the printer and the computer.
· Step 2 Turn the computer on and wait for it to boot up.
· Step 3 Plug the printer into the wall and then take the USB cord that is attached to the printer and plug it into the appropriate port on the computer.
· Step 4 Turn the printer on.
· Step 5 Click on "Start menu" and go to the "Control panel".
· Step 6 Find "Printers and hardware HOW TO INSTALL CANON MF - clip_image001.gif" box and click on it.
· Step 7 Take mouse and click "Add printer".
· Step 8 When you see "Welcome to the add printer wizard," hit "Next."
· Step 9 Click "Automatically detect and install plug and play printer" on the add printer wizard page. Click "Next."
· Step 10 Installing the printer will begin if the network can automatically detect it. Otherwise, the message unable to detect will pop up and you will be prompted to install the printer manually. Click "Next."
· Step 11 Select printer port. Use the recommended port for best set up options. Click "Next."
· Step 12 Pick manufacturer and printer. Click "Next."
· Step 13 Type a name or confirm name if it appears in the box and set printer as default printer if wish. Click "Next."
· Step 14 Print a test page to be sure printer is set up and online. Click "Next."
· Step 15 Receive a successful completion of installation of printer message. Click "Finish."
Posted on Aug 05, 2010
Canon mf 4100 data sheet
Hello, are you referring at the user manual or the service manual?
Nov 25, 2016 | Canon MF4100
My canon imageclass mf4100 won't install. says it is not compatible with the operating system. can you help?
Try installing the printer's drivers that correspond with your operating system or update the drivers.
You can download/update the drivers on this site.
Hope this helps.Thanks!
Oct 12, 2011 | Canon imageCLASS MF4150 All-In-One Laser...
I`m trying to install the "MF 5770 Driver" on "Windows XP". I'm prompted as follows: "An older version of MF Driivers exists in this computer. Uninstall the older version...
There may not be a program or "driver" you can see. It depends on how you searched your files. Be sure to check search hidden files when setting up the search. A driver may be mentioned in your Registry. Printers, especially Canons, leave software or references to software behind frequently.
When doing your search, use the Search Companion, not the newer Windows search. Under More Advanced options at the bottom, be sure to check Search hidden files and folders.
One thing I am a little confused about. CanonUSA has no driver updates on their website for the MF 5770. Where did you get this driver from? They only have firmware updates.
Canon instructions for driver install at website below:
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/imageclass_series/imageclass_mf5770#ServiceAndSupport
Nov 03, 2010 | Computers & Internet
Need printer driver for canon imageclass mf 4122
Open http://www.canon.com.sg/p/EN/39-All-In-One/104-Laser/4-imageCLASS-MF4122/ Click on support and download drivers.
May 27, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
Canon mf 5770 problem : opening the mf toolbox 4.9, the twain driver will not be shown, programm quits. running the setup utility of mf tool box again, it works, until system reboot, then the same...
I have the same problem. You can't use Canon Toolbox 4.9x. It does not work. You will have to download and intall the x64 driver only from the Canon website for the MF5770.
Unpack the x64 driver and install it.
Go to the Start-menu and click on Units and Printers. Right-click with your mouse when hovering over the printer, then choose scan, fax or print.
We can only hope that Canon will solve the problem in the future, most likely not since MF5770 is an older Multifunction-machine.
Jan 05, 2010 | Canon imageCLASS MF5770 All-In-One Laser...
Same problem with Canon MF4150 printer and Mac OS 10.6
Yes, there is no driver at all, currently, shall be available by end of october, what in reality means end of year or further! Not kidding.
There is a OS X 10.6 driver for MF4350 which does work with issues, at least in my case:
(a) single pages work (redic...) (b) pages which are unscaled
otherwise output is garbage!
However it is a workaround to live with, not nice, not perfect ...
Sep 01, 2009 | Canon imageCLASS MF4150 All-In-One Laser...
Printer won't work with new computer
I don't understand why my approach worked, but it did. Having tried all of the reasonable and obvious things, I downloaded an update of the Canon toolbox, which has to do with scanner operations rather than printing. Still, once I did this, I was able to use the MF4100 laser printer with my new computer.
Faith
Sep 11, 2008 | Canon imageCLASS MF4150 All-In-One Laser...
Computers & Internet Logo
163 people viewed this question
Alun Cox
David Payne
David Payne
